No. of quadrilaterals in a polygon
  • Thread starter zorro
  • Tags
    Polygon
So it would be 22C2 * 4 = 968In summary, to find the number of quadrilaterals with at least one side in common with a 24-sided convex polygon, we can subtract the number of quadrilaterals with no common sides from the total number of quadrilaterals that can be formed. This is represented by 24C4 - 12C4 = 10131. Another way to approach this is by choosing 2 vertices per side of the polygon, giving us 22C2 * 4 = 968 quadrilaterals.
zorro
1,384
Quadrilaterals are formed by using the vertices of a convex polygon of 24 sides. The number of quadrilaterals having atleast one side of the quadrilateral in common with the side of the polygon is ?
We can find out the total no. of quadrilaterals that can be formed and subtract from it the no. of quadrilaterals with no side common to that of the polygon.
24C4 - 12C4 = 10131
I got 12 by choosing alternate vertices.
I don't get the correct answer this way :|
I'm guessing here but what about 22C2 per side. You use 2 vertices for one side then you need 2 more to form the rest of the quadrilateral.
Related to No. of quadrilaterals in a polygon
What is a quadrilateral?
A quadrilateral is a shape that has four sides and four angles.
How many sides does a polygon have?
A polygon can have any number of sides, as long as it is a closed shape with straight sides.
How many quadrilaterals are in a polygon?
The number of quadrilaterals in a polygon depends on the number of sides and angles it has. For example, a triangle can only have one quadrilateral, while a hexagon can have six.
What is the formula for finding the number of quadrilaterals in a polygon?
The formula for finding the number of quadrilaterals in a polygon is (n-3)*n, where n is the number of sides in the polygon. This formula works for any regular or irregular polygon.
Can a polygon have more than one quadrilateral?
Yes, a polygon can have multiple quadrilaterals depending on its shape. For example, a decagon (10-sided polygon) can have 10 quadrilaterals.
13K
