Number of hydrogen moles needed to saturate a compound.
In summary, "saturate" in this context refers to the maximum amount of hydrogen atoms that can bond with a compound. The number of hydrogen moles needed to saturate a compound can be calculated by dividing the total number of bonding sites by the valence of hydrogen. This number can provide insight into the compound's reactivity and properties and can vary depending on the compound's size, structure, and external factors. The number of hydrogen moles needed to saturate a compound is not the same as its molecular weight, which is determined by the sum of the atomic weights of all the atoms in the molecule.
Entanglement
439
1. Homework Statement
How[/PLAIN] many moles of hydrogen are needed to saturate this compound?
3[/PLAIN] moles of hydrogen as the benzene ring contains 3 pi bonds.
Is that correct ?
How many H atoms in a mole of hydrogen?
there are 2 moles of hydrogen atoms in one mole of hydrogen molecules.
But, the question is "How many Moles of hydrogen molecules?".
Sorry, I don't understand the implication of your question.
Related to Number of hydrogen moles needed to saturate a compound.
1. What is the definition of "saturate" in this context?
In this context, "saturate" refers to the maximum amount of hydrogen atoms that can bond with a compound. This number is determined by the compound's molecular structure and the availability of bonding sites.
2. How do you calculate the number of hydrogen moles needed to saturate a compound?
The number of hydrogen moles needed to saturate a compound can be calculated by taking the total number of bonding sites in the compound and dividing it by the valence of hydrogen, which is 1.
3. What does the number of hydrogen moles needed to saturate a compound tell us?
This number tells us the maximum number of hydrogen atoms that can bond with a compound. It can also give us insight into the compound's reactivity and properties.
4. Can the number of hydrogen moles needed to saturate a compound vary?
Yes, the number of hydrogen moles needed to saturate a compound can vary depending on the size and molecular structure of the compound. It can also be affected by external factors such as temperature and pressure.
5. Is the number of hydrogen moles needed to saturate a compound the same as its molecular weight?
No, the number of hydrogen moles needed to saturate a compound is not the same as its molecular weight. Molecular weight is the sum of the atomic weights of all the atoms in a molecule, while the number of hydrogen moles needed to saturate a compound is determined by its molecular structure and bonding sites.
9K
