QM & Motion: Is There Consensus?
In summary, the stance of QM on the continuity of motion is not a clear-cut issue. While orthodox QM describes a particle as a continuous wave-function, there is no well-defined trajectory for the particle. The expectation values, however, follow classical laws. The concept of a particle moving continuously or jumping in discrete steps is not an accurate interpretation of QM. QM is a theory of measurements and probabilities, and the key to understanding it is to recognize that measurements are governed by probabilities. There is no consensus on what moves in QM, as the theory deals with measurements rather than physical objects. In the delayed choice quantum eraser experiment, the concept of classicality plays a significant role. Ultimately, in QM, there is
Zelebg
Is there consensus on the stance of QM in regards whether motion is actually continuous or not?
In orthodox QM, a particle is represented by a continuous wave-function. In that sense, the probability that you find a particle at a particular location is a continuous distribution. But, there is no sense in which the particle follows a specific trajectory ##x(t)##, with the position of the particle being well-defined for every time ##t##.
The expectation values, however, do generally follow classical laws. This is Ehrenfest's Theorem. For example:
##\langle p \rangle = m \frac{d \langle x \rangle}{dt}##
This says that the "expected" position of a particle at time ##t## is related to the expected value of its momentum according to the classical formula.
PS If, however, you question was: "does a particle move continuously from A to B, or jump from A to B in a sequence of discrete steps?"; then, neither of these is an accurate interpretation of QM.
Likes bhobba, vanhees71 and Dale
It's a question I had from a long time ago, so I forgot exactly where and what, but some QM descriptions seemed to imply electron would simply appear at point B, sometimes even before disappearing from point A, but in any case would appear at new position without actually traversing the distance.
A free electron is best described as a "wave packet", which corresponds to the probability distribution of the electron's position. The wave packet itself moves with a given velocity. But, it doesn't define a definite position or a definite velocity for the electron at any time. If you measure the velocity of the electron at any time, again you get value taken from the probability distribution.
The key to understanding QM is to understand that the quantities you measure are governed by probabilities. You can only say an electron is at point A if you measure it and find it at point A. You can't measure an electron to be at point A and point B at the same time.
Likes bhobba
Motion of what? This question is just too Big. There is no consensus what moves in qm(knowledge, probabilty, nonlocal fields, nonlocal guiding waves, etc.).
What moves in the delayed choice quantum eraser(a variant of the double slit experiment)?
QM is a theory of measurements via the Born rule - it is slightly more correct to assume motion is non-continuous.
For some profound reason classicality plays a big role in the quantum world, as long as you probe with classical sized devices.
In QM there's nothing noncontinuous. The time evolution is given by a differential equation and thus there cannot be "quantum jumps" in the literal sense.
Related to QM & Motion: Is There Consensus?
1. What is the relationship between quantum mechanics and motion?
Quantum mechanics is a branch of physics that studies the behavior of particles at the atomic and subatomic levels. Motion, on the other hand, refers to the movement of objects in space. The relationship between the two is that quantum mechanics helps explain the behavior of particles in motion, such as their position, velocity, and acceleration.
2. Is there a consensus among scientists about the principles of quantum mechanics and motion?
While there is a general consensus among scientists about the principles of quantum mechanics and motion, there are still ongoing debates and discussions about certain aspects of these concepts. Some scientists may have different interpretations or theories about how they work, but there is agreement on the basic principles.
3. How does quantum mechanics explain the behavior of particles in motion?
Quantum mechanics uses mathematical equations and principles to describe the behavior of particles in motion. It takes into account the wave-like nature of particles and the uncertainty principle, which states that it is impossible to know both the position and momentum of a particle simultaneously.
4. Are there any real-world applications of quantum mechanics and motion?
Yes, there are many real-world applications of quantum mechanics and motion. Some examples include the development of quantum computers, which use the principles of quantum mechanics to perform calculations at a much faster rate than traditional computers. Other applications include medical imaging, GPS technology, and the development of new materials.
5. Can quantum mechanics and motion be applied to larger objects, such as humans?
While quantum mechanics primarily deals with particles at the atomic and subatomic levels, it can also be applied to larger objects, including humans. However, the effects of quantum mechanics on larger objects are not as significant as they are on smaller particles. In most cases, classical mechanics is used to describe the motion of larger objects.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Interpretations and Foundations
  • Quantum Physics
