Root field of x^4+ax^2+b
  • MHB
  • Thread starter Kiwi1
  • Tags
    Field Root
In summary, if \(p(x)=x^4+ax^2+b\) is irreducible in F[x], then \(F[x]/<p(x)>\) is the root field of p(x) over F. This can be proven by forming the extension \(F(c)\) where c is a root of p(x), and showing that it contains all four roots of p(x) through a series of steps. This is done by using the fact that if K is the root field of a polynomial q(x) over F, then any irreducible polynomial p(x) with a root in K must have all of its roots in K.
Kiwi1
108
Prove that if \(p(x)=x^4+ax^2+b\) is irreducible in F[x], then \(F[x]/<p(x)>\) is the root field of p(x) over F.
My Attempt:
1. Let F(c) = \(F[x]/<p(x)>\) where c is a root of p(x). Then F(c) is a degree 4 extension over F because c is the root of a 4th order irreducible polynomial in F[x].
2. \(p(x)=x^4+ax^2+b=(x^2+\frac a2)^2-(\frac{a^2}4-b)\)
Form the extension \(F(d_1)\) where \(d_1,-d_1\) are the roots of \(x^2-[\frac{a^2}4-b]\)
Now the four roots (two each) of \(x^2+\frac a2+d_1\) and \(x^2+\frac a2-d_1\) are the four roots of p(x) in a suitable extension of F.
Let \(d_2\) be a root of \(x^2+\frac a2-d_1\) in \(F(d_1,d_2)\). So \(d_2=\sqrt{d_1-\frac a2}\) and \(\pm d_2\) are two roots of p(x). Also \(d_3=\sqrt{-d_1-\frac a2}\) are two more roots this time in \(F(d_1,d_3)\).
3. \(F(d_1,d_2)\) or \(F(d_1,d_3)\) between them contain the four roots of p(x). Choose the one that contains c. Suppose without loss of generality \(c \in F(d_1,d_2)\).
4. \(c \in F(d_1,d_2)\) so \(F(c) \subseteq F(d_1,d_2)\)
5. \(c=\pm d_2\) so \(d_2 \in F(c)\) so \(d_1=d_2^2 +\frac a2\in F(c)\)
6. \(d_1,d_2 \in F(c)\) so \(F(c) \supseteq F(d_1,d_2)\) and using (4) above \(F(c) = F(d_1,d_2)\)Now all I think I need to do is show that \(\pm d_3 \in F(d_1,d_2)\) and conclude that F(c) is a rootfield of p(x)
Unfortunately this last step has me stumped!
I think I solved it.
I have
"Theorem 7: Let K be the root field of some polynomial q(x) over F. For every irreducible polynomial p(x) in F[x], if p(x) has one root in K, then p(x) must have all of its roots in K."
In my problem I have \(q(x) = (x-d_2)(x+d_2)=x^2-d_2^2=x^2-d_1+\frac a2 \in F(d_1)[x]\)
So \(F(d_1,d_2)\) is the root field of q(x) over \(F(d_1)\). What's more \(c \in F(d_1,d_2)\) so by Theorem 7 all roots of p(x) (which is irreducible in \(F(d_1)\)) must be in \(F(d_1,d_2)=F(c)\)
Related to Root field of x^4+ax^2+b
1. What is the root field of x^4+ax^2+b?
The root field of x^4+ax^2+b is the set of all complex numbers that, when plugged into the equation, result in a value of zero.
2. How do you find the root field of x^4+ax^2+b?
To find the root field of x^4+ax^2+b, you can use the quadratic formula or factor the equation to solve for the roots.
3. Can the root field of x^4+ax^2+b be negative?
Yes, the root field of x^4+ax^2+b can contain negative numbers, as complex numbers can have both real and imaginary components.
4. Are there always four roots in the root field of x^4+ax^2+b?
No, there can be less than four roots in the root field of x^4+ax^2+b. This depends on the values of a and b in the equation.
5. How does the value of a and b affect the root field of x^4+ax^2+b?
The values of a and b can affect the number and type of roots in the root field of x^4+ax^2+b. For example, if a=0 and b>0, there will be two distinct real roots. However, if a<0 and b=0, there will be two imaginary roots.
  • Computing and Technology
  • Linear and Abstract Algebra
