Scattering Amplitude for a given potential
In summary, the equation above tells us that the scattering amplitude (a measure of how much a particle is scattered) is inversely proportional to the energies of the states involved in the interaction.
Sekonda
207
Hello again,
My question is on determining the scattering amplitude via time-dependent perturbation theory (first-order) for a given potential - I believe the perturbation potential is modeled due to some interaction between two scalar particles and has form:
[tex]\delta V=\lambda \Phi_{f'}^{*}\Phi_{i'}[/tex]
Where I believe the i' state is the initial state of some incoming particle which interacts with another particle in a state i, then both particles rebound into states f' and f respectively. I believe we use an equation of the following form to determine the scattering amplitude (provided that they are much less than 1):
[tex]a_{f}(t)=\frac{i}{2E_{f}}\int dt\int d^3x\Phi_{f}^{*}\delta V\Phi_{i}[/tex]
where I am assuming plane wave solutions to each wave equation, so they have following form where the N's are normalization constants.
[tex]\Phi_{i}=N_{1}e^{-E_{i}t+i\mathbf{p}_{i}\cdot \mathbf{x}}\; ,\; \Phi_{i'}=N_{3}e^{-E_{i'}t+i\mathbf{p}_{i'}\cdot \mathbf{x}}[/tex]
[tex]\Phi_{f}^{*}=N_{2}e^{E_{f}t-i\mathbf{p}_{f}\cdot \mathbf{x}}\; ,\; \Phi_{f'}^{*}=N_{4}e^{E_{f'}t-i\mathbf{p}_{f'}\cdot \mathbf{x}}[/tex]
So I have then substituted these into my scattering amplitude equation to attain:
[tex]a_{f}(t)=\frac{i\lambda}{2E_{f}}N_{1}N_{2}N_{3}N_{4}\int dt\: e^{i(E_{f}+E_{f'}-E_{i}-E_{i'})t}\int d^3x\: e^{-i(\mathbf{p}_f+\mathbf{p}_{f'}-\mathbf{p}_i-\mathbf{p}_{i'})\cdot \mathbf{x}}[/tex]
Now, I think if I have done this correctly, then the integral of the exponential with respect to time becomes a delta function describing conservation of energy of the interaction such that:
[tex]\int_{-\infty}^{\infty} dt\: e^{i(E_{f}+E_{f'}-E_{i}-E_{i'})t}=2\pi\delta(E_f+E_{f'}-E_i-E_{i'})[/tex]
I think the integral with respects to 'x' does something similar, can someone help me out with this integral?
Thanks guys!
SK
Actually is this correct?
[tex](2\pi)^3\delta^3(\mathbf{p}_i+\mathbf{p}_{i'}-\mathbf{p}_f-\mathbf{p}_{f'})=\int d^3x\: e^{-i(\mathbf{p}_f+\mathbf{p}_{f'}-\mathbf{p}_i-\mathbf{p}_{i'})\cdot \mathbf{x}}[/tex]
Essentially enforcing conservation of momentum as well?
yes,it is definitely correct.
Cheers man!
Thanks,
SK
I have attained a scattering amplitude of form:
[tex]\frac{i\lambda(2\pi)^4N_1N_2N_3N_4}{2(E_i+E_{i'}-E_{f'})}[/tex]
from the above, what does this tell me about the interaction? I think we should expect scattering amplitudes much less than 1 though I'm not sure how this equation shows it.
It seems that all I can say for this scattering amplitude solution is that the scattering of some particle from states i to f by some other particle scattering from states i' to f' is inversely proportional to the energy of state f or the the energies i+i'-f', so that the scattering is not only dependent on one state of the scattered particle f but also on the energy states of all other particle states involved in the interaction.
Is there anything else this equation says?
this is not the way you should do it.you have turned the amplitude into energy denominator form.You should retain those 4 delta functions(momentum+energy) and the absolute square of it shows the probability type thing.The delta function is treated after it.You can see some books lke feynman 'quantum electrodynamics' on how to treat it.you should draw some conclusion from absolute square of it rather than from amplitude itself(other than some analyticity,unitarity etc.)
Ahh I see what you mean, I may have been doing this calculation incorrectly but I understand what you are saying and it still applies. Thanks Andrien!
Related to Scattering Amplitude for a given potential
1. What is the scattering amplitude for a given potential?
The scattering amplitude for a given potential is a measure of the probability of a particle to scatter off of a potential. It describes the likelihood of a particle to scatter in a certain direction after interacting with a potential.
2. How is the scattering amplitude related to the potential?
The scattering amplitude is directly related to the potential through the Schrödinger equation. The potential is used to solve the Schrödinger equation and obtain the scattering amplitude as a solution.
3. Can the scattering amplitude be calculated for any potential?
Yes, the scattering amplitude can be calculated for any potential as long as it is solvable with the Schrödinger equation. However, for some complex potentials, the calculation may be more difficult and require numerical methods.
4. What information can we obtain from the scattering amplitude?
The scattering amplitude provides information about the scattering process, such as the scattering cross section, which is a measure of the probability of a particle to scatter in a particular direction. It also gives information about the energy and momentum transfer between the scattered particle and the potential.
5. How does the scattering amplitude change with different potentials?
The scattering amplitude can vary significantly for different potentials. It depends on the strength and shape of the potential as well as the energy of the particle. In general, a stronger potential will result in a larger scattering amplitude. Additionally, some potentials may have resonances, which can greatly affect the scattering amplitude.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Classical Physics
