Spacecraft reactor sheilding and heat radiators
In summary, the conversation discusses the design of a nuclear-powered spacecraft and the placement of shielding and radiator panels. The participants mention different sources for more realistic designs and suggest that placing the shield close to the habitat section would be more effective at stopping radiation.
Jeremy Thomson
I've been watching "The Expanse" and considered, if the spaceships are some sort of fusion powered drive, why aren't they covered in radiator panels to reject all the heat from the reactor/drive system? How many square meters of radiator panels would a 20MW (thermal) fission reactor require?
An idea for the overall design of a nuclear powered spacecraft is to have the habitable section in the nose, a looooong truss section (100s of metres) back to the reactor and rocket. This distance reduces the radiation the crew receives by some cubic function of the distance? Is is better to put the shielding right behind the habitable section or right in front of the reactor, or doesn't it matter?
My guess is that it would be better to have the shield close to the habitat section.
There, it has less amount of radioactivity to deal with, so is more effective at stopping what there is.
Because the people writing the script thinks the current designs look cooler. For more realistic designs look for instance at the computer game "Children of a Dead Earth", the film 2001 or the board game "Attack Vector: Tactical".
When it comes information on realistic Science Fiction radiators, atomic rockets got you covered http://www.projectrho.com/public_html/rocket/basicdesign.php#radiators
Shielding from neutrons and most other radiation don't behave that way. X meters of shielding absorbs 50% of the radiation. You want it close to the reactor so that it can be made as thick as required with the smallest diameter possible.
Related to Spacecraft reactor sheilding and heat radiators
1. What is the purpose of spacecraft reactor shielding?
The purpose of spacecraft reactor shielding is to protect the spacecraft and its crew from harmful radiation emitted by the nuclear reactor. This shielding is necessary for the safety and functionality of the spacecraft during long-term space missions.
2. How does spacecraft reactor shielding work?
Spacecraft reactor shielding works by using materials with high atomic numbers, such as lead or tungsten, to absorb and deflect radiation. The shielding is designed to create a barrier between the reactor and the rest of the spacecraft, reducing the amount of radiation that reaches the crew and equipment.
3. What materials are commonly used for spacecraft reactor shielding?
Lead, tungsten, and polyethylene are some of the most commonly used materials for spacecraft reactor shielding. These materials have high atomic numbers and are effective at absorbing and deflecting radiation.
4. Why are heat radiators necessary for spacecraft?
Heat radiators are necessary for spacecraft because they help dissipate excess heat generated by the reactor. In space, there is no medium for heat to transfer through, so radiators are used to release the heat into the surrounding vacuum.
5. How are heat radiators designed for use on spacecraft?
Heat radiators for spacecraft are designed to be lightweight and durable, as well as provide efficient heat dissipation. They often use a series of tubes or fins to increase surface area for heat transfer and may also utilize specialized coatings or materials to help with heat absorption and emission.
  • Science Fiction and Fantasy Media
  • Nuclear Engineering
15K
