Sum to Infinity of a Geometric Series
In summary, the given conversation discusses finding the sum to infinity of a series in terms of x. The solution involves using the formula S\infty = \frac{a}{1 - r}, where a = 1 and r = \frac{2x}{x + 1}. By simplifying the equation, the final answer is \frac{x + 1}{1 - x}.
odolwa99
85
Q. Find, in terms of x, the sum to infinity of the series...
1 + [itex](\frac{2x}{x + 1})[/itex] + [itex](\frac{2x}{x + 1})^2[/itex] + ...
S[itex]\infty[/itex] = [itex]\frac{a}{1 - r}[/itex]
a = 1
r = U2/ U1 = [itex](\frac{2x}{x + 1})[/itex]/ 1 = [itex]\frac{2x}{x + 1}[/itex]
[itex]\frac{1}{1 - (2x/ x + 1)}[/itex]
[itex]\frac{x + 1}{1 - 2x}[/itex]
Ans.: From textbook: [itex]\frac{x + 1}{1 - x}[/itex]
Can anyone help me figure out where the 2x becomes just x? Thank you.
If you take
[tex]\frac{1}{x-\frac{2x}{x+1}} \times \frac{x+1}{x+1}[/tex]
you will get
[tex]\frac{x+1}{1(x+1)-2x}[/tex]
Which simplifies to the answer you want.
Thanks for clearing that up. I appreciate the help.
Related to Sum to Infinity of a Geometric Series
1. What is a geometric series?
A geometric series is a sequence of numbers where each term is multiplied by a constant ratio to get the next term. For example, 1, 2, 4, 8, 16, ... is a geometric series with a common ratio of 2.
2. What is the formula for finding the sum of a geometric series?
The formula for finding the sum of a geometric series is S = a/(1-r), where S is the sum, a is the first term, and r is the common ratio. This formula is valid when the absolute value of r is less than 1.
3. How do you know if a geometric series converges or diverges?
A geometric series will converge if the absolute value of the common ratio is less than 1. If the absolute value of the common ratio is equal to or greater than 1, the series will diverge.
4. Can a geometric series have a negative common ratio?
Yes, a geometric series can have a negative common ratio. This will result in alternating positive and negative terms in the series.
5. How can the sum of a geometric series be used in real life?
The sum of a geometric series can be used in various real-life applications, such as calculating compound interest, population growth, or the total distance traveled in a series of movements with a constant ratio. It can also be used in geometric construction and in the calculation of fractals.
