The speed of a spaceship flying through dust
In summary: The exponential decay in this case is due to the mass of the ship increasing over time, not due to the dust particles increasing over time.
Haorong Wu
413
89
A spaceship is flying through dust. The density of dust is ##\rho##. Suppose the mass of the ship is ##m_0##, and its initial speed is ##v_0##. Since the dust will attach to the spaceship when it flies through it, the speed of the spaceship would change. Suppose the intersection of the ship is a cylinder with area of ##S##, and the ship is flying along the axis of the cylinder, and all dust it passes through would attach to it. Calculate the relation between the speed of the spaceship and time.
None
The given solution is:
Suppose after time ##dt##, the mass of the ship would increase ##dm##, and the speed would become ##v_0 - dv##.
According to the conservation of momentum, ##\left ( m_0 + dm \right ) \left ( v_0 - dv \right ) = m_0 v_0##.
Omiting ##dm \cdot dv##, we got ##v_0 dm -m_0 dv =0##.
According to the problem, ##dm=\rho S v dt##, so##\int_0^t \rho S v_0 dt = \int_{v_0}^v m_0 \frac {dv} v##
Thus, the result is ##v=v_0 e^{\frac {\rho S v_0 t} {m_0}}##
However, I could not agree this solution, and my solotion is:
Suppose at time t, the mass of the ship is ##m##, and its speed is ##v##.
Also, suppose after time ##dt##, the mass of the ship increases ##dm=\rho S v dt##, so ##\frac {dm} {dt}= v s \rho##.
Then according to the conservation of momentum, ##mv=m_0 v_0##, or ##m=\frac {m_0 v_0} {v}##
Then differentiate it with t, it becomes ##\frac {dm} {dt}= \frac {-m_0 v_0} {v^2} \frac {dv} {dt}##
Substituting ##\frac {dm} {dt}##, then ##v s \rho= \frac {-m_0 v_0} {v^2} \frac {dv} {dt}##
Integrating again, then ##t=\frac {m_0 v_0} {s \rho v^2} +c##. According to the initial conditions, ##c=- \frac {m_0} {s \rho v_0}##.
so ##v= \sqrt {\frac {m_0 {v_0}^2} {m_0+ s \rho v_0 t}} ##
So which one is correct? it seems a exponential decay would be more convincing.
Thanks!
Likes PeroK
Haorong Wu said:
Homework Statement: A spaceship is flying through dust. The density of dust is ##\rho##. Suppose the mass of the ship is ##m_0##, and its initial speed is ##v_0##. Since the dust will attach to the spaceship when it flies through it, the speed of the spaceship would change. Suppose the intersection of the ship is a cylinder with area of ##S##, and the ship is flying along the axis of the cylinder, and all dust it passes through would attach to it. Calculate the relation between the speed of the spaceship and time.
Homework Equations: None
Thanks!
The given solution doesn't look right. It uses ##m_0## in the differential equation, but that should be ##m##.
Your solution looks correct to me.
Thanks, I found that the given solution is exponential increasing which is absurd.
PS here's why it is NOT a negative exponential solution.
An exponential solution arises from ##\frac{dv}{dt} = kv##. I.e. the acceleration must be proportional to the velocity. In this problem, as the velocity reduces, the amount of dust per second reduces in proportion. So, if the mass of the ship stayed the same, then the reduction in velocity would be proportional to the velocity. But, the ship is also gaining mass, which means its velocity is less affected by the dust over time. This means it must be slower than exponential.
First of all, please do not put the solutions in quotes, it makes it impossible to use the quote feature to quote them.
The given solution is wrong for several reasons reasons. First of all, the original assumption should be ##(m+dm)(v+dv)= m_0 v_0## in order to be valid at all times. Otherwise it is only valid at t=0. Also note the difference in the sign of dv. This change is crucial as it will make dv negative when v decreases and vice versa. If you use a negative sign you will not get v when you integrate dv! This is reflected in the given solution (which does this mistake) having an exponentially increasing solution, which is clearly unphysical.
Noting that ##mv = m_0 v_0## should then give you the same relation as you derived from differentiating that.
Related to The speed of a spaceship flying through dust
1. What is the speed of a spaceship flying through dust?
The speed of a spaceship flying through dust can vary greatly depending on several factors such as the size and density of the dust particles, the velocity of the spaceship, and the composition and density of the surrounding medium. Therefore, it is difficult to determine a specific speed without knowing these variables.
2. How does the speed of a spaceship affect its interaction with dust particles?
The speed of a spaceship can greatly affect its interaction with dust particles. At lower speeds, the spaceship may simply push the dust particles aside, while at higher speeds, the particles can cause damage to the spaceship's exterior. Additionally, the speed can also determine the amount of dust that accumulates on the spaceship's surface.
3. Can a spaceship travel faster than the speed of dust particles?
Yes, a spaceship can travel faster than the speed of dust particles. This is because the speed of dust particles is limited by the medium in which they are traveling, while a spaceship can travel through different mediums and even in a vacuum, allowing it to achieve higher speeds.
4. How does the shape of a spaceship affect its speed through dust?
The shape of a spaceship can greatly affect its speed through dust. A streamlined and aerodynamic shape can reduce the resistance and drag caused by dust particles, allowing the spaceship to achieve higher speeds. On the other hand, a bulkier and less streamlined shape can slow down the spaceship and increase its interaction with dust particles.
5. What measures can be taken to reduce the impact of dust on a spaceship's speed?
To reduce the impact of dust on a spaceship's speed, several measures can be taken. These include designing a streamlined and aerodynamic shape, using materials that are resistant to dust and debris, and implementing a system to periodically clean the spaceship's exterior. Additionally, avoiding areas with high dust concentrations can also help maintain a consistent speed for the spaceship.
