What is the Correct Formula for Calculating Vapour Pressure of Solutions?
In summary, the formula to be applied for finding the total vapor pressure of a mixed solution is ##P= \chi_{solvent}P^o _{solvent}##, where ##P^o _{solvent}## is the vapor pressure of the pure solvent and ##\chi_{solvent}= \frac{mol_{solvent}}{mol_{solvent}+mol_{solute}}##. This formula takes into account the fraction of solute in the solution and can be used to calculate the expected vapor pressure. Neglecting the presence of a volatile solute, such as methanol, can lead to incorrect results. Therefore, it is important to consider all components in the solution when using this formula.
DottZakapa
239
Calculate the vapour pressure at 21.0°C of an ideal solution of water and methanol (CH3OH, P°=100 mmHg at 21.0°C) that contains 9.0 mol of water and 0,50 mol of methanol. Vapour pressure of water at 21.0°C is 18.7mmHg.
Solutions
Isn't the formula to be applied ##P= \chi_{solvent}P^o _{solvent}##?
in which ##P^o _{solvent}##= 18.7mmHg and
##\chi_{solvent}= \frac{mol_{solvent}}{mol_{solvent}+mol_{solute}}=\frac{9.0 mol}{9.0 mol+0,50 mol}##
but seems doesn't leads to the expected result
Hi,
Very unlikely: the pressure would be independent on the fraction solute ?
You seem to be on the right track. I think this will help:
"When two or more volatile solutions are mixed, each pressure component of the mixed solution is added together to find the total vapor pressure.
PTotal = Psolution A + Psolution B + ..."
source: https://www.thoughtco.com/raoults-law-with-volatile-solutions-609525
BvU said:
Hi,
On the contrary, vapor pressure does depend on the fraction of the solute. Vapor pressure lowering is one of the four colligative properties that one has real-life experience with. For example, salt water boils at a higher temperature than pure water because salt water's vapor pressure equals 1 ATM at a higher temperature. :)
Link: https://www.chem.fsu.edu/chemlab/chm1046course/colligative.html
You are:
1. missing the point of BvU's post
2. posting unrelated info (problem has nothing to do with colligative properties)
3. confusing OP (your post on Raoult's law was pointing in the right direction, now you are derailing)
None of that is helpful.
Likes Chestermiller
ok, i was neglecting the methanol, basically i was considering it as non volatile solute, in that case I should not consider it, but here it must be taken into account. thanks
Likes BvU
Related to What is the Correct Formula for Calculating Vapour Pressure of Solutions?
1. What is a solution?
A solution is a homogeneous mixture of two or more substances, where one substance is dissolved in another. The substance that is present in a larger amount is called the solvent, while the substance that is present in a smaller amount is called the solute.
2. How does a solution affect vapour pressure?
A solution affects vapour pressure by lowering it. This is because the presence of the solute particles interferes with the evaporation of the solvent molecules, making it more difficult for them to escape into the gas phase.
3. What is the relationship between concentration and vapour pressure?
The relationship between concentration and vapour pressure is inversely proportional. As the concentration of a solution increases, the vapour pressure decreases. This is because a higher concentration means more solute particles, which leads to a greater decrease in vapour pressure.
4. How does temperature affect vapour pressure in a solution?
Temperature has a direct effect on vapour pressure in a solution. As temperature increases, the vapour pressure also increases. This is because at higher temperatures, more solvent molecules have enough energy to overcome the intermolecular forces and escape into the gas phase.
5. What is the significance of vapour pressure in solutions?
Vapour pressure is an important property of solutions as it affects many physical processes such as boiling point, freezing point, and evaporation. It also plays a crucial role in determining the rate of reactions in solution, as well as the solubility of gases in liquids.
  • Atomic and Condensed Matter
