Why membrane for distillation has to be hydrophobic
In summary, the conversation discusses the use of membrane distillation and its characteristics. It is stated that the membrane should be porous and hydrophobic, but it is questioned whether a hydrophilic membrane can also be used. It is explained that the hydrophobic nature of the membrane prevents liquid water from entering the pores due to its high surface tension. This is known as capillary action and is essential for membrane distillation to work.
Yinxiao Li
46
I have a question about membrane distillation. I have read the following from a review paper about membrane distillation: The membrane distillation should be applied for membrane operations having the following characteristics:
- The membrane should be porous.
- The membrane should not be wetted by the process liquids.
In other words, this membrane has to be hydrophobic. However, I don't think the membrane distillation has to be hydrophobic, except for direct contact membrane distillation...A hydrophilic membrane can be applied to air gas MD, sweeping gas MD and vacuum MD, correct? Or there is any reason that hydrophilic membrane won't work.
It seems to me that if the membrane were hydrophilic, it would allow (in fact, encourage) the liquid water to creep by capillary action (due to liquid water's surface tension) through the pores. Hydophobia is what holds the liquid back, even when the pores are considerably larger than the molecules.
As water has strong dipole characteristics, whilst the membrane fabric is non-polar, the membrane material is not wetted by the liquid. Even though the pores are considerably larger than the molecules, the liquid phase does not enter the pores because of the high water surface tension. A convex meniscus develops into the pore. This effect is named capillary action.
https://en.wikipedia.org/wiki/Membrane_distillation#Principle_of_membrane_distillation
Not bad, I think, for someone who had never even heard of membrane distillation until five minutes ago?
Related to Why membrane for distillation has to be hydrophobic
1. Why does the membrane for distillation have to be hydrophobic?
The membrane for distillation needs to be hydrophobic because it allows for the separation of two liquids with different boiling points. A hydrophobic membrane repels water molecules and allows the vapor from the lower boiling point liquid to pass through, while blocking the higher boiling point liquid.
2. What happens if the membrane for distillation is not hydrophobic?
If the membrane for distillation is not hydrophobic, it will be unable to effectively separate the two liquids. This is because a hydrophilic membrane would allow both liquids to pass through, resulting in a mixture rather than a separation.
3. Can any type of hydrophobic material be used as a membrane for distillation?
No, not all hydrophobic materials are suitable for use as a membrane for distillation. The material must also have a high permeability to allow for the passage of vapor molecules while blocking liquid molecules.
4. What are the advantages of using a hydrophobic membrane for distillation?
One of the main advantages of using a hydrophobic membrane for distillation is its ability to selectively separate liquids with different boiling points. This method also requires less energy compared to other separation techniques, making it more cost-effective.
5. Are there any drawbacks to using a hydrophobic membrane for distillation?
One potential drawback of using a hydrophobic membrane for distillation is that it may become fouled or clogged over time, reducing its efficiency. This can be mitigated by proper maintenance and cleaning of the membrane.
  • Atomic and Condensed Matter
  • Mechanical Engineering
12K
19K
  • Classical Physics
  • Materials and Chemical Engineering
