Why metals more dense than semiconductors?
In summary: Not all metals have greater density than semiconductors, Si (2.330 g/cc) and Ge (5.323 g/cc). The group 1 and most 2 elements have lower density than Ge, several have lower density than Si.
ziadett
this question was in my material science exam .
by the way I'm not very good at this subject
See - http://www.webelements.com/webelements/properties/text/image-balls/density.html
Besides increasing atomic mass, the crystal structure determines the density, i.e. the lattice parameters or interatomic spacing.
Si: Space group: Fd-3m (Space group number: 227)
http://www.webelements.com/webelements/elements/text/Si/xtal.html
Structure: diamond
Cell parameters:
a: 543.09 pm
b: 543.09 pm
c: 543.09 pm
Ge: Space group: Fm-3m (Space group number: 225)
http://www.webelements.com/webelements/elements/text/Ge/xtal.html
Structure: ccp (cubic close-packed)
Cell parameters:
a: 565.75 pm
b: 565.75 pm
c: 565.75 pm
Fe: Space group: Im-3m (Space group number: 229)
Structure: bcc (body-centred cubic)
Cell parameters:
a: 286.65 pm
b: 286.65 pm
c: 286.65 pm
Ni:Space group: Fm3m (Space group number: 225)
Cell parameters:
a: 352.4 pm
b: 352.4 pm
c: 352.4 pm
Look at crystal structures -
http://www.webelements.com/webelements/elements/text/periodic-table/xtal.html
Click on particular element in table to see crystallographic information.
A general quick and dirty formula
Consider the equation for the density:
[tex]\rho=\frac{An}{N_AZ}[/tex]
Where
[tex]\rho[/tex] = the density
n = the density of electrons in the conduction band
A = atomic mass, consider this to be a constant
[tex]N_A[/tex]= Avogadro´s number
Z = valence, consider this to be a constant.
The key is n, the density of electrons in the conduction band. For metals, this is much larger than for semiconductors. In fact that´s the main difference between semiconductors and metals.
I´ll admit this is not a very satisfactory way of doing it, but I really think this is what they´re looking for. This equation allows you to compare metals and semiconductors on the same level since the atomic mass, valence and in a way, the cell structure are constants.
Now if you wanted to go further you run into problems because elemental semiconductors tend to form covalent bonds which are very directional bonds. Thus you would be forced to consider the cell structure. But in the process, you would loose the generality since metals don´t generally have the same cell structure as semiconductors. As the previous post demonstrates you begin to compare apples to oranges.
Where did you find this equation ?
It certainly looks like you are applying it beyond its range of applicability.
By your analysis, if the density is proportional to n, then metals should be many, many orders of mangitude more dense than insulators - that you would see the same range of magnitudes in density as you see in electrical conductivity. This is certainly not true !
In fact, the statement that metals are more dense than semiconductors itself is fallacious in the absence of further clarification.
Related to Why metals more dense than semiconductors?
1. Why are metals more dense than semiconductors?
Metals are more dense than semiconductors because of the way their atoms are arranged. In metals, the atoms are closely packed together in a regular lattice structure. This results in a higher number of atoms per unit volume, leading to a higher density. In contrast, semiconductors have a less orderly arrangement of atoms, resulting in a lower density.
2. Is the density of a metal related to its conductivity?
Yes, the density of a metal is closely related to its conductivity. Metals have a high number of free electrons that are able to move easily through the material, making them good conductors of electricity. The higher the density of a metal, the more closely packed the atoms are, allowing for a greater number of free electrons and therefore, higher conductivity.
3. How does the density of a metal affect its physical properties?
The density of a metal can affect its physical properties in various ways. For example, metals with higher density tend to be stronger and more durable, making them suitable for use in structural applications. Additionally, higher density metals also tend to have higher melting points and are more resistant to corrosion.
4. Are there any exceptions to the rule that metals are more dense than semiconductors?
Yes, there are some exceptions to this rule. Some semiconductors, such as germanium and silicon, have densities that are comparable to certain metals. This is because these semiconductors have a crystalline structure similar to that of metals. However, in general, metals still tend to have higher densities than semiconductors.
5. How does the density of a metal affect its electronic properties?
The density of a metal can have a significant impact on its electronic properties. As mentioned earlier, metals with higher densities tend to have more free electrons, making them good conductors of electricity. In contrast, semiconductors have a lower density and therefore, a lower number of free electrons, resulting in lower conductivity. The density also affects the band structure of a metal, which can influence its optical and thermal properties.
  • Atomic and Condensed Matter
