How to Enter Physics Graduate School From Another Major
Full Chapter List - So You Want To Be A Physicist... Series
Part I: Early Physics Education in High schools
Part II: Surviving the First Year of College
Part III: Mathematical Preparations
Part IV: The Life of a Physics Major
Part V: Applying for Graduate School
Part VI: What to Expect from Graduate School Before You Get There
Part VII: The US Graduate School System
Part VIII: Alternative Careers for a Physics Grad
Part VIIIa: Entering Physics Graduate School From Another Major
Part IX: First years of Graduate School from Being a TA to the Graduate Exams
Part X: Choosing a Research area and an advisor
Part XI: Initiating Research Work
Part XII: Research work and The Lab Book
Part XIII: Publishing in a Physics Journal
Part XIV: Oral Presentations
Part XIII: Publishing in a Physics Journal (Addendum)
Part XIV: Oral Presentations – Addendum
Part XV – Writing Your Doctoral Thesis/Desertation
Part XVI – Your Thesis Defense
Part XVII – Getting a Job!
Part XVIII – Postdoctoral Position
Part XIX – Your Curriculum Vitae
I have decided to tackle this issue because it has become a very common question in many physics forums. Can someone, without a degree in physics, get accepted and succeed in physics graduate school to obtain a Ph.D?
This question cannot be answered easily, because it depends on (i) your major and (ii) what physics and mathematics classes you took as an undergraduate. Students majoring in, say electrical engineering, engineering mechanics, mathematics, applied mathematics, etc. will have an easier path to going into physics than, say, students who majored in economics, music, etc., mainly because of the many overlaps in courses that one took as an undergraduate.
Still, I think that there is a concrete way to determine how well-prepared you are in going into a physics graduate program. This is something you can do yourself as a first level of self-evaluation on whether you are well-equipped to enter such a program, or if you lack some necessary knowledge to complete it successfully.
1. Get a copy of a GRE Physics Subject test. Now try to do the test yourself. If you did not score 75% or better, you lack the necessary preparation to go into a physics graduate school
2. If you have a school that you already have in mind where you might want to apply, get a copy of the previous year’s qualifying exams (more on the qualifying exams in Part IX of this essay). You don’t even have to do the exam. Just read it, and see if you understand what it is asking, and what you will need to be able to solve it. If you find that there are questions that go over your head, and you don’t know where to look for the way to start solving them, you immediately lack the necessary preparation to go into a physics graduate school.
These are concrete, self-evaluations that you can test on yourself. The GRE self-test should test a wide variety of physics knowledge that a typical physics undergraduate should have by the time he/she graduates. This allows you to compare your knowledge to such a group of students. 75th percentile score isn’t that high, but in this self-test, you get to use as much time as you need, and may even need to refer to physics textbooks to help you with your test (something you can’t do in an actual GRE test). I consider knowing where to look for help as an indication that a student isn’t clueless.
The qualifying exam self-test is more school-specific. This is the standard of knowledge that a particular school would want their graduate candidates to have, so the questions tend to be more difficult, and it isn’t a multiple-choice exam. Here, I merely wanted you to see if you can understand what is being asked, and then know a way to solve it, without actually having to solve it. Most physics students can understand the question, and have an idea of how to solve it. The process of solving the question itself may not be trivial (usually, it isn’t!), but knowing a way to do it is a major indication that a student has the necessary knowledge. So if you encounter anything here that makes no sense to you, and you also are clueless in figuring out a way to solve it, then you lack the necessary preparation.
The thing here is that, depending on where you intend to apply and your educational background, getting accepted into a physics graduate program isn’t the biggest issue, especially if you’re paying the full tuition and fees yourself. With an engineering degree/computer science/math degree and a GAP of 3.0 or better, you can find schools that might accept you into their program. The question is, can you survive in the program and ultimately, get to your goal of receiving your Ph.D? It would be a waste of time (and financial resources if you’re paying full fare) if you get snagged in the qualifying exams because you were not sufficiently prepared.
Suppose you don’t think you are sufficiently prepared. In that case, you need to evaluate whether you should apply to a school, and then spend maybe a year, or even two, in advanced undergraduate courses to get you up-to-speed and prepare you for the qualifying exams. Many schools will allow you to do this. This evaluation will depend on your current educational background. I would say that engineering and math majors will have the advantage of not needing too many courses to get them up and running. If you come from a non-science, non-technical background, you may want to consider how far up a hole you’re willing to climb to achieve your goal.
Using the two self-tests that I mentioned above will give you a concrete evaluation of your knowledge to survive a physics graduate program.
PhD Physics
Accelerator physics, photocathodes, field-enhancement. tunneling spectroscopy, superconductivity
"If you come from a non-science, non-technical background, you may want to consider how far up a hole you’re willing to climb to achieve your goal."
Reference https://www.physicsforums.com/insights/entering-physics-graduate-school-from-another-major/
Yes! I graduated in 2014, as a non-trad, with an English degree. Since then, I've been setting my sights on obtaining a physics degree and becoming a physicist. However, the highest level of math I had under my belt was Pre-cal which I took as an elective for my English degree; my only science was an intro to chem course. So, I decided to see just how practical it would be to accomplish should I embark on such an adventure.
Firstly, I didn't know where to start, but after a few google searches, I found PF. Utilizing the free textbooks and homework sections, as well as Insights articles and the various posts of encouragement and discussions throughout the forum, I started with Calculus. Self-teaching calculus is difficult enough and doing it while working multiple jobs is even harder, so I applied for and landed an entry-level job at the state university to take advantage of a tuition reimbursement benefit they allowed for staff. I enrolled in Calc. I in the spring of 2017 and ended up with an A. From there I've taken some online physics and engineering courses while maintaining a self-study habit.
I still have a long way to go, but, at 33 years old, I've been accepted for 2nd Bachelor's in Physics for Fall 2018.
Great essay. I have a BS in aerospace engineering (minored in physics), and a MS in astronautical engineering. I’ve been studying for the physics GRE and plan to take it this winter. My question is: What (dis)advantage would I have in applying to a big physics school (MIT, CalTech, Stanford, Princeton, etc.) to pursue my PhD soley in terms of acceptance? In general, would the selection committee see my background and want to accept me, just to bring in diversity, or would they shun me since I don’t not have a Physics BS?
Another classic from @zapperz!
