spacetime5
Struggles with the Continuum: Quantum Electrodynamics
Common Topics: charge, particles, mass, feynman, electron
Quantum field theory is the best method we have for describing particles and forces in a way that takes both quantum mechanics and special relativity into account. It makes many wonderfully accurate predictions. And yet, it has embroiled physics in some remarkable problems: struggles with infinities!
I want to sketch some of the key issues in the case of quantum electrodynamics, or ‘QED’. The history of QED has been nicely told here:
• Silvian Schweber, QED and the Men who Made it: Dyson, Feynman, Schwinger, and Tomonaga, Princeton U. Press, Princeton, 1994.
Instead of explaining the history, I will give a very simplified account of the current state of the subject. I hope that experts forgive me for cutting corners and trying to get across the basic ideas at the expense of many technical details. The nonexpert is encouraged to fill in the gaps with the help of some textbooks.
QED involves just one dimensionless parameter, the fine structure constant:
$$ \alpha = \frac{1}{4 \pi \epsilon_0} \frac{e^2}{\hbar c} \approx \frac{1}{137.036} . $$
Here ##e## is the electron charge, ##\epsilon_0## is the permittivity of the vacuum, ##\hbar## is Planck’s constant and ##c## is the speed of light. We can think of ##\alpha^{1/2}## as a dimensionless version of the electron charge. It says how strongly electrons and photons interact.
Nobody knows why the fine structure constant has the value it does! In computations, we are free to treat it as an adjustable parameter. If we set it to zero, quantum electrodynamics reduces to a free theory, where photons and electrons do not interact with each other. A standard strategy in QED is to take advantage of the fact that the fine structure constant is small and expand answers to physical questions as power series in ##\alpha^{1/2}##. This is called ‘perturbation theory’, and it allows us to exploit our knowledge of free theories.
One of the main questions we try to answer in QED is this: if we start with some particles with specified energy-momenta in the distant past, what is the probability that they will turn into certain other particles with certain other energy-momenta in the distant future? As usual, we compute this probability by first computing a complex amplitude and then taking the square of its absolute value. The amplitude, in turn, is computed as a power series in ##\alpha^{1/2}##.
The term of order ##\alpha^{n/2}## in this power series is a sum over Feynman diagrams with ##n## vertices. For example, suppose we are computing the amplitude for two electrons wth some specified energy-momenta to interact and become two electrons with some other energy-momenta. One Feynman diagram appearing in the answer is this:
photon_exchange
Here the electrons exchange a single photon. Since this diagram has two vertices, it contributes a term of order ##\alpha##. The electrons could also exchange two photons:
2-photon_exchange
giving a term of ##\alpha^2##. A more interesting term of order ##\alpha^2## is this:
photon_exchange_with_virtual_pair
Here the electrons exchange a photon that splits into an electron-positron pair and then recombines. There are infinitely many diagrams with two electrons coming in and two going out. However, there are only finitely many with ##n## vertices. Each of these contributes a term proportional to ##\alpha^{n/2}## to the amplitude.
In general, the external edges of these diagrams correspond to the experimentally observed particles coming in and going out. The internal edges correspond to ‘virtual particles’: that is, particles that are not directly seen but appear in intermediate steps of a process.
Each of these diagrams is actually a notation for an integral! There are systematic rules for writing down the integral starting from the Feynman diagram. To do this, we first label each edge of the Feynman diagram with an energy-momentum, a variable ##p \in \mathbb{R}^4##. The integrand, which we shall not describe here, is a function of all these energy-momenta. In carrying out the integral, the energy-momenta of the external edges are held fixed, since these correspond to the experimentally observed particles coming in and going out. We integrate over the energy-momenta of the internal edges, which correspond to virtual particles while requiring that energy-momentum is conserved at each vertex.
However, there is a problem: the integral typically diverges! Whenever a Feynman diagram contains a loop, the energy-momenta of the virtual particles in this loop can be arbitrarily large. Thus, we are integrating over an infinite region. In principle, the integral could still converge if the integrand goes to zero fast enough. However, we rarely have such luck.
What does this mean, physically? It means that if we allow virtual particles with arbitrarily large energy-momenta in intermediate steps of a process, there are ‘too many ways for this process to occur’, so the amplitude for this process diverges.
Ultimately, the continuum nature of spacetime is to blame. In quantum mechanics, particles with large momenta are the same as waves with short wavelengths. Allowing light with arbitrarily short wavelengths created the ultraviolet catastrophe in classical electromagnetism. Quantum electromagnetism averted that catastrophe — but the problem returns in a different form as soon as we study the interaction of photons and charged particles.
Luckily, there is a strategy for tackling this problem. The integrals for Feynman diagrams become well-defined if we impose a ‘cutoff’, integrating only over energy-momenta ##p## in some bounded region, say a ball of some large radius ##\Lambda##. In quantum theory, a particle with a momentum of magnitude greater than ##\Lambda## is the same as a wave with a wavelength less than ##\hbar/\Lambda##. Thus, imposing the cutoff amounts to ignoring waves of short wavelength — and for the same reason, ignoring waves of high frequency. We obtain well-defined answers to physical questions when we do this. Unfortunately, the answers depend on ##\Lambda##, and if we let ##\Lambda \to \infty##, they diverge.
However, this is not the correct limiting procedure. Indeed, among the quantities that we can compute using Feynman diagrams are the charge and mass of the electron! Its charge can be computed using diagrams in which an electron emits or absorbs a photon:
photon_absorption_processes
Similarly, its mass can be computed using a sum over Feynman diagrams where one electron comes in and one goes out.
The interesting thing is this: to do these calculations, we must start by assuming some charge and mass for the electron — but the charge and mass we get out of these calculations do not equal the masses and charges we put in!
The reason is that virtual particles affect the observed charge and mass of a particle. Heuristically, at least, we should think of an electron as surrounded by a cloud of virtual particles. These contribute to its mass and ‘shield’ its electric field, reducing its observed charge. It takes some work to translate between this heuristic story and actual Feynman diagram calculations, but it can be done.
Thus, there are two different concepts of mass and charge for the electron. The numbers we put into the QED calculations are called the ‘bare’ charge and mass, ##e_\mathrm{bare}## and ##m_\mathrm{bare}##. Poetically speaking, these are the charge and mass we would see if we could strip the electron of its virtual particle cloud and see it in its naked splendor. The numbers we get out of the QED calculations are called the ‘renormalized’ charge and mass, ##e_\mathbb{ren}## and ##m_\mathbb{ren}##. These are computed by doing a sum over Feynman diagrams. So, they take virtual particles into account. These are the charge and mass of the electron clothed in its cloud of virtual particles. It is these quantities, not the bare quantities, that should agree with the experiment.
Thus, the correct limiting procedure in QED calculations is a bit subtle. For any value of ##\Lambda## and any choice of ##e_\mathrm{bare}## and ##m_\mathrm{bare}##, we compute ##e_\mathbb{ren}## and ##m_\mathbb{ren}##. The necessary integrals all converge, thanks to the cutoff. We choose ##e_\mathrm{bare}## and ##m_\mathrm{bare}## so that ##e_\mathbb{ren}## and ##m_\mathbb{ren}## agree with the experimentally observed charge and mass of the electron. The bare charge and mass chosen this way depend on ##\Lambda##, so call them ##e_\mathrm{bare}(\Lambda)## and ##m_\mathrm{bare}(\Lambda)##.
Next, suppose we want to compute the answer to some other physics problem using QED. We do the calculation with a cutoff ##\Lambda##, using ##e_\mathrm{bare}(\Lambda)## and ##m_\mathrm{bare}(\Lambda)## as the bare charge and mass in our calculation. Then we take the limit ##\Lambda \to \infty##.
In short, rather than simply fixing the bare charge and mass and letting ##\Lambda \to \infty##, we cleverly adjust the bare charge and mass as we take this limit. This procedure is called ‘renormalization’, and it has a complex and fascinating history:
• Laurie M. Brown, ed., Renormalization: From Lorentz to Landau (and Beyond), Springer, Berlin, 2012.
There are many technically different ways to carry out renormalization, and our account so far neglects many important issues. Let us mention three of the simplest.
First, besides the classes of Feynman diagrams already mentioned, we must also consider those where one photon goes in and one photon goes out, such as this:
photon_mass
These affect the properties of the photon, such as its mass. Since we want the photon to be massless in QED, we have to adjust parameters as we take ##\Lambda \to \infty## to make sure we obtain this result. We must also consider Feynman diagrams where nothing comes in and nothing comes out — so-called ‘vacuum bubbles’ — and make these behave correctly as well.
Second, the procedure just described, where we impose a ‘cutoff’ and integrate over energy-momenta ##p## lying in a ball of radius ##\Lambda##, is not invariant under Lorentz transformations. Indeed, any theory featuring the smallest time or smallest distance violates the principles of special relativity: thanks to time dilation and Lorentz contractions, different observers will disagree about times and distances. We could accept that Lorentz invariance is broken by the cutoff and hope that it is restored in the ##\Lambda \to \infty## limit, but physicists prefer to maintain symmetry at every step of the calculation. This requires some new ideas: for example, replacing Minkowski spacetime with 4-dimensional Euclidean space. In 4-dimensional Euclidean space, Lorentz transformations are replaced by rotations, and a ball of radius ##\Lambda## is a rotation-invariant concept. To do their Feynman integrals in Euclidean space, physicists often let time take imaginary values. They do their calculations in this context and then transfer the results back to Minkowski spacetime at the end. Luckily, there are theorems justifying this procedure.
Third, besides infinities that arise from waves with arbitrarily short wavelengths, there are infinities that arise from waves with arbitrarily long wavelengths. The former is called ‘ultraviolet divergences’. The latter is called ‘infrared divergences’, and they afflict theories with massless particles, like the photon. For example, in QED the collision of two electrons will emit an infinite number of photons with very long wavelengths and low energies, called ‘soft photons’. In practice, this is not so bad, since any experiment can only detect photons with energies above some nonzero value. However, infrared divergences are conceptually important. It seems that in QED any electron is inextricably accompanied by a cloud of soft photons. These are real, not virtual particles. This may have remarkable consequences.
Battling these and many other subtleties, many brilliant physicists and mathematicians have worked on QED. The good news is that this theory has been proved to be ‘perturbatively renormalizable’:
• J. S. Feldman, T. R. Hurd, L. Rosen and J. D. Wright, QED: A Proof of Renormalizability, Lecture Notes in Physics 312, Springer, Berlin, 1988.
• Günter Scharf, Finite Quantum Electrodynamics: The Causal Approach, Springer, Berlin, 1995
This means that we can indeed carry out the procedure roughly sketched above, obtaining answers to physical questions as power series in ##\alpha^{1/2}##.
The bad news is we do not know if these power series converge. In fact, it is widely believed that they diverge! This puts us in a curious situation.
For example, consider the magnetic dipole moment of the electron. An electron, being a charged particle with spin, has a magnetic field. A classical computation says that its magnetic dipole moment is
$$ \vec{\mu} = -\frac{e}{2m_e} \vec{S} $$
where ##\vec{S}## is its spin angular momentum. Quantum effects correct this computation, giving
$$ \vec{\mu} = -g \frac{e}{2m_e} \vec{S} $$
for some constant ##g## called the gyromagnetic ratio, which can be computed using QED as a sum over Feynman diagrams with an electron exchanging a single photon with a massive charged particle:
The answer is a power series in ##\alpha^{1/2}##, but since all these diagrams have an even number of vertices, it only contains integral powers of ##\alpha##. The lowest-order term gives simply ##g = 2##. In 1948, Julian Schwinger computed the next term and found a small correction to this simple result:
$$ g = 2 + \frac{\alpha}{\pi} \approx 2.00232. $$
By now a team led by Toichiro Kinoshita has computed ##g## up to order ##\alpha^5##. This requires computing over 13,000 integrals, one for each Feynman diagram of the above form with up to 10 vertices! The answer agrees very well with an experiment: in fact, if we also take other Standard Model effects into account we get agreement to roughly one part in ##10^{12}##.
This is the most accurate prediction in all of science.
However, as mentioned, it is widely believed that this power series diverges! Next time I’ll explain why physicists think this, and what it means for a divergent series to give such a good answer when you add up the first few terms.
  1. bhobba says:
    [QUOTE="john baez, post: 5565242, member: 8778"]This step amounts to pretending that virtual particles with large momenta are impossible, or less likely than we'd otherwise expect.  That's not really true.”:biggrin::biggrin::biggrin::biggrin::biggrin::biggrin::biggrin::biggrin:I wonder if John, or someone else, could comment on why it works.  My limited understanding is its really a mathematical trick to decouple low energy physics we are more certain of from high energy physics that's a bit of a mystery.ThanksBill
  2. john baez says:
    Steve Wenner:”However, one of many puzzlements: if the integrals diverge, then why not change the measure?”"Imposing a cutoff" or "regularization" is one way to change the measure to get a convergent integral.  This is an important first step.  But in making this step, you are led to inaccurate answers to physics questions.  This step amounts to pretending that virtual particles with large momenta are impossible, or less likely than we'd otherwise expect.  That's not really true.It's like saying "my calculations show that I'll be in debt if I buy a Cadillac.  But I don't want to be in debt, so I'll do the calculation differently."To get the right answers, you don't want to make false assumptions just in order to get integrals that converge!  You want to figure out why the integrals are diverging, understand what conceptual mistake you're making, and fix that conceptual mistake.  That's renormalization.  There are ways to do this, like Scharf's way, where you never get the divergent integrals in the first place.  But I believe for most people those are harder to understand than what I explained here.  My explanation is more "physical" – or at least, most physicists use this way of thinking.So what's the conceptual mistake?The conceptual mistake is trying to work with imaginary "bare" particles separated from their virtual particle cloud.  There is no such thing as a bare particle.It's not an easy mistake to fix, because the particle-with-cloud is a complicated entity.  But renormalization is how we fix this mistake.  It makes perfect sense when you think about it.  I think my explanation should be enough to get the idea.  The actual calculations are a lot more work.
  3. john baez says:
    I wrote:For example, consider the magnetic dipole moment of the electron. An electron, being a charged particle with spin, has a magnetic field. A classical computation says that its magnetic dipole moment is$$ vec{mu} = -frac{e}{2m_e} vec{S} $$where ##vec{S}## is its spin angular momentum. Quantum effects correct this computation, giving$$ vec{mu} = -g frac{e}{2m_e} vec{S} $$for some constant ##g## called the gyromagnetic ratio, which can be computed using QED as a sum over Feynman diagrams with an electron exchanging a single photon with a massive charged particle:Someone asked me a good question about this:”I’m a graduate student at UMass Boston and I really enjoyed your "Struggles with the Continuum” paper. I was wondering if you could give me a little more explanation for one part. I’m by no means a particle physicist, which is probably why I didn’t get what was probably a simple point. When we want to compute the magnetic dipole moment of an electron as predicted by QED, why should we consider a process where an electron exchanges a photon with a “massive charged particle”? Basically I want to know what intuition leads one to realize this is the calculation we want to do.”I replied:”I'm no experimentalist, but to measure the magnetic dipole moment of an electron basically amounts to measuring its magnetic field.  Like its electric field, the magnetic field of an electron consists of virtual photons.  So when you "measure" its electric or magnetic field, it's exchanging a virtual photon with some charges in your detector apparatus.The easiest way to model this is to imagine your detector apparatus is simply a single charged particle and compute the force on this particle as a function of its position and velocity, due to the virtual photon(s) being exchanged.   (The magnetic force is velocity-dependent.)But if that charged particle is light, quantum mechanics becomes important in describing its behavior: the uncertainty principle will make it impossible to specify both its position and velocity very accurately.  So, it's better to take the limit of a very massive particle.  In that limit, you can specify both position and momentum exactly.”
  4. A. Neumaier says:
    “However, one of many puzzlements: if the integrals diverge, then why not change the measure?”
    One can avoid the divergences from the outset by using a carefully chosen mathematical setting. This is described in Scharf’s book cited in the article, and in more detail in [URL=’https://www.physicsforums.com/insights/causal-perturbation-theory/’]my insight article[/URL].
  5. bhobba says:
    In that regard the following is likely of interest:
    [MEDIA=youtube]LYNOGk3ZjFM[/MEDIA]
    Very nice series of lectures on what divergence really is and even the why of quantitisation. I have viewed them a few times now and enjoy it every time.
  6. A. Neumaier says:
    “Nice to see you again!”
    Well, your former ”this week’s find in mathematical physics” was far more attractive for me than your current blog. Online, I am now mainly active on [URL=’http://www.physicsoverflow.org’]PhysicsOverflow[/URL]. But this term I have a sabbatical, which gives me more time to spend on discussions, so I became again a bit active here on PF.
  7. john baez says:
    “Nice explanation!
    Those who want to see renormalization in a simpler toy setting not involving fields but just ordinary quantum mechanics might be interested in my [URL=’http://www.mat.univie.ac.at/~neum/ms/ren.pdf’]tutorial on renormalization[/URL].”
  8. Steven Wenner says:
    Wonderful post!  This is the first time since I read Feynman's popular little book, QED, that I have felt that I have learned something solid this subject.  Can't wait for the next installment!However, one of many puzzlements: if the integrals diverge, then why not change the measure?
