Cosmic Web Connections
The Evolution of the Universe, Cosmic Web and Connections
Common Topics: data, offset, galaxies, star, formation
The universe was not perfectly uniform when it started, some areas had a higher density than others. During the evolution of the universe, these areas of high density contained most of the matter and started forming galaxies where there was the highest concentration of matter. This large-scale structure (‘cosmic web’) connects the observed clusters of galaxies via a series of filaments. Figure 1 is a model of what this looks like.
Skeleton of a cosmic web
Figure 1: Skeleton of a cosmic web traced out by an algorithm run on a sample of observed galaxies. The far right shows the complete web, and the left images show close-up portions. Blue areas are points of higher density.
Cosmic Web Key Points
  1. The universe was not perfectly uniform when it started and some areas had higher density than others, forming galaxies
  2. High-density areas are connected via acosmic web of filaments and the more connected a galaxy is (connectivity) the more massive it is
  3. Connectivity is related to star formation, with higher connectivity resulting in less star formation
  4. AGN activity is more efficient at quenching star formation in galaxies with high connectivity
  5. Connectivity has an impact on the evolution of a galaxy, affecting star formation, mass and morphology
At the Crossroads
The cosmic web is a representation of the density of space and can be traced out with the observed distribution of galaxies, connecting those closest. This is done with similar algorithms for both observations and simulations. The densest areas are the more massive, central galaxies that are located at the crossroads of multiple filaments (nodes), similar to the blue areas in Figure 1. Other research has shown the mass of a galaxy increases with the number of connected filaments (“connectivity”). Recent research wanted to know whether the connectivity was related to star formation and whether it helped prevent star formation from happening.
Forming Stars, or Not
To accomplish this, scientists investigated observed and simulated galaxies at the densest regions (nodes) within the cosmic web. Observed galaxies were taken from the SDSS (The Sloan Digital Sky Survey) data release and number ~ 7×105. Galaxies from two independent simulations were compared to the observations to see if the same general trends hold, but direct comparison is difficult because simulations have significantly smaller sample sizes. This is due to the computational cost of simulating large amounts of galaxies.
These galaxies were connected with a median of three filaments. For the observed galaxies, scientists compared the connectivity to the star formation rate (measured by comparing the relative ages of stars). Figure 2 shows that as connectivity decreases, the excess star formation rate increases for all galaxies. Researchers found this trend also occurred for the simulated galaxies, where star formation can be chosen as an output parameter.
Comparison for the observed galaxies of the average connectivity and excess star formation rate relative to the average for that type.
Figure 2: Comparison of the observed galaxies of the average connectivity and excess star formation rate relative to the average for that type. The black lines are for all galaxies. Top: The blue line is for star-forming galaxies and the red line is for passive galaxies which are not actively forming a significant amount, of stars. Bottom: The blue line is for spherical or irregularly shaped galaxies the red line is for elliptical galaxies. Increasing star formation is to the right. This shows that as connectivity increases, star formation decreases.
This is counterintuitive; filaments can funnel cold gas into the galaxy, which could be expected to trigger star formation. Scientists provide several different explanations for this. It could be that the gas received from multiple filaments could be chaotic, instead of the more uniform funneling that a single filament would provide. Alternatively, it could be that the filaments may not be effective at feeding the inner regions of a galaxy that would form stars, or that they are experiencing fewer mergers that are mixing less gas. Whatever the explanation, scientists have shown that more connectivity means less star formation.
Transitioning to Old Age
Finally, researchers investigated what impact connectivity had on AGN (active galactic nucleus) activity. Feedback from AGN is important in galaxy formation as it assists the transition of a galaxy from being new and star-forming to a passive old age. AGN gives off vast amounts of energy that can drive star-forming gas out of the galaxy and quench star formation. To link AGN activity and connectivity, scientists compared two similar simulations: one with AGN and one without. They found that AGN was more efficient at quenching star formation when they were in galaxies with high connectivity.   The AGN were able to give off more energy to stop star formation as they were fed more material.
Researchers showed that connectivity is an important factor in galaxy formation, as it affects when stars will stop forming, as well as the total mass and morphology of a galaxy in both observations and simulations. The evolution of galaxies is impossible to observe as it takes many millions of years, however, any information we can gather from work such as this helps us understand the universe.
Arnouts, S. Codis, S. Davé, R. Devriendt, J. Dubois, Y. Hwang, H. S.
Kraljic, K. (Institute for Astronomy, University of Edinburgh), Laigle, C.
Musso, M. Peirani, S. Pichon, C. Pogosyan, D. Slyz, A. Treyer, M.
Comment Thread
1 reply
  1. Prof Mark R Smith says:
    Nothing surprising, this is an overview of the cosmic process which applies to various galaxies and the composition of matter within and surrounding!
