999equals1
Why Do People Say That 1 And .999 Are Equal?
Common Topics: numbers, less, equal, sets, people
Why do people say 1 and 0.999… are equal? Aren’t they two different numbers?
No, they really are the same number, though this is often very counterintuitive to many beginning students. Here are some non-rigorous proofs that 1=0.999…:
Proof #1
For any two unequal numbers, there is always another number in between them. (That is intuitively obvious, and can be pictured on a number line, which will be familiar to many people.) Therefore, if 0.999…. and 1 are different, there must be another number in between them. But there is no way to write a number that is greater that 0.999… and less than 1 in decimal notation.
Proof #2
First, we put
[tex]\ x = 0.999…[/tex]
Multiplying by 10 gives us
[tex]\ 10x = 9.999…[/tex]
But then
[tex]\ 10x-x = 9.999…-0.999…,[/tex]
thus
[tex]\ 9x = 9[/tex]
Hence we get that
[tex]\ x = 1[/tex]
Proof #3
If you accept that 0.9999… is a number, then how much less than 1 is it? It’s larger than 0.9999, so it’s less than 0.0001 less than 1. But it’s also larger than 0.9999999, so it’s less than 0.0000001 less than 1. So the difference between 0.9999… and 1 is less than 0.00001, 0.000000001, or 0. any number of 0s followed by 1 … so the difference must be zero. If you accept that two numbers whose difference is 0 must be the same, then that proves that 0.9999… = 1. If you don’t accept that, and you think that two different numbers can have a difference of zero, then you’re in an ‘extended number system’ that has more numbers than we normally use.
Proof #4
First, we have that
[tex]\ 1/3 = 0.333…[/tex]
If we multiply things by 3, then we get
[tex]\ 1=3\times (1/3) = 3\times (0.333…) = 0.999…[/tex]
All of these proofs are correct, but they are not rigorous. For example, how do we know that [itex]3 \times (0.333…) = 0.999…[/itex]? This is not that obvious if we think about it. A more rigorous proof is given in the post following this one.
Some further questions you might have:
But 1 cannot equal 0.999…, as every number can only have one representation!
Well, the thing is that this is just a misconception that is simply not true. Numbers can have many representations. For example,
[tex]\frac{1}{3}=\frac{2}{6}=\frac{3}{9}=0.333… ,[/tex]
but somehow, many people don’t have any problems with this thing. The same thing happens to 1=0.999… really, it’s just another way to write the same number. Does this make our number system ugly? I understand that you might think that, but that’s just something we need to accept. Not having that 1=0.999… would make our number system much uglier!
The way I see it, is that 0.999… gets closer and closer to 1, but never quite reaches 1.
This reasoning appears a lot and apparently, many people see 0.999… as some kind of process that gets close to 1. But this is not quite what mathematicians mean with 0.999…
Mathematicians say that 0.999… is a number, just like 2 and 3. So phrases like “it gets close to 1, but never reaches 1” are meaningless. It’s the same as saying 1 gets closer and closer to 2, but never quite reaches 2. This sentence makes no sense, and the same thing happens with 0.999…
Can we define number systems such that 1=0.999… does not hold?
Of course! But these number systems are not as useful, because they don’t conform to our intuition about numbers and limits.
In Proof #2, you say 10x=9.999… But this 9.999… has one fewer nine than 0.999…
Another popular argument. This time, the confusion arises from not grasping infinity. 0.999… has an infinite number of nines. If we somehow remove a nine from this sequence, then we would still have an infinite number of nines. So there are an equal number of nines in 0.999… and 9.999…
The same thing happens here: consider two sets of numbers, A and B, where
[tex]A=\{0,1,2,3,4,…\}[/tex]
[tex]B=\{1,2,3,4,…\}[/tex]
Both sets are infinite. Actually, both sets have an equal number of elements. But A doesn’t contain 0, so it has one fewer element than B? Yes, but this reasoning only applies to finite sets. For infinite sets, it’s quite possible to have one element less and still have an equal number of elements. Indeed, consider the following correspondence:
[tex]0\leftrightarrow 1,~1\leftrightarrow 2,~2\leftrightarrow 3,~3\leftrightarrow 4,…,~n\leftrightarrow n+1,…[/tex]
So for an element n in A, there exists a unique element in B that corresponds to n, namely n+1. This means, by definition actually, that both sets have the same number of elements.
Read this supportive article: https://www.physicsforums.com/insights/is-there-a-rigorous-proof-of-1-0-999/
Maybe we should just abandon our base 10 number system and move to a number system where every number has a unique representation.
Tempting, but sadly this is not possible. The problem arises in every base! For example, in base 2, we have [itex]1=0.111…[/itex]. There is no way around it.
AlephZero
Fredrik
micromass
tiny-tim
vela
Click For Forum Comments
Newer Comments »
  1. Isaac0427 says:
    Ok, I just talked to my math teacher. She explained it to me in person which helped. Thanks guys it really does help. I mostly understand it now, that as something gets so close to 1, for all practical purposes, it is equal to 1.
  2. jbriggs444 says:
    “I thought it represented an infinitely small change of x. I could be wrong, however.”
    In the non-standard analysis, dx can be given meaning as an infinitesimal. In standard analysis, the dx in an integral is pure notation.
  3. WWGD says:
    “dx is also infinitesimally small, but if it equaled zero, then any integral or derivative would equal zero or be undefined.”
    Remember I said in previous posts that the length of the rectangles in a fixed Riemann sum is bounded below. You then consider what happens as this approaches 0 in the limit, but this, dealing with limits, is a separate issue.
  4. jbriggs444 says:
    dx is not a number. It is a notation.
  5. Isaac0427 says:
    “1-0.99999…. _is_ indefinitely small, so must equal zero.”
  6. WWGD says:
    Yet another reason, maybe mentioned is that, by the Archimedean property, a Standard Real number cannot be indefinitely small; it must then equal zero. But the difference
    1-0.99999…. _is_ indefinitely small, so must equal zero. So the two numbers are then equal.
  7. lavinia says:
    “I know this discussion came off of my mentioning a Riemann sum. I meant a Riemann integral. My point was that in a Riemann integral, you add up an infinite amount of rectangles with a width of dx. dx, for the integral to have a nonzero value, couldn’t be zero, but it is, by definition, less than .00000000001, .00000000000000000000000001, or any number of zeros you put before the one. You would need an infinite amount of zeros. So, I know it may not be the proper notation, but the width of the rectangles would essentially be .000…1. If the fact that it gets infinitely close to zero makes it equal to zero, then a Riemann integral would have a value of zero, which is not the case. If we were to take some [U]fundamental[/U] length (in a coordinate system that has one), and have two particles of that size touch with a distance between them of zero, would they be in the same position? I say a fundamental size because the particle’s centers would have no distance between them.”
    This is not what the Riemann integral is. One does not add up an infinite number of rectangles of zero width.
    The way I learned it, the Riemann integral is defined in terms of lower and upper sums. For a positive function, one divides a closed interval into finitely many closed segments then takes the length of each segment and multiplies it by the max or the min of the function in the segment. and adds the values up. These give you what are called lower and upper sums. [U]As WWGD said,[/U] [U]these segments have finite length and there are always only finitely many terms in the sum [/U]The Riemann integral is then the Least Upper Bound of all lower sums obtained by dividing the interval into finitely many segments of finite length. It is also the Greatest Lower Bound of all upper sums. A particular sum can be chosen to have segments of arbitrarily small length, but each sum always has finitely many segments and these segments always have finite length.
    This same point is true for the expression ##.999…##
    The three dots mean that number which is the Least Upper Bound of all finite decimal numbers, .9, .99, 999, .9999 etcetera. [U]It does not stand for some non-standard number in some other number system. [/U]It stands for that ordinary real number that is the LUB of the set of decimals ##{ .9,.99,.999, .9999}## etc
    The number one is the least Upper Bound of all of these numbers. The proof shows that one can always find a finite decimal sequence of 9’s that is arbitrarily close to 1, Another way of saying this is that 1 is the limit of the sequence, ##x_1 = .9##, ##x_2 = .99 ##, … ## x_n = .999999## (n times)
    [U]Hallsofivy gives a nice proof of this limit in Post #2.
    [/U]
    Every positive number has a decimal expansion. For almost all of them, the decimal expansion is infinitely long. This means that almost every number is the Least Upper Bound of an infinite sequence of increasing decimal numbers. 1 is not special in any way.
  8. Isaac0427 says:
  9. Mark44 says:
    “The maximal width goes to 0 if we consider a net of Riemann sums. In order to compute the Riemann integral, we consider what happens as the width of partitions go to zero.
    But any sum has a minimal width.
    [/quote]Yes, I understand all of this.
    What I disagree with, and keep carping on, your assertion that the widths of the rectangles can be “going to 0” and at the same time “these widths do not become indefinitely-close to 0”. Obviously, both of these can’t be true.
  10. WWGD says:
    “Please explain to me how the widths of the rectangles can be “going to 0” and at the same time “these widths do not become indefinitely-close to 0″ — your words.
    I maintain that you can’t possibly be talking about a specific Riemann sum with a specific number of terms (hence a specific number of rectangles, all of whose areas are positive numbers).”
    I don’t mean to be disrespectful, but this conversation does not seem to be going anywhere productive and frankly, I would like to leave it at this. I am not blaming it on you, but we either drop it or take a different tack to it, because otherwise we will be going ( at least seemingly) in circles for a long time here. We are just not communicating effectively here; I suggest we leave it at this, at least for now. No disrespect intended.
  11. lavinia says:
    “We are not talking about a specific Riemann sum. My complaint is that you are talking about a limit, but don’t seem to realize it. Emphasis added.
    In other words, as ##Delta x to 0## — that’s a limit. All the other stuff about compact sets, continuity, and subcovers etc. is just word salad that I’m 99% sure would be over the head of the person you were responding to.”
    I think that WWGD is trying to point out that on an open interval one would need to divide it into an infinite sequence of closed intervals whose lengths would become arbitrarily small near the edge of the interval. On a closed interval one can choose a subdivision that is finite.
  12. Mark44 says:
    “No, I am definitely talking about an individual Riemann sum. By a controlled way, I mean there is a lower bound for the widths, which there is by the usual arguments. I think the confusion here is you are referring to the Riemann integral, while I am referring to specific Riemann sums.”
    Please explain to me how the widths of the rectangles can be “going to 0” and at the same time “these widths do not become indefinitely-close to 0” — your words.
  13. WWGD says:
    “When you say, “the rectangles, while going to 0, …” you’re no longer talking about a specific Riemann sum — you’re talking about the limit of the Riemann sums (as the number of terms goes to infinity), which means you’re talking about the Riemann [U]integral[/U].
    These were your exact words:
    In short, you’re saying that the rectangles are going to zero and that their widths are not going to zero. That’s impossible.
    Also, I don’t know what you mean “goes to zero in an uncontrolled way” …”
  14. Mark44 says:
    ” I was referring to individual Riemann sums, not to the Riemann integral itself. I was addressing the question of whether a Riemann sum is zero or not, because the general term goes to zero in an uncontrolled way.[/quote]
    [quote]I think the point is that the rectangles, while going to 0, are uniformly bounded , by compactness of the region of integration, so these widths do not become indefinitely-close to 0[/quote]In short, you’re saying that the rectangles are going to zero and that their widths are not going to zero. That’s impossible.
    [QUOTE=WWGD] I made no reference to the Riemann integral itself; that is a whole other topic. But yes, the Riemann integral is the limit as the partition width goes to zero. I don’t see why the two contradict or are incompatible with each other.”
  15. WWGD says:
    “I think you mean Riemann [U]integral[/U] being the limit of the Riemann sums.
    My complaint is in the following. I interpret the phrase “while going to 0” as equivalent to saying “the limit of the Riemann sums as n goes to infinity.” You can’t say that the widths of the rectangles are going to zero, but at the same time do not become close to zero. Here again is what you said, with emphasis added.
    The rectangle widths are either going to zero or they’re not — you can’t have it both ways.”
    Yes, I meant Riemann integral, my bad. I was referring to individual Riemann sums, not to the Riemann integral itself. I was addressing the question of whether a Riemann sum is zero or not, because the general term goes to zero in an uncontrolled way. I made no reference to the Riemann integral itself; that is a whole other topic. But yes, the Riemann integral is the limit as the partition width goes to zero. I don’t see why the two contradict or are incompatible with each other.
  16. Mark44 says:
    “No, I think you are not realizing my point. I am talking about an individua Riemann sum not being 0, addressing the question. I do know that the Riemann sum is the limit ( if it exists) of the Riemann sums.
    [/quote]I think you mean Riemann [U]integral[/U] being the limit of the Riemann sums.
    [QUOTE=WWGD] I never said nor implied otherwise. I did reply to the OP that for individual sums, the width is controlled, so it does not go to zero. The rest of the exchanges were with and for you.”
    [quote=WWGD]I think the point is that the rectangles, while going to 0, are uniformly bounded , by compactness of the region of integration, so these widths do not become indefinitely-close to 0[/quote]
  17. WWGD says:
    No, I think you are not realizing my point. I am talking about an individua Riemann sum not being 0, addressing the question. I do know that the Riemann sum is the limit ( if it exists) of the Riemann sums. I never said nor implied otherwise. I did reply to the OP that for individual sums, the width is controlled, so it does not go to zero. The rest of the exchanges were with and for you.
  18. PeroK says:
    “The phrasing that madness used was careful and avoided speaking of the result of a never-ending process.”
    Fair enough. It’s not the way I read it, but my apologies to madness.
  19. jbriggs444 says:
    “Perhaps, but my original point was that there are those who see the limit as a number (full stop) and those who see the limit as the hypothetical result of a never-ending process. Breaking away from this latter view is perhaps an important step in grasping rigorous maths.”
    “Yes, but it’s also important to remember that this number (the limit) is the number that you get closer and closer to as you apply the process of increasing n. Or, if you don’t like this process, it’s the number that you can get as close to as you like by choosing a high enough value of n.”
  20. PeroK says:
    “Neither is a rigorous definition of a limit but they are a statement of what is implied by such a definition. In particular, the limit of the sequence 0.9, 0.99, 0.999, … is the number 1, not the sequence itself.”
  21. HallsofIvy says:
    “Neither of those is the definition of a limit.”
    Neither is a rigorous definition of a limit but they are a statement of what is implied by such a definition. In particular, the [b]limit[/b] of the sequence 0.9, 0.99, 0.999, … is the [b]number[/b] 1, not the sequence itself.
  22. PeroK says:
  23. madness says:
    “It is important, though, to realise that a limit is a number, and not a process. It’s a small point, perhaps, but it sharpens your understanding of these things.”
  24. PeroK says:
    “But what I actually said was “limit of 0.999… as you keep on adding more decimal places”, which is not the same as what you quoted from me. I’m not sure what point you are making in the second part, as it seems to agree with what I wrote. The mathematical statement simply says that as you make n bigger and bigger you get closer and closer to 1, which I don’t think anybody would disagree with.”
  25. madness says:
    “There’s a difference between what you say above and what I think you’re trying to say.
    First: limit of .999 … is meaningless, as you aren’t saying what is changing.
    Second, ##lim_{n to infty}sum_{j = 1}^n frac 9 {10^j} = 1##. The sum can be made arbitrarily close to 1 just by taking more terms in the sum.”
  26. Mark44 says:
    “In a _specific sum_ , the function interval width is continuous and defined on a compact set. What is wrong with this argument? If you let your minimal width go to 0 in a _specific sum_ without bound, your integral will equal 0. What you end up getting is a net of Riemann sums, which will converge netwise to the value of the integral under the right conditions.”
  27. WWGD says:
    I also see it like this: The collection {## x_1=a, x_2,…., x_n=b ##} covers [a,b]. By compactness of [a,b], the collection has a finite subcover. Now, consider min ## (x_{i+1}-x_i )##:=m on the finite subcover. A finite set will have a minimum value , say m. The value ##m=0## will never be realized. Maybe I am not explaining myself well here.
  28. WWGD says:
    “This part, which I just quoted:”
  29. Mark44 says:
    “Do you see something specifically wrong with the claim that rectangle width is continuous on a compact set so it achieves a minimum, which is a uniform lower bound? Is this _not_ a controlled way? What flaw do you see here?”
    This part, which I just quoted: [quote]so these widths do not become indefinitely-close to 0;[/quote]
  30. WWGD says:
    “I’m not sure that we were. Isaac0427 said I believe he really meant Riemann integral here.
    Your response to him was
    Your explanation used a lot of fairly high-powered analysis, but was flawed; i.e., that the (areas of) the rectangles are going to zero while their widths miraculously remain positive, or that they “become close to zero in a controlled way.””
    Do you see something specifically wrong with the claim that rectangle width is a continuous function on a compact set so it achieves a minimum, which is a uniform lower bound? Is this _not_ a controlled way? What flaw do you see here? Or do you claim that in a specific Riemann sum the widths, and specifically the minimal width, becomes indefinitely close to 0. Convince me then that the integral is not zero.
  31. Mark44 says:
    I’m not sure that we were. Isaac0427 said [quote]wouldn’t a Riemann sum not mater at all, and just be equal to zero?[/quote]I believe he really meant Riemann integral here.
    Your response to him was [quote=WWGD]I think the point is that the rectangles, while going to 0, are uniformly bounded , by compactness of the region of integration, so these widths do not become indefinitely-close to 0; they become close to 0 in a controlled way.[/quote]
  32. WWGD says:
    “A particular [U]Riemann sum[/U] will involve a finite number of subintervals of nonzero width. The [U]Riemann integral[/U], however, is the limit of these Riemann sums, as the subinterval width goes to zero.”
    So we are saying the same thing. I was addressing a poster question about the fact that an indefinitely-small Standard Real number must equal 0, which led them to believe that it must follow that a Riemann sum must equal 0 , since all the terms in the sum become indefinitely small. But this is not so, because in an individual/specific Riemann sum, the terms do not become indefinitely small; they are uniformly bounded by my previous argument. Of course this bound goes to 0, but the minimal width on a specific Riemann sum does not go to 0 or else the sum itself would be zero. Now, it would be interesting how to do integrals in non-standard analysis. I have seen methods to differentiate but I have not seen integration theory in non-standard analysis.
  33. Mark44 says:
    “This is kind of difficult to explain in words, but my point is that, for any individual Riemann sum, the function (partition width) is a continuous function on a compact set [a,b], so it assumes a minimum value. Of course, we let the minimal values go to 0.”A particular [U]Riemann sum[/U] will involve a finite number of subintervals of nonzero width. The [U]Riemann integral[/U], however, is the limit of these Riemann sums, as the subinterval width goes to zero.
  34. WWGD says:
    “But the Riemann [U]integral[/U] is the limit as the partition gets finer, of these sums.
    [URL]https://en.wikipedia.org/wiki/Riemann_integral[/URL]
    In other words, as you take the limit as n goes to infinity, which forces the subinterval width to zero.”
  35. Mark44 says:
    “Yes, but a specific Riemann sum takes on a specific value for ##n ##. Then you consider different Riemann sums where n becomes larger.
    [/quote]But the Riemann [U]integral[/U] is the limit as the partition gets finer, of these sums.
    [quote]Loosely speaking, the Riemann integral is the limit of the Riemann sums of a function as the partitions get finer.[/quote]
    [QUOTE=WWGD]
    So you have a collection of Riemann sums, each with a specific value of n, and we consider what happens as we consider specific sums with increasingly-larger values for ##n ##.”In other words, as you take the limit as n goes to infinity, which forces the subinterval width to zero.
  36. WWGD says:
    “.Sure they do. Assuming for simplicity’s sake that ##Delta x = frac{b – a} n##, as ##n to infty, Delta x to 0##. There is no positive minimum value that’s a lower bound on ##Delta x.##
    For the same reason, we can evaluate ##lim_{x to infty} x cdot frac 1 {2x + 3}## and get 1/2, even though there is no upper bound on x, and no positive lower bound on ##frac 1 {2x + 3}##.”
    Yes, but a specific Riemann sum takes on a specific value for ##n ##. Then you consider different Riemann sums where n becomes larger. So you have a collection of Riemann sums, each with a specific value of n, and we consider what happens as we consider specific sums with increasingly-larger values for ##n ##. So you end up with a net of Riemann sums , where the order is inclusion of partition set {#x_1,x_2,…,x_k#} , that converges ( under the right conditions) as a net to the value of the integral.
  37. Mark44 says:
    .”Yes, what I meant is for a specific Riemann sum, the widths are uniformly bounded; the function Min width is a continuous function on a compact set — integration is done on a compact interval [a,b] — so it assumes an actual minimum value on [a,b]. Now, we can consider what happens as we let the widths go to 0, but for a _specific_ Riemann sum, the widths do not go to 0.
    [/quote]Sure they do. Assuming for simplicity’s sake that ##Delta x = frac{b – a} n##, as ##n to infty, Delta x to 0##. There is no positive minimum value that’s a lower bound on ##Delta x.##
    [QUOTE=WWGD] And then we define convergence using nets.”
  38. WWGD says:
    “In the Riemann definition of a definite integral, you have the number of rectangles n approaching infinity (i.e., increasing without bound), where the area of each rectangle is approaching zero.
    In effect, what you have is the indeterminate form ##[0 cdot infty]##. Indeterminate forms are a way to categorize limits that involve a product or quotient or other operation in which one or more of the quantities is unbounded. Indeterminate forms are not number, and different instances of the same indeterminate form can come out to be literally any real number or ##infty## or ##-infty##. With Reimann sums, if you have a well-behaved function, the limit comes out to a real number.
    See above…”
    Yes, what I meant is for a specific Riemann sum, the widths are uniformly bounded; the function Min width is a continuous function on a compact set — integration is done on a compact interval [a,b] — so it assumes an actual minimum value on [a,b]. Now, we can consider what happens as we let the widths go to 0, but for a _specific_ Riemann sum, the widths do not go to 0. And then we define convergence using nets.
  39. Mark44 says:
    ” If something infinitesimal is just considered 0, wouldn’t a Riemann sum not mater at all, and just be equal to zero? Wouldn’t that make anything using dx, dy, etc. represent a change of zero, as they are defined as an infinitesimaly small change in their respective variable? This is just my thinking, I am not being ignorent, I just want to understand.”
    “Like someone pointed out, there are no infinitesimals in the Standard Real numbers; these exist only on non-standard models of the Reals. Your other questions are good, let me think about them some more. I think the point is that the rectangles, while going to 0, are uniformly bounded , by compactness of the region of integration, so these widths do not become indefinitely-close to 0; they become close to 0 in a controlled way. Good point, though.”See above…
  40. WWGD says:
    “I have no way to say this is true for sure, but it appears to me as though proof #3 is based off an incorrect assumption. Wouldn’t the difference between .999… and 1 be infinitesimal, not 0. Isn’t this one of the reasons we have the concept of infinity, and in this case an infinitesimal value. If something infinitesimal is just considered 0, wouldn’t a Riemann sum not mater at all, and just be equal to zero? Wouldn’t that make anything using dx, dy, etc. represent a change of zero, as they are defined as an infinitesimaly small change in their respective variable? This is just my thinking, I am not being ignorent, I just want to understand.”
  41. Mark44 says:
    [/quote]There is no need that I can see to bring infinitesimals into the argument. By definition of the notation, .999 … [U]means[/U] an infinitely long string of 9s. If there is a difference between .999 … and 1, there has to be a digit somewhere in the difference that isn’t 0. Which digit is that?
    [QUOTE=Isaac0427] Isn’t this one of the reasons we have the concept of infinity, and in this case an infinitesimal value. If something infinitesimal is just considered 0, wouldn’t a Riemann sum not mater at all, and just be equal to zero? Wouldn’t that make anything using dx, dy, etc. represent a change of zero, as they are defined as an infinitesimaly small change in their respective variable? This is just my thinking, I am not being ignorent, I just want to understand.”
  42. Mark44 says:
    I would think this whole theme is answered by:
    The definition of real numbers says that $$0.999…_{text{as real number}} =_{text{acting on real numbers}} 1_{text{as real number}}$$
    If you don’t like it, use other numbers.”I have no idea what you’re trying to say in the equation above.
    “I think equivalence is more intuitive if you simply state that the limit of 0.999… as we keep adding more decimal places is 1. I think this is also a closer translation of the mathematical statement into plain english.”
  43. WWGD says:
    “I think a key point is that .999… is by definition a limit, and that limit is equal to 1.”
    True, it is the limit of a Cauchy sequence, which converges by the fact that the Reals are a complete metric space, and the sequence, as you said, converges to 1.
  44. WWGD says:
    I agree with Mathwonk. It is a very narrow view of what a number is. A number is not a unique object, but instead an equivalence class of objects. Under this equivalence relation, the two, 0.99999… and 1 are equivalent, and so considered equal. Maybe similar to the fact that if today is Wednesday, then every day that is ## pm 7k ## days from today is also a Wednesday, and not just that today , 12/9/2015 is Wednesday, so no other day can be a Wednesday . Equivalence is very close conceptually to equality but it is not quite the exact same thing.
  45. mathwonk says:
    this question never dies. this is basically why people cannot tell the difference between a good car and a car that says “BMW” on the side, i.e. its not all about the notation. but for some reason they are willing to allow the same car to be called a bmw or a beemer, but a number can’t have two names. still the same people who admit that .33333….. = 1/3, will not accept the result of multiplying this equation by 3.
  46. WWGD says:
    “They are clearly different but if you’re approximating, they’re almost equal.”
    No, they are not different as Real numbers using the definition of Real numbers in terms of Cauchy sequences. This is a technical point that requires the use of precise definitions.
  47. Isaac0427 says:
    I think that is exactly my point. If we call limits being equal to, in the equation for derivatives, lim Δx→0 (f(x+Δx)-f(x))/Δx (I know I may not have written it right), the answer would be undefined.
  48. madness says:
  49. SlowThinker says:
    “Wouldn’t the difference between .999… and 1 be infinitesimal, not 0.
    something infinitesimal is just considered 0”
    Both are true. The important part is that real numbers are not precise enough to distinguish an infinitesimal difference – which is, in fact, the reason why we can use infinitesimals to integrate and derive expressions containing real numbers.
  50. Isaac0427 says:
  51. Mark44 says:
    Who are “they”? Are you referring to .999 and .999… ?
    Clearly these two numbers are close, but that’s not the point. What we’re saying is that .999… is identically equal to 1, and .999 is smaller than 1 by .001.
  52. Mark44 says:
    “*Both .999… and 9.999… are finite numbers; i.e., strictly less than infinity.*
    How can you call 0.999…… or 9.999…… as finite?
    If these are finite then infinity can also be considered finite!”
    “Please look up the definition of a finite number. There is a difference between an infinite _decimal expansion_ and an infinite number.”WWGD is correct. Finite numbers are bounded; infinite numbers are unbounded.
  53. WWGD says:
  54. Mark44 says:
    “So does this mean that .99999….. = .99999…8 ?”
    As already mentioned, the right side is meaningless for two reasons. On the left side the ellipsis (…) means that the pattern you see repeats endlessly. On the right side, it is not known how many 9s there are in front of the final 8 digit.
    “Okay… but it seems like to make .999 = 1 you also have to terminate the run of nines.
    [/quote]Don’t confuse .999 with .999… They mean two very different things. The first is identical to 999/1000 which is smaller than 1, and the second is equal to 1.
    Anyway I know this has been discussed several times so I’ll read up some more.”
  55. Ernest S Walton says:
    “No, because the right hand side is nonsense. You can’t have a non-terminating run of nines and then terminate it.”
    Okay… but it seems like to make .999 = 1 you also have to terminate the run of nines. Anyway I know this has been discussed several times so I’ll read up some more.
  56. pwsnafu says:
  57. SlowThinker says:
    “Why would the proof need to invoke surreal numbers? The proofs are all concerned with two representations of the same real number.”
    If the proof can be used to prove a false statement, then the proof must be wrong.
    0.9999…##neq##1 in surreal numbers, so if the proof works with them too, then it’s wrong.
    I dare say that all of the “informal proofs” from the article immediately work with surreal numbers, so they must be wrong.
    This quote from the original article,
    “Can we define number systems such that 1=0.999… does not hold? Of course!”
    seems to be the answer that people are looking for, together with “Real numbers are defined in such a way that 0.999…=1”.
  58. Mark44 says:
    “I did a quick scan of all of the proofs. None of them mentioned surreal numbers. If you can point out where I might have missed this, I would appreciate it.”
    [quote=SlowThinker]My idea was: if the proof, applied over surreal numbers, proves that 0.9999…=1, then the proof is not correct. There must be some implicit assumption.
    “Please show me where.”
    “Now, turning to the problem at hand. 0.999… is, by definition of the decimal numeration system, ##0.9+ 0.09+ 0.009+ cdotcdotcdot## = ##0.9+ 0.9(0.1)+ 0.9(0.01)+ cdotcdotcdot## = ##0.9+ 0.9(.1)+ 0.9(.1^2)+ cdotcdotcdot##, precisely a geometric series with a= 0.9 and r= 0.1. So the sum, and the value of 0.9999…, is [itex]frac{0.9}{1- 0.1}= frac{0.9}{0.9}= 1[/itex].”
    [quote=SlowThinker]I would say that, by definition of the decimal numeration system, 0.9999…=##sum_{n=1}^omega{}9 0.1^n## rather than ##sum_{n=1}^infty{}9 0.1^n##. The difference is, obviously, 0 in real numbers.
    “And that’s the set we’re concerned with here.
  59. SlowThinker says:
    “I did a quick scan of all of the proofs. None of them mentioned surreal numbers. If you can point out where I might have missed this, I would appreciate it.”My idea was: if the proof, applied over surreal numbers, proves that 0.9999…=1, then the proof is not correct. There must be some implicit assumption.
  60. Mark44 says:
    “Proofs #2 & #3 are what convinced me that 1 and .999… are NOT equal. It’s just insulting to assume that .333… = 1/3 in this context.
    [/quote]How is this assumption insulting. Just by ordinary division you can show that the 3 digit keeps repeating.
    [QUOTE=Algr]And why assume that .999… and 9.999… have different numbers of nines when this would never happen for any finite number?”
    To the right of the decimal point, both have the same number of 9 digits. Also I don’t understand what you are saying about “finite numbers”. Both .999… and 9.999… are finite numbers; i.e., strictly less than infinity.
    “I’m not an expert on these things, but you can easily tell that a proof is wrong when it proves 0.9999…=1 on surreal numbers. Which most of the above do.
    [/quote]I did a quick scan of all of the proofs. None of them mentioned surreal numbers. If you can point out where I might have missed this, I would appreciate it.
    [QUOTE=SlowThinker]
    I’m not entirely sure about HallsofIvy’s proof, it might be OK, even if I think it’s swapping ##infty## with ##omega## somewhere along the way.”Please show me where.
  61. FactChecker says:
    I’m not entirely sure about HallsofIvy’s proof, it might be OK, even if I think it’s swapping ##infty## with ##omega## somewhere along the way.”You can easily prove it by contradiction, as I indicated. Once that is done, you know that they are equal. Then I would to be careful about saying that other proofs are wrong unless I completely understood the other proofs and can pinpoint the error.
  62. SlowThinker says:
    “If they are different, how different are they? Suppose you say that they are different by more than 0.0001. Then 1 – 0.99999 is closer and the more 9’s you add, the closer it gets. So you can not say there is any difference.”I’m not an expert on these things, but you can easily tell that a proof is wrong when it proves 0.9999…=1 on surreal numbers. Which most of the above do.
  63. FactChecker says:
  64. Greg Bernhardt says:
    “While there are several arguments here that people might accept as proofs, they all, as stated, are non-rigorous, involving some basic, unstated assumptions.”
    Here is the previous FAQ
    [URL]https://www.physicsforums.com/insights/is-there-a-rigorous-proof-of-1-0-999/[/URL]
  65. HallsofIvy says:
    While there are several [b]arguments[/b] here that people might accept as proofs, they all, as stated, are non-rigorous, involving some basic, unstated assumptions. For example, in argument two, it is assumed that multiplying x= 0.999… by 10 gives 10x= 9.999… and then that subtracting x give 9x= 0.999… again. Both of those assume the usual arithmetic properties are true for 0.999… That is true but exactly the sort of thing people who object to “0.999…= 1” would object to anyway. In argument four, it is accepted that 0.333…= 1/3. Why would a person who objects to “0.999…= 1” accept that?
    It is not too difficult to give a [b]rigorous[/b] proof using “geometric series”. It is easily shown that the sum [itex]sum_{i= 0}^n ar^i[/itex] is [tex]frac{a(1- r^n}{1- r}[/tex]. To do that, let [itex]S_n= sum_{i= 0}^n ar^i= a+ ar+ ar^2+ cdotcdotcdot+ ar^n)[/itex]. Since that is a [b]finite[/b] sum, the usual properties of arithmetic hold and we can write [itex]S_n- a= ar+ ar^2+ cdotcdotcdot+ ar^n= r(a+ ar+ cdotcdotcdot+ ar^{n-1})[/itex]. The quantity in the last parentheses is [b]almost[/b] [itex]S_n[/itex] itself. It is only missing the last term, [itex]ar^n[/itex]. Restore that by adding [itex]ar^{n+1}[/itex] to both sides: [itex]S_n- a+ ar^n= r(a+ ar+ cdotcdotcdot+ ar^{n-1})+ ar^{n+ 1}[/itex]. Taking that last term inside the parentheses we have [itex]S_n- a+ ar^n= r(a+ ar+ cdotcdotcdot+ ar^{n-1}+ ar^n)= rS_n[/itex]. We can write that as [itex]rS_n- S_n= (r- 1)S)_n= ar^n- a= a(r^n- 1)[/itex] and dividing both sides by r- 1, [itex]S_n= frac{a(r^n- 1)}{r- 1}[/itex] which, for r< 1 can be written more as [itex]S_n= frac{a(1- r^n)}{1- r}[/itex]The geometric series, [itex]sum_{i= 0}^infty ar^i[/itex], is, by definition, the limit of the "partial sums", [itex]S_n= sum_{i= 0}^n ar^i[/itex], as n goes to infinity. As long as [itex]|r|< 1[/itex], [itex]lim_{ntoinfty} r^n= 0[/itex] so that limit is easily calculated as [itex]sum_{i= 0}^infty ar^i= frac{a}{1- r}[/itex].Now, turning to the problem at hand. 0.999... is, by definition of the decimal numeration system, [itex]0.9+ 0.09+ 0.009+ cdotcdotcdot= 0.9+ 0.9(0.1)+ 0.9(0.01)+ cdotcdotcdot= 0.9+ 0.9(.1)+ 0.9(.1^2)+ cdotcdotcdot[/itex], precisely a geometric series with a= 0.9 and r= 0.1. So the sum, and the value of 0.9999..., is [itex]frac{0.9}{1- 0.1}= frac{0.9}{0.9}= 1[/itex].
  66. Nemika says:
    *Both 0.999… and 9.999… are finite numbers; i.e., strictly less than infinity.* How can you call 0.999… or 9.999… as finite? If these are finite then infinity can also be considered finite!
  67. Algr says:
    Proofs #2 & #3 are what convinced me that 1 and .999… are NOT equal.  It's just insulting to assume that .333… = 1/3 in this context.  And why assume that .999… and 9.999… have different numbers of nines when this would never happen for any finite number?
Newer Comments »
