So, by using the formula, we can solve the integral in the previous part.
  • Thread starter teng125
In summary, to solve the problem of finding the integral of (x-2) / (x^2 +2x +3), you can simplify the numerator by writing it in the form 1/2[(2x+2)-6]. Then, you can divide the expression by 1/2 and use the substitution method to solve the integral. The final solution will involve using the fact that the derivative of arctan(x/a) is 1/(x^2 + a^2).
teng125
416
does aanybody knows how to do this: int (x-2) / (x^2 +2x +3 )
pls help...
write the numerator in the form 1/2[(2x+2)-6]
now you get on dividing 1/2 { (2x+2)/(x^2+2x+3) - 6/(x^2 +2x +3)}
for the first part you cand substitute x^2 +2x +3 as t and it will simplify and for the second part make factors (if possible) and use partial fractions or make a perfect square.
PS this is supposed to be a calculus problem.
the answer for second part is arctan (x+1) / sqr root 2...
may i know how do u get it??
In the second part, in the denominator, you have x^2 +2x+3.
Write it as (x+1)^2 + 2.
use the fact that d/dx (arctan(x/a) = 1/(x^2 + a^2)
Are you sure that: d/dx (arctan(x/a) = 1/(x^2 + a^2)? Shouldn't it read:
[tex]\frac{1}{a} \ \frac{d}{dx} \arctan \left( \frac{x}{a} \right) = \frac{1}{x ^ 2 + a ^ 2}[/tex]?
[tex]\int \frac{x - 2}{x ^ 2 + 2x + 3} dx = \frac{1}{2} \ \int \frac{2x - 4}{x ^ 2 + 2x + 3} dx = \frac{1}{2} \ \int \frac{2x + 2 - 6}{x ^ 2 + 2x + 3} dx[/tex]
[tex]= \frac{1}{2} \left( \int \frac{2x + 2}{x ^ 2 + 2x + 3} dx \ - \ \int \frac{6}{(x + 1) ^ 2 + 2} dx \right) = ...[/tex]
This is just what others have shown you typed in LaTeX.
Can you go from here?
Note that:
[tex]\int \frac{dx}{x ^ 2 + a ^ 2} = \frac{1}{a} \arctan \left( \frac{x}{a} \right) + C[/tex]
FAQ: So, by using the formula, we can solve the integral in the previous part.
What is the purpose of the "Int (x-2) / (x^2 +2x +3 )" equation?
The purpose of this equation is to calculate the integral of (x-2) divided by (x^2 +2x +3). It is used in calculus to find the area under a curve.
How do you solve the "Int (x-2) / (x^2 +2x +3 )" equation?
This equation can be solved by using integration techniques such as substitution, integration by parts, or partial fractions. The exact method used will depend on the specific equation and the skill level of the person solving it.
What is the domain and range of the "Int (x-2) / (x^2 +2x +3 )" equation?
The domain of this equation is all real numbers except for x = -1 and x = -2. The range of this equation is all real numbers.
Can the "Int (x-2) / (x^2 +2x +3 )" equation be used for any type of curve?
No, this equation can only be used for continuous functions. It is most commonly used for polynomial functions, but can also be applied to other types of curves such as trigonometric functions.
What is the significance of the constant term in the denominator of the "Int (x-2) / (x^2 +2x +3 )" equation?
The constant term, in this case 3, affects the shape and behavior of the curve. It can determine if the curve has a horizontal or slanted asymptote, if it has any vertical asymptotes, and if it has any x-intercepts. It is an important factor to consider when solving and interpreting this equation.
