Re: carbon steel - Is a crystal the same as a grain?
In summary: Tc superconductors is an example of such a "molecular" conductor. Nonetheless, the original question was a bit of a red herring - metals and alloys are not composed of "molecules" in the traditional sense.
392hemi
I'm still a little confused about crystals and grains. Does a crystal become a grain as the metal solidifies?
I'm also not clear on molecules. For instance with a body centered lattice you have nine atoms. One on each corner and one in the center of the body. So within that lattice -- what determines what a molecule is? Sorry -- I'm sure that's a dumb question.
In a body-centered crystal, each atom on the corner is only counted as 1/8, or in other words is part of 8 unit cells. Go back to your solid state physics book and reread that chapter.
As for the grain problem, I do not know. Anyone else? I'd also like to know.
dt
dt
Sorry -- I've never seen a solid states physics book, much less read one. :smile:
I know very little about physics -- I'm just searching for a little info regarding a specific area of metallurgy. At first, I didn't understand what you meant by 1/8 -- but after thinking about it -- I remember seeing the illustrations of the corner atom cut to an eight and it finally dawned on me. Then I found this web site, which cleared if up with an animated illustration:
http://www.kings.edu/~chemlab/vrml/bcc.html
However, I still don't understand what makes up a steel molecule.
Thanks,
Terry
392hemi said:
"...I still don't understand what makes up a steel molecule."
There's no such thing as a "steel molecule". I'm not sure what the exact definition of a molecule is, but this one should work in almost all cases: For a substance to be made of molecules (a localized group of 2 or more atoms) the vapor phase (or at least the liquid phase) of the substance has to be made of those molecules. This rules out steel because when its heated, the Fe, C and any other atoms that its made of come apart long before they all melt. In fact, it rules out all metals and alloys that I can think of as well as most of the elements (exceptions are O2, N2 etc.).
I would say that a grain is a crystal. There are objects that are made up of a single crystal no matter how large they might be. Most crystalline objects however are made up of small crystals joined together at the boundaries. The orientation of each crystal is different. They are called grains because they resemble the grain seen in wood. So whenever a liquid solidifies, if it forms a crystal it is made up of one or more grains.
This fits well with my understanding of metallic bonding - the nuclei are surrounded by a 'sea' of electrons so there is no 'molecule' to identify, just a repeating pattern of nuclei sites (the unit cell). Basicallly, the concept of molecule has no meaning for metallic bonding. It's useful for covalent & ionic bonding however. A sodium & a chlorine atom make a 'salt' molecule but two iron atoms don't make a metallic unit cell.
Thanks,
Terry
http://er6s1.eng.ohio-state.edu/mse/mse205/lectures/chapter3/chap3.pdf
This site has some background on crystal structures, and why these "grains" are only in polycrystalline materials.
Keep in mind the advise that was given that you do really need to look up a solid state physics text, because the question involved here are the ones covered and answered in a typical solid state physics class.
Yes, this is a perfectly acceptable model - to the first approximation. Keep in mind that "metallicity" can sometime be a rather vague definition. What you described as your understanding of metals is perfectly valid for the "conventional" metals that obey the straightforward band structure model. However, for metals (or more accurately, conductors) that are actually doped insulators, such picture breaks down severely. In that case, you CAN have "molecules" as the material making up the conductor - the Cu-O molecules in the cuprate superconductors for example.
Zz.
I'm sure glad I asked.
I have stacks of books on metalworking, welding and metallurgy. Many of them have mentioned "molecules" when discussing metal. I'm writing a book on hand shaping metal and I wouldn't want to make the same mistake.
FAQ: Re: carbon steel - Is a crystal the same as a grain?
What is the difference between a crystal and a grain in carbon steel?
A crystal is a microscopic arrangement of atoms in a repeating pattern, while a grain is a collection of crystals that are randomly oriented. In carbon steel, grains are formed during the solidification process and can affect the mechanical properties of the steel.
How do crystals and grains impact the strength of carbon steel?
The size and orientation of grains can greatly affect the strength of carbon steel. Large grains can decrease the strength and cause brittleness, while smaller grains can increase strength and make the steel more ductile. The orientation of grains also plays a role in the steel's strength, as grains aligned in the direction of stress can provide greater resistance.
Can carbon steel have both single crystals and multiple grains?
Yes, carbon steel can have both single crystals and multiple grains within the same piece of steel. This is due to the solidification process during manufacturing, which can result in a mixture of grain sizes and orientations in the final product.
How can I control the size and orientation of grains in carbon steel?
The size and orientation of grains can be controlled through various heat treatments during the manufacturing process. For example, rapid cooling can result in smaller grains, while annealing can promote larger grains. The addition of alloying elements can also influence grain size and orientation.
Are grains visible to the naked eye?
No, grains in carbon steel are too small to be seen with the naked eye. They can only be observed under a microscope or through special etching techniques. However, the effects of grain size and orientation can be seen in the overall appearance and properties of the steel.
