How Does Viscous Resistance Affect Object Motion?
In summary, the object covered a distance of 1m in the viscous medium when it was thrown with an initial speed of 20m/s.
hastings
80
An object with mass m=0.1 kg is thrown with an initial speed v0=20m/s in a viscous matter which opposes its motus with a resistance force of F=-Bv (v is the speed and B=2kg/s). Find the distance this object has covered in the viscous matter. Leave aside gravity force.
F=m*a
I tried this way
[tex]\vec F=-\beta \vec v=m \cdot a[/tex]
[tex]\frac{-\beta \vec v}{m}= a= \frac{dv}{dt}=\frac{ds}{d^2t}[/tex]
[tex]\frac{-\beta \vec v}{m} d^2t=ds [/tex]
[tex]\int{\frac{-\beta \vec v}{m} }d^2t=\int ds [/tex]
[tex]\int{\frac{-\beta \vec v}{m} } \cdot t dt=s[/tex]
[tex]\displaystyle{-\frac{1}{2}} \frac{\beta v }{m}t^2+K=s[/tex]
How to continue? Is it right till this point?
Realize that v is not a constant but a function of t. Stick with this:
[tex]\frac{-\beta \vec v}{m}= a= \frac{dv}{dt}[/tex]
Rearrange so that v is on one side and t on the other. Then you can integrate.
you mean like this?
[tex] -\frac{\beta dt}{m}=\frac{1}{v}dv[/tex]
[tex]\int{ -\frac{\beta}{m}}dt=\int \frac{1}{v}dv [/tex]
[tex]-\frac{\beta}{m}t=ln(v)+K[/tex]
How to get K? Should i substitute t0=0s & v0=20m/s?
to get the distance "s", I need a formula with a, t and v
Where do I go with an expression with 2 unknown quantities, v and t?
[tex]-\frac{\beta}{m}t=ln(v)-ln20[/tex]
suppose I do ...
[tex]-\frac{\beta}{m}t+\log20=\log v[/tex]
[tex]\frac{ds}{dt}=v=e^{-\frac{\beta}{m}t+\log20} [/tex]
[tex]\int{ds}=\int{e^{-\frac{\beta}{m}t+\log20} }dt[/tex]
[tex]\int ds=\int (C \cdot e^{\alpha t})dt \ \ \mbox{where \alpha=\frac{-\beta}{m} } \ \mbox{ and C=e^{\log20} }[/tex]
[tex]s=\frac{C}{\alpha}e^{\alpha t}+K_1[/tex]
I assume k1=0; I know all the quantities except t
Looks good to me (with a bit of correction).
You can simplify a bit. For example:
[tex]C=e^{\ln20}[/tex]
What does that equal?
Realize that k1 cannot equal zero if s = 0 at t = 0.
ok, Doc Al. got your message about posting the same topic more than once.
Won't do it again. This is what happened: after waiting a long time I didn't get much help in this section so I tried my luck on some other section - where eventually I got some interesting hint to solve this problem (THANKS A LOT TO "arunbg"!).
Here's what I did
[tex] F_R= -\beta \cdot v=m \cdot a[/tex]
[tex](1) \ a=-\frac{\beta v}{m}[/tex]
[tex](2) \ a=v \frac{dv}{dx} \ \mbox{ infact } \displaystyle{(v \cdot \frac{ \frac{dv}{dt}}{\frac{dx}{dt} } = v \cdot \frac{a}{v} = a)}[/tex]
[tex] v \frac{dv}{dx}= -\frac{\beta v}{m}[/tex]
[tex] \frac{dv}{dx}= -\frac{\beta}{m}[/tex]
[tex]dv=-\frac{\beta}{m} dx[/tex]
[tex]\int{dv}= \ -\int{\frac{\beta}{m}dx}[/tex]
[tex]v=-\frac{\beta}{m}x[/tex]
[tex]x=-\frac{mv}{\beta}[/tex]
[tex]x=-\frac{0.1 \mbox{ kg } (20 \mbox{ m/s})}{2 \mbox{ kg/s}}=-1m[/tex]
I'm not sure whether this is the correct way, but the result is 1m.
[tex]C=e^{\ln 20} \ \Longrightarrow C=20?[/tex]
You are right about k1. with t=0 and x=0 i get
[tex]0=\frac{20}{\alpha} e^{\alpha \cdot 0}+K_1[/tex]
[tex]0=\frac{20}{\alpha}+K_1 \ \Longrightarrow K_1=-\frac{20}{\alpha}[/tex]
Suppose I try with the definite integral...
[tex]a=\frac{dv}{dt}=-\frac{\beta v}{m}[/tex]
[tex]\frac{1}{v}dv=-\frac{\beta}{m}dt[/tex]
[tex]\int_{v_0}^v{\frac{1}{v}}dv=-\frac{\beta}{m} \int_0^t{}dt[/tex]
[tex]\ln v -\ln v_0=-\frac{\beta}{m}t[/tex]
[tex]\ln \frac{v}{v_0}=-\frac{\beta}{m}t[/tex]
[tex]\frac{v}{v_0}=e^{-\frac{\beta}{m}t}[/tex]
[tex]v=\frac{dx}{dt}=v_0e^{-\frac{\beta}{m}t}[/tex]
[tex]dx=v_0e^{-\frac{\beta}{m}t}dt [/tex]
[tex]\int_0^x{dx}= \int_0^t {v_0e^{-\frac{\beta}{m}t}}dt[/tex]
[tex]x=v_0[-\frac{m}{\beta}e^{-\frac{\beta}{m}t}]_0^t=v_0[\frac{m}{\beta}-\frac{m}{\beta}e^{-\frac{\beta}{m}t}]= \frac{m v_0}{\beta}[1-e^{-\frac{\beta}{m}t}] [/tex]
So in the end I get
[tex]x=\frac{mv_0}{\beta} \displaystyle{[1-e^{-\beta t/m }]}[/tex]
How to go foward now? The answer is 1m
What I don't know is the instant (time) this object stops or anyway comes out of the viscous medium. Just a step away from the solution...How do I go on now?
Anybody there to help me? Any suggestion is appreciated.
Here's what I did
This method is fine up until you integrate and decide to omit the constant of integration! The next line should read
[tex]v=-\frac{\beta}{m}x +A[/tex] for some constant, A. Use your initial conditions to find A, then proceed as you did to find x.
Assuming that "t" is endless (of course not negative, never heard of "t=-4s")
[tex]\lim_{t \to +\infty}\frac{mv_0}{\beta} \displaystyle{[1-e^{-\beta t/m }]}= \frac{mv_0}{\beta}[/tex] [tex]= \frac{0.1kg \ (20 \mbox{ m/s})}{2kg/s}=1m[/tex] :approve::smile:
You seem to be doing the entire problem over and over several ways. Nothing wrong with that as long as you realize that any correct way will give you the answer if you stick with it. You had all you needed for the answer in post #5, once you found the correct constant.
hastings said:
So in the end I get
Examining this solution should tell you something about how the object will move. The distance reaches a limit as time goes to infinity.
Take the limit.
There you go. :wink:
Just for fun, if you can stand it, plug in a few values of time (1 sec, 2 sec, etc...) to see that you don't really have to wait forever for the object to go pretty much as far as it will go.
FAQ: How Does Viscous Resistance Affect Object Motion?
1. What is a physics dynamic problem?
A physics dynamic problem is a problem that involves the application of principles and laws of physics to describe the behavior of objects in motion or under the influence of forces. It typically involves solving equations of motion to determine the position, velocity, and acceleration of an object over time.
2. How do you approach solving a physics dynamic problem?
The first step in solving a physics dynamic problem is to clearly identify the physical quantities involved and the relationships between them. This often involves drawing a free-body diagram and applying Newton's laws of motion. Then, equations of motion can be derived and solved using algebraic manipulation and substitution.
3. What are some common types of physics dynamic problems?
Some common types of physics dynamic problems include projectile motion, circular motion, and simple harmonic motion. Other types may involve collisions, applied forces, or changes in gravitational potential energy.
4. How does the use of vectors impact solving physics dynamic problems?
Vectors, which have both magnitude and direction, are often used to represent physical quantities in physics dynamic problems. This allows for a more precise and accurate description of an object's motion. Vector addition and subtraction can also be used to combine multiple forces acting on an object.
5. What are some tips for solving physics dynamic problems efficiently?
Some tips for solving physics dynamic problems efficiently include breaking the problem down into smaller, more manageable steps, using clear and organized notation, and checking for units and significant figures in calculations. It can also be helpful to work backwards from the answer and to practice using different problem-solving strategies.
