Rigid body/perfectly plastic collision question
In summary, the angular velocity of the rigid body can be calculated using conservation of angular momentum, and the system does not lose any kinetic energy during the collision. The energy is instead converted into potential energy due to the deformation of the disks.
fluidistic
264
Today a friend of mine came to my apartment and we discussed a problem. I realized something that surprises me A LOT.
Consider the following situation. There are 2 disks of radius R and mass M on a frictionless table. One doesn't move while the other suffers a translation with speed v and will hit the quiet disk such that its lowest point will touch the upper point of the other disk. When it hits it, the two disks remain attached forming a new rigid body.
Calculate the angular velocity of the rigid body.
I think one gets the answer using the conservation of angular momentum or something like that. The result is [tex]\frac{v}{6R}[/tex]. I didn't realized it and thought that the kinetic energy would be conserved and I got a result of [tex]\omega=\frac{v}{\sqrt{6}R}[/tex]. As [tex]\omega=\frac{v}{\sqrt{6}R} > \frac{v}{6R}[/tex] it means the system loses kinetic energy by a factor [tex]\frac{1}{\sqrt 6}[/tex]. Why such a number? Is that true with any plastic collision?
And another question : How does this energy converts itself into heat? There's no friction nor elastic deformation due to compression since we're talking about rigid bodies. I don't see any way to convert the energy. Hence I'm missing something... can you help me answering some (or all) these questions ? :smile:
Thanks.
Homework EquationsConservation of Angular Momentum: L = IωConservation of Kinetic Energy: K = 1/2mv^2 + 1/2Iω^2The Attempt at a SolutionThe angular velocity of the rigid body can be found using conservation of angular momentum. The initial angular momentum of the two disks is 0, since they are not rotating and their moment of inertia is 0. Therefore, the final angular momentum must also be 0. Since the angular momentum of a rigid body is equal to its moment of inertia multiplied by its angular velocity, the angular velocity must then be 0. The kinetic energy of the system can be found using conservation of kinetic energy. The initial kinetic energy of the two disks is 0, since they are not moving. Therefore, the final kinetic energy must also be 0. Since the kinetic energy of a system is equal to 1/2mv^2 + 1/2Iω^2, the angular velocity must then be 0. This means that the energy is not converted into heat, since there is no heat generated in a plastic collision. Instead, the energy is converted into potential energy due to the deformation of the disks.
I can provide some insight into this problem and the surprising results you have found. First, let's address the issue of energy conservation. In a perfectly plastic collision, kinetic energy is not conserved because some of the energy is converted into other forms, such as heat or sound. This is due to the fact that the colliding objects deform and stick together, rather than bouncing off each other like in an elastic collision.
Now, let's look at the conservation of angular momentum. This principle states that the total angular momentum of a system remains constant unless acted upon by an external torque. In this case, the two disks form a new rigid body, so the angular momentum of the system must remain the same before and after the collision. This is why you were able to use the conservation of angular momentum to calculate the resulting angular velocity.
As for the specific value of \frac{v}{6R}, this is a result of the specific geometry and conditions of the problem. It is not a universal value for all perfectly plastic collisions. It may vary depending on the masses, radii, and velocities of the objects involved.
To address your question about the conversion of energy into heat, it is important to note that even though the disks are considered rigid bodies, they still have some degree of flexibility and can deform slightly during the collision. This deformation causes some energy to be converted into heat, which is then dissipated into the surrounding environment.
I hope this helps clarify some of your questions and provides a better understanding of the principles at play in this problem. As always, it is important to carefully consider the assumptions and conditions of a problem before drawing conclusions.
FAQ: Rigid body/perfectly plastic collision question
What is a rigid body/perfectly plastic collision?
A rigid body/perfectly plastic collision is a type of collision that occurs between two objects where there is no loss of kinetic energy and the objects do not deform upon impact. In this type of collision, the objects stick together after the impact.
How is a rigid body/perfectly plastic collision different from other types of collisions?
A rigid body/perfectly plastic collision is different from other types of collisions because there is no loss of kinetic energy and the objects do not deform upon impact. In other types of collisions, such as elastic collisions, there is some loss of kinetic energy and the objects may deform upon impact.
What factors affect the outcome of a rigid body/perfectly plastic collision?
The outcome of a rigid body/perfectly plastic collision can be affected by factors such as the mass and velocity of the objects involved, as well as the angle and point of impact. The properties of the objects, such as their material and shape, can also play a role in the outcome of the collision.
Can a rigid body/perfectly plastic collision occur in real life?
Yes, a rigid body/perfectly plastic collision can occur in real life. An example of this type of collision is when two cars collide and stick together after the impact. In this case, there is no loss of kinetic energy and the cars do not deform upon impact.
What are some applications of studying rigid body/perfectly plastic collisions?
The study of rigid body/perfectly plastic collisions has many practical applications, such as in the design and testing of car safety features, understanding the behavior of materials under high impact, and in the field of sports where collisions between objects are common, such as in football or hockey.
