Some subtleties regarding Impedance
  • Thread starter Oren Becker
  • Tags
    Impedance
In summary: But this is a higher-level circuit analysis technique, beyond the scope of an introductory course. In summary, we discussed the concept of impedance and how it can be derived for an inductor using phasors and Fourier analysis. We also addressed the issue of omitting the constant of integration in the derivation and how it assumes certain initial conditions for the current. Additionally, we mentioned the limitations of using sinusoids as basis functions for analyzing circuits and briefly touched on the use of Laplace transforms for more advanced circuit analysis.
Oren Becker
Hello.
I am taking a first year electricity and magnetism course.
In class, the following was taught:
a. What is the impedance of an inductor?
b. What is the total impedance of 2 components connected serially?
But only at home I realized that I don't understand some of the derivation.
Vp - Voltage at peak.
L - Inductance.
w - angular frequency
theta - phase
I was able to derive the impedance of a resistor and a capacitor using phasors.
I had a problem with the derviation for an inductor:
dI/dt = (Vp/L) * exp(j * (wt - theta))
At this point the professor integrated both sides, but did not add a constant of integration. As much as I understand, this is equivalent to the assumption that when the voltage is zero, the current is also zero. Is this assumption really necessary and what is its justification?
Regarding 2 components connected serially:
We where told this is analogous to resistance and resistors. Trying to understand this, I wrote:
V1 + V2 = V = Vp * exp(j * (wt - theta))
I1 = I2 = I
Therefore: Vp * exp(j * (wt - theta)) = V = Z1*I + Z2*I = (Z1 + Z2) * I
which implies that the total impedance really is Z1+Z2.
But the whole concept of impedance was developed assuming that the voltage across the component looks like: Vp * sin(wt - theta). But here, all the information I have is that the sum of the voltages is in that form. I don't see why each of them is of that form, and therefore I don't understand the justification for this derivation.
Thanks in advance for your help,
Oren.
I'll post again, addressing your problem directly, in a minute. But first I want to point out that the impedance of an inductor can be derived in such a way that does not assume anything about the initial conditions other than that the current is sinusoidal. If we have:
[tex] v_L(t) = L \frac{d}{dt}[i_L(t)] [/tex]​
And these are both arbitrary functions of time, then we can define some other function of time zL(t) such that:
[tex] z_L(t) = \frac{v_L(t)}{i_L(t)} = L \frac{ \frac{d}{dt}[i_L(t)]}{i_L(t)} [/tex]​
At this point there are two equivalent things you can do:
1. You can say that we are dealing with AC circuits and therefore the current is of the form [itex] i_L(t) = I_0 e^{i (\omega t + \phi)} [/itex]. Here I have used "i" instead of "j", because "j" (the electrical engineering convention) bugs me.
2. You can take the Fourier transform of both sides of the equation, so that you are going from looking at signals in the time domain to looking at them in the frequency domain (i.e. looking at the complex impedance Z(ω), as well as I(ω) and V(ω), all of which are phasors).
Approaches 1 and 2 are equivalent, because what Fourier analysis says is that any signal (i.e. any function of time) can be constructed as a combination of sinusoids (i.e. complex exponentials) of varying frequencies at varying amplitudes and phases. Therefore, without any loss of generality, you can say that the input has this sinusoidal form, and ask the question, what does the output look like as a function of an input at this frequency ω? A good way of thinking about it is that you are computing the frequency response of the system, i.e. how the system responds to an input at a given frequency. If you input a certain signal v(t) at a given frequency ω, the frequency response tells you by how much the output i(t) has been phase shifted and attenuated (or amplified) by the system. In this case, "the system" is just an inductor. However, this approach applies to more complicated linear circuits, which can be characterized by their frequency response (also sometimes called a transfer function), H(ω), defined as output/input (in the frequency domain). So, in this case, the output is being taken to be the current across the inductor, and the input is being taken to be the voltage, making H(ω) = 1/Z(ω).
Since these two approaches are equivalent (either one will tell you how the component attentuates and phase shifts signals of frequency ω as a function of ω), we can make the substitution:
[tex] Z_L = L \frac{ \frac{d}{dt}[I_0 e^{i (\omega t + \phi)}]}{I_0 e^{i (\omega t + \phi)}} [/tex]
[tex] Z_L = L \frac{i \omega I_0 e^{i (\omega t + \phi)}}{I_0 e^{i (\omega t + \phi)}} [/tex]
[tex] Z_L = i \omega L[/tex]​
An inductor phase shifts current by π/2 (which comes from the factor of i) relative to the voltage across it and attenuates higher frequency signals more than lower ones. This is the frequency response of an inductor.
To address your problem directly:
Omitting the constant of integration doesn't assume that i = 0 when v = 0. What it assumes is that when t = 0, the current is given by the same initial phase as the voltage + π/2, and its amplitude is attenuated from that of the voltage by the expected amount. In other words, you are assuming certain initial conditions for the current.
You could certainly add in a constant of integration, C. However, since these are complex-valued functions, C is an arbitrary complex number. Therefore, there is nothing preventing you from writing:
C = A/(iωL), where A is some other arbitrary complex constant. Doing so means that the whole expression is still divided by iωL, and we get the result we expect.
Part of the problem here is that the functions we are using here as basis functions in the Fourier synthesis, namely sinusoids (or complex exponentials), are defined so that they are present for all time (they always have been oscillating and always will). If you want to know precisely how the current in an inductor will evolve with time given that a sinusoidal voltage is suddenly turned on at t = 0, then Laplace transform methods are more convenient than Fourier transform methods.
Related to Some subtleties regarding Impedance
1. What is impedance and why is it important in science?
Impedance is the measure of opposition to the flow of an alternating current (AC) in a circuit. It is important in science because it helps us understand how electricity behaves in different materials and components, allowing us to design and troubleshoot electronic systems.
2. How is impedance different from resistance?
Resistance is the measure of opposition to the flow of direct current (DC) in a circuit, while impedance takes into account both resistance and reactance (the opposition to AC caused by capacitance or inductance). In other words, impedance is a more comprehensive measure of the overall opposition to current flow.
3. How does impedance affect the performance of electronic devices?
Impedance plays a crucial role in the performance of electronic devices. It affects the flow of current, voltage, and power in a circuit, which can impact the efficiency, stability, and accuracy of electronic systems. Understanding and controlling impedance is essential for optimizing the performance of these devices.
4. What factors can affect the impedance of a circuit?
The impedance of a circuit can be affected by several factors, including the type of material used, the length and thickness of conductors, the presence of capacitors or inductors, and the frequency of the AC signal. Changes in any of these factors can impact the overall impedance of a circuit.
5. How can impedance be measured and calculated?
Impedance can be measured using specialized equipment such as an impedance analyzer or an oscilloscope. It can also be calculated using Ohm's Law, which states that impedance is equal to the voltage divided by the current in an AC circuit. In more complex circuits, impedance can be calculated using mathematical formulas and circuit analysis techniques.
