Deadstar
- 104
An ideal fluid is rotating under gravity g with constant angular velocicy [tex]\Omega[/tex], so that relative to the fixed Cartesian axes [tex]\mathbf{u} = (-\Omega y, \Omega x, 0)[/tex]. We wish to find the surfaces of constant pressure, and hence the surface of a uniformly rotating bucket of water (which will be at atmospheric pressure).
'By Bernoulli,' [tex]p/\rho + \mathbf{u}^2/2 + gz[/tex] is constant so the constant pressure surfaces are
[tex]z = \textrm{constant} - \frac{\Omega^2}{2g}(x^2 + y^2)[/tex].
But thes means that the surface of a rotating bucket of water is at the highest in the middle. What is wrong? (Done, not my question)
Write down the Euler equations in component form, integrate them directly to find the pressure, and hence obtain the correct shape for the free surface.
Euler equations
[tex]\frac{D \mathbf{u}}{Dt} = -\frac{1}{\rho} \nabla p + \mathbf{g}[/tex]
and in component form.
[tex]\frac{\partial u}{\partial t} + u\frac{\partial u}{\partial x} + v\frac{\partial u}{\partial y} + w\frac{\partial u}{\partial z} = -\frac{1}{\rho}\frac{\partial p}{\partial x}[/tex]
[tex]\frac{\partial v}{\partial t} + u\frac{\partial v}{\partial x} + v\frac{\partial v}{\partial y} + w\frac{\partial v}{\partial z} = -\frac{1}{\rho}\frac{\partial p}{\partial y}[/tex]
[tex]\frac{\partial w}{\partial t} + u\frac{\partial w}{\partial x} + v\frac{\partial w}{\partial y} + w\frac{\partial w}{\partial z} = -\frac{1}{\rho}\frac{\partial p}{\partial z} - g[/tex]
I get that the above component form becomes...
[tex]\Omega x \frac{\partial u}{\partial y} = -\Omega^2 x = -\frac{1}{\rho}\frac{\partial p}{\partial x}[/tex]
[tex]\Omega y \frac{\partial v}{\partial x} = -\Omega^2 y = -\frac{1}{\rho}\frac{\partial p}{\partial y}[/tex]
[tex]g = -\frac{1}{\rho}\frac{\partial p}{\partial z}[/tex]
So now I just sort of... integrate and combine them together. I'm not sure whether I can do this though, integrate each line seperatly and add it all together (as each is a component of the total pressure..?)
So I get...
[tex]-\frac{p}{\rho} = -\frac{\Omega^2}{2}(x^2 + y^2) + gz + constant[/tex]
which is pretty close to what I'm after however I'm guessing something has gone wrong at the integration step. Anyone care to assist?
For finding the shape is it just a case of setting [tex]p/\rho[/tex] equal to zero?
