Centrifugal force in high pressure vessel
In summary: So, 3000 psi ---> 200N, not 2000N, and the final pressure will be 20,000 psi.In summary, an enclosed cylindrical vessel holding two pounds of fluid at ambient atmospheric pressure and being spun at 30,000 rpm's will experience a centrifugal force that creates a pressure of 1,000 psi. If the vessel is pre-pressurized to 3,000 psi before being spun, the resulting force will not be 4,000 psi but rather 20,000 psi according to Dalton's partial pressure law. This is due to the increase in the number of molecules and the direct proportionality of pressure to the number of molecules.
drewman13
An enclosed cylindrical* (disc) vessel one inch thick and five inches in radius holding two pounds of fluid at ambient atmospheric pressure (14psi?)and being spun at 30,000 rpm's. Assume the centrifugal force acting on the fluid creates a pressure of 1,000 psi. The question is ...
"If the vessel is pre-pressurized, to say 3,000 psi, before it is spun up to 30,000 rpm's, will the centrifugal force add pressure to the already pre-pressurized (3,000 psi) vessel?"
Would the resultant force then be 4,000 psi? If not, what would the total psi be and why?
Use Dalton's partial pressure law.
He didn't say the vessel was pressurized with gas.
If it is so, then the pressure of the gas will depend on the position from where it is being measured.
Due to rotations, the gas will be displaced toward the outer side. And the pressure of the gass will gradually increase when we move from ceter of rotation to the extreme of the daimeter.
Yes, I'm with aekanshchumber, and I'll give him an additional support for his opinion writing a few equations:
Inside the vessel, and choosing a reference frame spinning with it, the Navier-Stokes equations yield:
[tex] \frac{\partial P}{\partial r}=\rho\omega^2 r[/tex] in Hydrostatic form.
Solving for P(r) you will obtain the pressure distribution. The constant resulting of the last equation has to depend on the initial value in the case of a closed vessel, where no boundary constraint is possible to satisfy.
Maybe, the unsteady process is harder [\B] of analyzing due to a progressive acceleration of the fluid is necessary. The kinematic field has to be solved firstly before doing any comment about the pressure at the very first instants. I don't think such a simple rule as drewman13 has stated would be correct for figuring the total pressure out.
The pressure will surely increase, but it will not be 4000psi.
Remember that the pressure is proportional on the no of molecules. So for a fixed volume (of the cylinder, V) at 1.4psi if the Number of moecules be N, then at 3000 psi it will be around 2000N.
Now if N molecules generated a 1000psi pressure when gyroscoped @ 30000rpm, then 2000N molecules will generate 2000 x 1000psi at same rpm. I imagine they are proportional however they may not be directly proportional. But logically and from Classical kinetic theory they are likely to be directly proportional.
So you can imagine the net pressure to be humongous 2,000,000 psi.
The logic sounds good but the starting pressure was 14 psi, not 1.4 psi.
So, 3000 psi ---> 200N, not 2000N, and the final pressure will be 200,000 psi.
OPPS..thanks for correcting me.
FAQ: Centrifugal force in high pressure vessel
What is centrifugal force in a high pressure vessel?
Centrifugal force is the outward force that is exerted on an object as it rotates within a high pressure vessel. It is caused by the object's inertia and the vessel's walls, and it is proportional to the object's mass and angular velocity.
How does centrifugal force affect materials in a high pressure vessel?
Centrifugal force can cause materials within a high pressure vessel to move away from the center of rotation, creating a pressure gradient and increasing the pressure at the walls. This can lead to structural stress and potential failure of the vessel if not properly accounted for.
How is centrifugal force calculated in a high pressure vessel?
The formula for calculating centrifugal force in a high pressure vessel is F = mrω^2, where F is the centrifugal force, m is the mass of the object, r is the distance from the axis of rotation to the object, and ω is the angular velocity.
What factors can affect centrifugal force in a high pressure vessel?
The magnitude of centrifugal force in a high pressure vessel can be affected by the object's mass, angular velocity, and distance from the axis of rotation. Additionally, the shape and size of the vessel and the material properties of both the vessel and the object can also play a role.
How can centrifugal force be controlled or minimized in a high pressure vessel?
To control or minimize centrifugal force in a high pressure vessel, engineers can use design techniques such as balancing the mass distribution, adjusting the shape of the vessel, and using materials with high strength and stiffness. It is also important to properly calculate and account for centrifugal force in the design process.
