Finding real and complex factors of polynoms
In summary, Noorac was trying to factoring complex polynomials but was having trouble. She was helped by Wukunlin who told her how to approach the task and solved it.
Noorac
Hi. I'm having some trouble factoring complex polynomials. I'm sure it's very easy assignments, but I'm missing some key-information as to how to solve these tasks.
Tasks:
The task is to find the complex and real factors of the polynomials(since I'm not that articulate in english I will provide the answer for the first task, just so it's easier to see what type of answers the task is looking for)
a) z3 + 8
b) z4 - 1
c) I will provide this one if I still don't get it.
(I decided to list two tasks since I find that it is easier to compare the solution to different tasks than to just try and understand how one solution works. However, at this point I'm happy with any help I can get, since I'm pretty much stuck).
Answer:
a) (z + 2)(z - 1 - i[itex]\sqrt{3}[/itex])(z - 1 + i[itex]\sqrt{3}[/itex]) = (z + 2)(z2 - 2z + 4)
(Side note: i = [itex]\sqrt{-1}[/itex])
PS: telling me how to approach the task and solve it is just as good(if not better), than just solving the task. Then I can actually try to solve it myself.
Thanks, Noorac=)
umm... I'm not sure why you (or they) want to factorize these polynomials, persoanlly I find it easiest to do the following: (I'll use a) as an example)
1) make [tex]z^3=-8[/tex]
2) you will have the most obvious solution, ie z = -2 or z+2=0
3) use long division to perform [tex]\frac{z^3}{z+2}[/tex] and you should obtain the other factor
another method is to draw the most obvious solution on an argand plane. The amount of solutions of the polynomial is equal to the highest power of z, and all solutions have the same modulus and same angular spacing to each other, you can then work out the complex roots that way
Wukunlin:
(The reason to finding the factors are non other than practice, it's a task taken from my textbook).
I've tried a), and as far as I know, made it, yet I can't make it for the other ones(b).
Heres how i solved a)
z3 + 8 => [itex]\sqrt[3]{8}[/itex]ei*[itex]\frac{pi}{3}[/itex] = 2(cos[itex]\frac{pi}{3}[/itex] + i*sin[itex]\frac{pi}{3}[/itex]) = 1 + i[itex]\sqrt{3}[/itex]
Wich has gotten me a bit closer to the solution(the complex root). The answer is on the form:
Cn(z - r1)(z - r2)...
And since this is a real polynomial, the conjugent(is this the right english word for switching the sign infront of the complex part of the equation?) is also a root, meaning I have:
Cn(z - (1 + i[itex]\sqrt{3}[/itex]))(z - (1 - i[itex]\sqrt{3}[/itex])). Now, all I need to find out is what Cn is. How?
For the real factor, I just decided to take the third root of z3 + 8 = z + 2
and perform long division(I'll spare the actual division):
z3 + 8 : z + 2 = z2 - 2z + 4
This gives me the correct real factor: (z + 2)(z2 - 2z + 4)
Is this the correct way to solve this? Or is there a more elegant way? If it is correct, I still have trouble doing b)
Edit; spelling errors
[itex]C_n[/itex] I believe corresponds to the coefficient of z in this case (1)
you pretty much did what I meant to say, except in your first line, you could have set the argument to 0 instead of [itex]\frac{\pi}{3}[/itex]
then when you do the long division you will get [itex](z^2 - 2z + 4)[/itex], and then you could find the other 2 roots using the quadratic formula
conjugate, is the word
and its worth remembering any complex roots will always come in conjugate pairs as well
i find a good way is to write it is as
[tex]z^3+8 = 0 [/tex]
then re-arrange and write in complex polar form [itex] z=re^{i \theta}[/itex]
[tex]z^3=r^3e^{i 3 \theta}=-8 [/tex]
from there, you should be able to find the thetas that only give real values in the exponential
[tex] 3 \theta = n \pi[/tex]
[tex] \theta = n \frac{\pi}{3}[/tex]
[tex] n =0,1,2[/tex]
and the corresponding r should follow
FAQ: Finding real and complex factors of polynoms
What is a polynomial?
A polynomial is an algebraic expression consisting of variables, coefficients, and exponents. It can have any number of terms and the terms can be combined using addition, subtraction, multiplication, and division.
What is a real factor of a polynomial?
A real factor of a polynomial is a term that, when multiplied with other terms in the polynomial, results in a real number. In other words, it is a term that can be factored out of the polynomial without leaving any complex numbers.
What is a complex factor of a polynomial?
A complex factor of a polynomial is a term that, when multiplied with other terms in the polynomial, results in a complex number. In other words, it is a term that cannot be factored out of the polynomial without leaving some complex numbers.
How do you find the real factors of a polynomial?
To find the real factors of a polynomial, you can use the method of synthetic division or long division. Both methods involve dividing the polynomial by a potential factor and checking if the remainder is equal to zero. If it is, then the potential factor is a real factor of the polynomial.
How do you find the complex factors of a polynomial?
To find the complex factors of a polynomial, you can use the quadratic formula or the method of completing the square. Both methods will give you the roots of the polynomial, which are the complex factors. You can also use a graphing calculator to graph the polynomial and find the complex roots by locating the points where the graph intersects the x-axis.
