Explaining a Paradox in Modern Physics
In summary, the paradox discussed is about a right angled lever with arms of equal length, constrained to rotate about its bend point and with two transverse forces of equal magnitude acting at the tips of each arm. The net torque is zero and the lever remains at rest. However, when viewed by an observer traveling at a speed of 0.866c along an axis parallel to one of the arms, the arm and force parallel to the motion are reduced by one-half while the other arm and force are unaffected, resulting in a net torque on the system. The solution is that in the observer's frame, work is being done by one of the forces and this energy increase is invested as a rise in mass that exactly counters the torque. However,
genxhis
37
i didn't quite understand the resolution to this paradox as explained by my modern physics book. in case anyone hasn't heard of this, let me explain the setup. there is a right angled lever (with arms of equal length) which is constrained to rotate about its bend point. in addition, there are two transverse forces (of equal magnitude) acting at the tips of each arm. thus the net torque is zero and the lever remains at rest. but how does this look like to an observer traveling at speed v = 0.866c (gamma = 2) along an axis parallel to one of the arms? for the observer, both the arm parallel to the motion and its respective force are reduced by one-half. the other arm and force are unaffected. the result is that there now appears to be a net torque on the system. the solution is that the from the observer's frame work is being done by one of the forces and this energy increase is invested as a rise in mass that exactly counters the torque.
a couple of points i don't understand. (1) there must be a force at the center of the lever that constrains it to rotations. doesn't this force contribute to the work done? (2) how can the mass of the lever be rising if the natural frame measures no such change? isn't rest mass supposed to be an invariant?
I’m not sure about this situation, but it might be that because in the moving frame, one of the levers is compressed while density is the same, its mass increases creating a larger moment of inertia, decreasing Net torque to 0. I’m not sure though, I’m assuming that the measured mass changes for the person in the moving frame. I might be wrong.
It’s an interesting question. I'm also interested in the answer.
Regards,
Nenad
How does traveling observer measure the force? Wouldn't it be by the deflection of the arms as they bend ever so slightly.
That means the "changing" distance of deflection is not on the same arm that is "reduced by one-half".
the change in the forces by changing reference frames is a given. actually, its presumbly based on the lorentz transformations (where F = dp/dt) and shouldn't be too difficult to derive.
Maybe I'm screwing this up - but it seems to me that one arm shrinks and it's force does not shrink, will the other arm does not shrink, but it's force does.
it looks like your thinking under the false presumption that the transformation simply contracts those components of force parallel to the motion.
Think about your direction with respect to the lengths and forces acting upon both arms. You are traveling parallel to one arm, but perpendicular to the force acting upon it. The opposite is true for the other arm. Does that help?
Gee, you're going to make me actually think about this...
OK, the 4-force in the rest frame should be
(0, fx, fy, fz)
Boosting in the x direction, the Lorentz transform should be
(-gamma*v*fx/c^2, gamma*fx,fy,fz)
OK, that seems to say that you're right, the force in the direction of boost should increase
Don't worry about the 'force' in the center of the lever. It is irrelevant.
I'm not sure I see how that helps.
I've been thinking that maybe the angular momentum and torque need to be reformulated as bi-vectors (using the wedge product, not the cross product), but I'm not quite sure how to do it.
[add]
I think I see how to do it, and I think it solves the problem.
The bivector for torque can be represented by (force) ^ (distance), where (force) is the one-form representing the force, and (distance) is the one-form representing the distance. (You can pick (force)^(distance) or the negative of that, (distance)^(force), but you have to be consistent - the wedge product is anti-commutative).
The wedge product ^ generates a second rank anti-symmetric tensor from the two one forms, and the two torques generated by the problem statement are equal and opposite. So torque isn't a vector in GR, - it's a second rank anti-symmetric tensor, a bi-vector. Thus you don't get the right results when you think of torque as a vector and transform it as such, but you do when you use bi-vectors, which are geometric objects.
the following URL discusses the wedge product a little bit, but it may not be enough to explain it to someone who hasn't seen it before
http://icl.pku.edu.cn/yujs/MathWorld/math/w/w054.htm
This may also help
http://www.av8n.com/physics/area-volume.htm
I think one has to work with one-forms rather than vectors, but with a Minkowski metric the two are very closely related - one simply takes g_ab u^a to convert u^a to the one form u_b, and with a Minkowski flat space-time (a Lorentzian metric), this means that one simply inverts the sign of the first component of the 4-vector.
That's about as clearly as I can describe it, anyway. I suspect there's a way to do the wedge product with 4-vectors rather than one-forms, but it seems that the standard defintion uses one-forms.
Length and forces are vectors. The original question was directionally confused. The applied forces are vectors, not masses [that is a mixed reference frame]. They are aligned 90 degrees apart from one another and rotate symmetrically. The vector products are not important. Your first intuition was essentially correct.
I really think the ultimate problem is that the cross product is only defined in 3 dimensions. The relevance of this fact is, of course, that torque = force (cross) distance. The mathematical equivalent of the 3-dimensional cross product in 4 dimensions is the wedge product/ bi-vector. The bi-vector approach works in three dimesnsions, too - but in 3d, one can take the dual (Hodges dual) of the bi-vector to get an ordinary vector. In 4d, the dual of a bivector is another bivector, so one can't reduce the bi-vector to an ordinary vector.
These ideas all best described by Clifford algebras, which I learned (as much as I did learn) from the WWW, and not from a textbook, giving me a "seat of the pants" approach to the whole topic.
Writing out the components of the bi-vector (which is just an anti-symmetric tensor) might (or might not) help illustrate how it works
the bi-vector in the original frame for fx^ry looks like this (f=force, L=length)
[tex]
\begin {array}{cccc} 0&0&0&0\\\noalign{\medskip}0&0&-1/2\,fL&0\\\noalign{\medskip}0&1/2\,fL&0&0
\\\noalign{\medskip}0&0&0&0\end {array}
[/tex]
And when it's boosted (beta=v/c, applied in the x direction) it looks like this (this is just the usual tensor transformation rule)
[tex]
\begin {array}{cccc} 0&0&1/2\,{\frac {fL\beta}{\sqrt {1-{\beta}^{2}}}}&0\\\noalign{\medskip}0&0&-1/2\,{\frac {fL}{\sqrt {1-{\beta}^{
2}}}}&0\\\noalign{\medskip}-1/2\,{\frac {fL\beta}{\sqrt {1-{\beta}^{2}
}}}&1/2\,{\frac {fL}{\sqrt {1-{\beta}^{2}}}}&0&0\\\noalign{\medskip}0&0
&0&0\end {array}
[/tex]
(The two bi-vectors for fx^ry and rx^fy are the same except for the sign - they are additive inverses).
pervect said:
I really think the ultimate problem is ...
As I said in post 3 - assume you can measure the force by the deflection of the Arms. The deflection of the "shorter" arm will be unchanged.
the deflection of the still long arm will be shorter.
How much more info is needed?
RB
RB
I'm really not sure if you can define the force by the deflection of the arm.
I think it's best to stick with the formalism. The 4-force is defined as dP/dtau, where P is the energy-momentum 4-vector.
IF we know the total momentum of the system P summed over some spacelike hypersurface representing a time T we can find the momentum of the system P' on another spacelike hypersurface represnting the time T' by summing up the 4-forces F = dP/dtau multipled by the time interval dtau for all particles representing the system
Note that we sum over dtau, not dt - dtau is the proper time it takes each particle to move from the hypersurface representing the system at T to the hypersurface representing T'.
For the angular momentum of the system, the calculation is similar
The angular momentum bi-vector L should be given by summing up P^r, where P is the energy-momentum 4 one-form, and R is the radius one-form (and ^ is the wedge product). The angular momentum of the system is performed by doing this sum, again, over some space-like hypersurface representing "the system" at some time T.
The total change in angular momentum L over the time interval from T to T' is then the intergal of F^r dtau, just as the linear momentum change was the intergal of F dtau. That happens because F*dtau = dP, by defintion, and tau is a scalar.
All we need to argue now is that internal forces can't cause the momentum or the angular momentum of the system to change.
to be honest, I'm rather lost in all this 4-space formalism. if you manage to figure it out, could you guys explain it in terms of 3-dim in each frame?
the following sources suggest that net internal torques can exist and are in fact neccesary to the resolution of this paradox:
http://scitation.aip.org/getabs/servlet/GetabsServlet?prog=normal&id=AJPIAS000043000007000615000001&idtype=cvips&gifs=yes
http://panda.unm.edu/Courses/finley/P495/TermPapers/relangmom.pdf (page 17)
Bi-vectors aka two-forms are really very useful. They can be intuitively thought of as directed areas. A few sources that talk about them online are
http://phy1139-862.rit.edu/blog/mathematics/index.php
http://www.mrao.cam.ac.uk/~clifford/introduction/intro/node4.html#SECTION00022000000000000000
http://planetmath.org/encyclopedia/Bivector.html
They will be well worth your time.
I can't read the first URL above without a subscription, alas. The second URL seems to contain mostly a much clearer exposition than mine of angular momentum as a bi-vector aka a 2-form. I do see that it mentions your point about internal torque at the end of the paper, but it doesn't really explain it very well.
thanks. the middle website gave a nice, rough overview of generalized (?) vectors.
i went to the library and read the first article (in the American Journal of Physics). it purports that the solution to the problem is in fact very simple. any partition of the lever into small pieces means each piece must have a balanced set of forces acting on it to remain at rest. but a set of forces balanced in one inertial frame is also balanced in any other (though in general their orientations and magnitudes may change). to resolve the paradox, just transform the internal forces along with the external ones. in addition to the net external torque, there will be a net internal torque which will precisely cancel the former. classically however we rarely observe a net internal torque and i would presume this arises from the low speeds of the bodies involved. still, that begs the question precisely why that is?
of course, this solution contradicts that given by my modern physics text and that is always a little disturbing. especially considering the book explicitly states its solution was first given by Max von Laue, a nobel laureate.
But the force is already well defined within it own reference frame, and those forces will directly account for 100% of the deflections - within that frame.
SO - If with a construct like a 4-space “formalism” you can track all the measurements through “hyperspace” great! But at the end of the day once you have the “4-space formalism” right. Please check your work by using it to, as genxhis requested, describe in 3-dimensions within the time frame of the traveler's reference frame, all the observations there of force and deflections.
Well, I was having some problems even visualizing the internal forces on the system, unitl I hit on the expedient of adding a "brace" from one end of the L shaped rod to the other, making it a triangle, and making the all the hinge points a pviot joint.
I think we can get rid of anything but tension and compression forces this way, i.e. we can analyze the problem as beams in compression and tension, and get rid of all the torsion forces at the joints (which can rotate freely). A real beam might have a tendency to buckle, but I think we can idealize that out of the problem.
So we should wind up with a nice loop of forces. I haven't really worked the problem out in detail, though.
Here's the basic issue, as I see it. In the rest frame, none of the forces are doing any work - since the velocity is zero, force*velocity is zero. In the moving frame, this is not the case - some of the forces ARE doing work. (There is no net work done on the system as a whole - but the forces that point in the direction that the system is moving are doing work on parts of the system, work that is canceled out by the opposing forces doing negative work on other parts of the system).
Energy and momentum interconvert, just like time and space do. So the work that these forces are doing in the moving frame shows up as momentum in the rest frame, and vica-versa. This is why I think the 4-space formalism is needed.
Handwaving, since work is being done on one part of the system, and is being extracted from another part, there must be a flow of energy through the system in the moving frame. This "flow" has to be accounted for when calculating the total system momentum / angular momentum.
Sorry don't see where it can be shown that the moving observer will view any work being done by any part of the system being looked at.
The system is as static to him as it is the those in the stationary ref frame.
actually, there is no need for energy flow (or at least it is indistinguishable from a rest case). take any slice of the lever. it must have a balanced set of forces acting on it in either frame. thus, there will be no net energy flow into or out of the slice. more generally, we will not observe any fluctuations in the mass-energy of the system as viewed from either frame.
OK, I've got some more results, this is about as simple as I can make it, and it doesn't even use bivectors :-).
We know that a body Lorentz contracts in the direction of motion when we view it in a Lorentz frame.
We also know that forces transform differently - the force in the direction of motion remains unchanged, while the force perpendicular to the direction of motion is smaller.
This is counter-intuitive - see for instance the paper previously mentioned (by another poster)
or consider that 4-forces transform like 4-vectors, and that a force can be obtained by taking the spacelike component of the 4-force, dp/dtau, and divinding by dtau/dt to get dp/dt. dtau/dt is, of course, the time dilation factor gamma.
Given this set of circumstances, consider a L-shaped structure of beams, with all the beams connected by hinges. (The beams are actually straight, ignory the wobbly ascii!).
Code:
x--------x
x
Consider an aragment of forces that puts the diagonal beam in compression. This consists of pusing "down" on the upper arm, and "to the right" on the vertical arm, while holding the pivot point steady (this requires a third, diagional, force). It may be instructive to draw a force diagram and see why the diagonal beam is in compression, and the other two beams are in tension.
Now consider a pair of adjacent atoms on the diagonal beam, oriented on a line follwoing the diagonal. The attached diagram shows how the orientation of the beam and the forces transform. Remember that distances contract in the direction of motion, while forces contract in the perpendicular direction.
In the stationary frame, the forces are central forces, because the beam is in compression, and the forces point along the axis of the beam. In the moving frame, the forces are NOT central forces!
This argument is completely general, but it should be possible to (for instance) regard the forces as being due to electrical repulsion between like charges. While I haven't gone through the calculations, one should arive at at the same diagram if one computes the forces by transforming a columb force between two charges. Any force no matter what it's origin should transform in the above manner.
Now the diagram on the left, with central forces, does not contribute to the angular momentum of the system. The diagram on the right, however, with non-central forces does contribute to the angular momentum. If one looks up the derviation of angular momentum for a swarm of particles, one finds that one must assume that the forces between particles are central forces to keep internal forces from contributing to the angular momentum. One can also directly see that the non-central forces contribute angular momentum by picking a pivot point (say one of the particles) and summing force (x) distance.
Related to Explaining a Paradox in Modern Physics
1. What is a paradox in modern physics?
A paradox in modern physics is a situation or phenomenon that appears to contradict established laws or principles in physics. It often arises when two well-supported theories or observations cannot be reconciled with one another.
2. Why do paradoxes occur in modern physics?
Paradoxes occur in modern physics due to the complexity of the universe and our limited understanding of it. As we continue to make new discoveries and advancements in technology, we often come across situations that challenge our current understanding and lead to paradoxes.
3. How do scientists attempt to explain paradoxes in modern physics?
Scientists use a variety of approaches to explain paradoxes in modern physics. These may include proposing new theories or modifications to existing ones, conducting experiments to gather more data, and collaborating with other experts in the field to find a solution.
4. Can paradoxes in modern physics be resolved?
Yes, paradoxes in modern physics can be resolved. As our understanding of the universe deepens, we are able to find explanations for previously unexplainable phenomena. However, some paradoxes may remain unsolved until new evidence or technology becomes available.
5. What are some famous paradoxes in modern physics?
Some famous paradoxes in modern physics include the twin paradox, the grandfather paradox, and the Schrödinger's cat paradox. Each of these paradoxes challenges our understanding of time, causality, and quantum mechanics, respectively.
12K
