Prashasti
- 63
- 2
Can an atom be considered as an example of a dipole? It has positive charge in the nucleus and negative charge around it?!
Prashasti said:That means for a neutral Hydrogen atom it is "Yes" but for any other atom, it is no, (unless electric field is applied). Am I right if I say that this is because there is only one electron in a neutral H atom ,as for one electron and one proton, the direction of dipole moment is possible to tell?!
A dipolar substance is a molecule that has a separation of positive and negative charges, called a dipole moment. This is due to the unequal distribution of electrons within the molecule, resulting in a slightly positive and a slightly negative end.
Dipolar substances have a dipole moment, while non-dipolar substances do not. This means that dipolar substances can interact with electric fields, while non-dipolar substances cannot.
Water (H2O) is a common example of a dipolar substance. The oxygen atom has a slightly negative charge, while the hydrogen atoms have a slightly positive charge, resulting in a polar molecule.
Due to their polarity, dipolar substances can experience dipole-dipole interactions, which are stronger than the intermolecular forces experienced by non-polar substances. This can lead to higher boiling and melting points for dipolar substances.
Atoms become dipolar when there is an unequal distribution of electrons, resulting in a separation of positive and negative charges. This can occur due to differences in electronegativity between atoms in a molecule, or due to the shape of the molecule.
