Andre
- 4,311
- 74
This paper has been stalled for almost a year and concequentely misses the latest climate reconstructions (Moberg etc) but finally somebody got the most brilliant and original idea that the heating source itself may perhaps not be ruled out completely as a factor determining temperatures.
Usoskin, J.G., M. Schuessler, S.K. Solanki and K. Mursula 2005, "Solar activity, cosmic rays, and Earth's temperature: a millennium-scale comparison", Journal of Geophysical Research v. 110 (10 p.).
the draft is here
You keep wondering why the news papers keep very quiet about this instead of shouting: "Global warming caused by sun!"
the draft is here
Conclusions
Sunspot numbers and cosmic ray fluxes reconstructed from records of the cosmogenic isotopes 10Be and 14C, respectively, show correlations and anticorrelations with a number of reconstructions of the terrestrial Northern Hemisphere temperature, which cover a time span of up to 1800 years. This indicates that periods of higher solar activity and lower cosmic ray flux tend to be associated with warmer climate, and vice versa. The major part of this correlation is due to similar long-term trends in the data sets. Although the correlations often show only low significance levels, the signs of the correlation coe±cients in all cases are systematic. The long-term trend of the cosmic ray flux determined on the basis of the 14C record seems to correlate better with the terrestrial temperature than the sunspot numbers derived from the same isotope data. This suggests that e®ects induced by cosmic rays may affect the long-term terrestrial climate. The positive correlation between the geomagnetic dipole moment and the temperature reconstructions provides further evidence favoring the cosmic ray influence on the terrestrial climate. However, the present analysis cannot determine the relative importance of (total and UV) solar irradiance and cosmic ray flux since the irradiance may show a long-term trend that does not exactly follow the averaged sunspot number.
