0/0 as the result of taking a limit
  • Thread starter quasar987
  • Tags
    Limit
In summary: Are you saying it is not necessary to use the epsilon-delta definition to show that the limit is 0?"?In summary, you are confused because in last year's final calculus exam, there's a question that reads: Calculate the gradient vector of the functionf(x,y)=\frac{x^4+y^3}{x^2+y^2} at all point (including at (0,0)).But for exemple, \left[ \frac{\partial f}{\partial x} \right]_{(0,0)} = \left[\frac{4x^3}{x^2+y^2}
quasar987
32
I know when we encounter 0/0 as the result of taking a limit, we cannot conclude to the value of the limit. But what about 0/0 for a function? I am confused because in last year's final calculus exam, there's a question that reads:
[tex]f(x,y)=\frac{x^4+y^3}{x^2+y^2}[/tex]
But for exemple,
[tex]\left[ \frac{\partial f}{\partial x} \right]_{(0,0)} = \left[\frac{4x^3}{x^2+y^2}-\frac{2x^5}{(x^2+y^2)^2}-\frac{2xy^3}{(x^2+y^2)^2}\right]_{(0,0)} = \frac{0}{0}[/tex]
But for exemple,
You missunderstood a great deal of mathematics.When u're given a function,u have to see first at which points (what set) it is defined.In your case,neither the function,nor the derivatives are defined in (0,0),so your calculation is pointless.I should say INCORRECT.
Daniel.
PS.Was it written on the exam paper "including (0,0)"??If so,it must have been a (bad) joke from the teacher.
Yes, I transcripted the question as it was written on the paper!
And the worst part is that a friend of mine went to see a teacher about that question today and he told him the way to do it was to use the limit to show that the gradient was (0,0) at (0,0) ! Insane!
The exam is at: http://www.dms.umontreal.ca/~giroux/documentsc1/finalC1H04.html and it is the first question. Although it is in french, you can see that the "including at (0,0)" part is there.
Il n'y a acune problème.Je comprends Français.
Yes,i saw that.He meant to 'compute that limit'.It's (0,0),as it can easily be shown.However,it is still weird.He could have said:"Find the limit."Students would have gotten it.
Daniel.
PS.Je pense que le proffesseur Giroux (?) est un idiot. :-p
Oh My, Oh My!
you must keep in mind that this is function of 2 variables, You need to be a bit more careful.
First note that if you plot points on either side of zero the function is well behaved.
The correct way to analysis multi variable limits is to hold one variable constant, while the limit in the other variable is examined.
so if you first evaluate your partial of f wrt x at y=0, you have
[tex]\left[ \frac{\partial f}{\partial x} \right]_{(x,0)} = \left[\frac{4x^3}{x^2}-\frac{2x^5}{(x^2)^2}-\frac{0}{(x^2)^2}\right]_{(x,0)}=2x [/tex]
Clearly this is 0 at x = 0
You will get similar results if you hold x constant (that is compute the partial wrt y) and take the y limit as x is held constant.
You will find that the function is well behaved and approaching zero for all x,y near zero. therefore the limit exists at (0.0) and is 0. This can also be seen by plotting points near zero.
But do we agree that finding the limit of the gradient as (x,y) approches (0,0) is not the same as "calculating" the gradient for the value (0,0) ?
1. Prove that
[tex]\lim_{(x,y)\to(0,0)}f(x,y)=0[/tex]
We must show that given [tex]\epsilon>0[/tex] there exist a [tex]\delta>0[/tex]
so that [tex]||\vec{x}-\vec{0}||<\delta\to|f(\vec{x})-0|<\epsilon, \vec{x}\equiv(x,y)[/tex]
Rewrite your function in polar form:
[tex]x=r\cos\theta,y=r\sin\theta\to{f}(x,y)=g(r,\theta)=r^{2}\cos^{4}\theta+r\sin^{3}\theta[/tex]
Hence, since:
[tex]|g(r,\theta)-0|<=r^{2}+r[/tex]
it follows that we can find, for [tex]\epsilon>0[/tex] a [tex]\delta>0[/tex] so that
[tex]r<\delta\to{r}^{2}+r<\epsilon[/tex]
[tex]\delta<min(\sqrt{\frac{\epsilon}{2}},\frac{\epsilon}{2})[/tex]
is perhaps the simplest choice.
Hence, defining f(0,0)=0 gives us a continuous function.
Was this part of what you asked for?
2. By definition,
[tex]\frac{\partial{f}}{\partial{x}}\mid_{(x_{0},y_{0})}=\lim_{x\to{x}_{0}}\frac{f(x,y_{0})-f(x_{0},y_{0})}{x-x_{0}}[/tex]
Hence, in your case:
[tex]f(x,0)=x^{2},f(0,0)=0,f(0,y)=y[/tex]
We therefore gain:
[tex]\frac{\partial{f}}{\partial{x}}\mid_{0,0}=\lim_{x\to0}x=0,\frac{\partial{f}}{\partial{y}}\mid_{0,0}=\lim_{y\to0}1=1[/tex]
Hmm..I'll go and check up the definition to be sure, but I'm pretty certain I'm right here..
3. It is NOT correct that, for example [tex]\frac{\partial{f}}{\partial{x}}[/tex] is continuous at (0,0):
We compute [tex]\frac{\partial{f}}{\partial{x}}[/tex] at [tex](x_{0},y_{0})\neq(0,0)[/tex]
[tex]\frac{\partial{f}}{\partial{x}}\mid_{(x_{0},y_{0})}=\frac{4x_{0}^{3}(x_{0}^{2}+y_{0}^{2})-2x_{0}(x_{0}^{4}+y_{0}^{3})}{(x_{0}^{2}+y_{0}^{2})^{2}}[/tex]
Rewriting in polar form:
[tex]\frac{\partial{f}}{\partial{x}}=h(r,\theta),x_{0}=r\cos\theta,y_{0}=r\sin\theta[/tex]
We get:
[tex]h(r,\theta)=r(4\cos^{3}\theta-2\cos^{5}\theta)-2\cos\theta\sin^{3}\theta[/tex]
Hence,
[tex]\lim_{(x_{0},y_{0}\to(0,0)}\frac{\partial{f}}{\partial{x}}\mid_{(x_{0},y_{0})}[/tex]
depends on the angle by which we approach the origin.
In particular, the limit value will not always equal zero
,which is the function value [tex]\frac{\partial{f}}{\partial{x}}\mid_{(0,0)}[/tex]
Hence the x-derivative is discontinuous at the origin.
4. It is instructive to compute the DIRECTIONAL DERIVATIVES at the origin.
by definition, the derivative in the direction [tex]\vec{n},||\vec{n}||=1[/tex]
is given by:
[tex]\frac{\partial{f}}{\partial{n}}\mid_{(x_{0},y_{0})}\equiv\lim_{t\to0}\frac{f(x_{0}+tn_{x},y_{0}+tn_{y})-f(x_{0},y_{0})}{t}[/tex]
Setting [tex]\vec{n}=n_{x}\vec{i}+n_{y}\vec{j}=\cos\theta\vec{i}+\sin\theta\vec{j}[/tex]
we gain:
[tex]\frac{\partial{f}}{\partial{n}}\mid_{(0,0)}=\sin^{3}\theta[/tex]
Hmm...mais vous n'écrivez pas si bien... :wink:
I kidd.
I kidd.
Oui,c'est vrai.J'ai oublié un "u"... :confused: "aucune",peut [itex]\hat{e}[/itex]tre...??
Daniel.
Thanks arildno. I don't think this is what the question asked but they were assuredly very instructive posts, especially #4.
Just a final comment.
This function is an example where the partial derivatives all exist at (0,0), but still is not a differentiable function at (0,0).
If you want "gradient" to mean the "(total) derivative of f", then the gradient
doesn't exist at (0,0).
By definition, the total derivative of f(x,y) equals 0 at (0,0) if and only if
f(x,y)/|(x,y)| goes to zero as (x,y) does, where |(x,y)| = sqrt(x^2+y^2). in the case above f(x,y)/|(x,y)| = {x^4 + y^3}/(x^2+y^2)^(3/2).
thus the bottom has homogeneous degree 3, while the top has partly degree 4 and partly degree 3. thus if you approach (0,0) along the line x=0, this quotient is equal to 1, hence does not approach 0.
can you see how to modify the top of f slightly so as to get a function which does have total derivative zero at (0,0)? and by the way the professor is not an idiot here. indeed this is the kind of question which exposes whether one does or does not know what a derivative means.
Just adding a post-ultimate comment:
In order to prove that f is not differentiable at zero (that is, that the "total derivative" doesn't exist), you must show that there cannot exist a vector (a,b) independent of [tex]\vec{x}=(x,y)[/tex] so that:
[tex]\lim_{(\vec{x})\to(0,0)}\frac{|f(x,y)-f(0,0)-ax-by|}{||\vec{x}||}=0[/tex]
As mathwonk proved, (a,b)=(0,0) cannot be used, and it is a simple matter to show that no other choice works either.
(The simplest way to do this, is to change (x,y) into polar coordinates and show that (a,b) must be a function of the angle of approach in order to get zero (that is, dependence on (x,y)))
If you could have found a vector (a,b), that would, of course, have been the "total derivative", "gradient" of f at (0,0)
FAQ: 0/0 as the result of taking a limit
What does it mean when the result of taking a limit is "0/0"?
When the result of taking a limit is "0/0", it means that the function being evaluated has a value of 0 at the point where the limit is being taken, but the denominator of the limit is also approaching 0. This can result in an indeterminate form, meaning that the limit cannot be determined without further analysis.
Can a limit with a result of "0/0" be evaluated?
No, a limit with a result of "0/0" cannot be evaluated directly. It requires further analysis, such as using L'Hopital's rule or other techniques, to determine the actual value of the limit.
Does a limit with a result of "0/0" always mean there is an error in the calculation?
No, a limit with a result of "0/0" does not always mean there is an error in the calculation. It is a common misconception that a limit with an indeterminate form is always incorrect, but in some cases, it is a valid result that requires further analysis to determine the value of the limit.
How does "0/0" as a limit result differ from other indeterminate forms?
"0/0" as a limit result is a type of indeterminate form known as a "quotient of limits", where both the numerator and denominator of the limit are approaching 0. Other types of indeterminate forms include "infinity/infinity" and "0 x infinity", which require different techniques to evaluate.
Is it always necessary to simplify a limit with a result of "0/0" before evaluating?
Yes, it is necessary to simplify a limit with a result of "0/0" before evaluating. This involves using algebraic manipulation or other techniques to transform the limit into a form that can be evaluated using L'Hopital's rule or other methods. Failure to simplify the limit may result in an incorrect evaluation.
