A problem with limits ( i think)
  • Thread starter steve2510
  • Tags
    Limits
In summary, the conversation discusses a mathCAD problem involving finding the maximum deflection of a beam using an equation. The limit of the equation as P approaches 0 is incorrect, but the correct limit is found by replacing P with P^2 in the equation. The conversation also discusses different methods of solving the problem and clarifies some confusion about the use of P and P^2 in the equation.
steve2510
36
The maximum deflection of a beam is given by the equation
y=M/P(sec(μL/2)-1)
μ=√(P/EI) Where EI Is a constant.
Show that as P→0 y→ML^2/8EI
This is a mathCAD problem by the way, but I'm very novice at it so i want to try formulise some sort of solution on paper before i attempt mathCAD
I'm really stuck, firstly i would replace μ with √(P/EI)
∴y = M/P(sec(√(P/EI)*L)/2)-1)
I think the next step is to try get the EI out the function as it is a constant and doesn't need to be differntiated.
The derivivative of secx is tanxsecx which is the same as tanx/cosx and as x approaches 0 the function will equal 0/1 which is 0
If someone could point me in the right direction it would be much appreciated !
The limit is correct, if the initial equation has P^2 instead of P in the denominator.
I would keep EI there, it gives the correct factors in the derivatives.
$$y=M \frac{\sec \left(\sqrt{\frac{P}{EI}}\frac{L}{2} \right)-1}{P^2}$$
So you want to replace [itex]\sqrt{P/EI}L/2[/itex] with x. Then [itex]P= (4x/L^2)(EI)= 4EIx/L^2[/itex]. [itex]y= M/[(4EIx/L^2)(sec(x)- 1)= ML^2/(4EIx(sec(x)- 1)[/itex]
I'm still a little bit confused have you said that the √x = √P/EI * L/2 ∴ x = P/EI * L^2/4 ∴ 4xEI/L^2 = P, then
I follow that you have placed P back into the equation I am confused why the sec x is on the bottom of the fraction now when it was on the top before.
Am i not right in saying that y=(ML^2*sec(x)-1)/4EIx
So d/dx(Ml^2*sec(x)-1) = ML^2secxtanx
d/dx 4EIx = 4Ei
Would i then subsitute x back into the equation ?
Also Mfb why have you replaced P with P^2 in the original equation
I think some brackets in HallsofIvy's post are wrong.
That is just a guess: with P^2, the given limit is correct, without, it is not.
So I've said that x = √(P/Ei) * L/2
∴P = (x2*EI *4)/L2
Subsituting back in i get
(ML2(sec(x)-1)/x24EI
D/dx ML2(sec(x)-1) = ML2sec(x)tan(x) Where x = √(P/Ei) * L/2 as P reaches 0 x = 0 aswell. Which means sec(x)tan(x) = zero which cancells the top complety so surely this isn't correct!?
The bottom would become 8EIx
Am i doing something wrong, this is really my first problem with limits and i don't even recall being taught L'Hôpital's rule. This is a MathCad problem, and i think it is meant to calculate mos this maths!
I'm just sturggling to arrange it in mathCAD without getting a catalogue of errors, so i thought it might be easier to generate a paper solution first !
I still don't see where the p^2 came from , if p is approaching 0 then what difference does it make if p is p^2, also if its p^2 on the bottom would you not have to times the top by another factor of p. whether p is p^2 or just p surely we have the correct intermediate form of 0/0 already as secx -1 = 0
That P^2 is not the result of any calculation.
The formula given in post 1 does not fit to the limit given there. Therefore, we have 3 options:
- the given limit is wrong. In that case, you already know the correct limit
- the given formula is wrong, but the limit is right. In that case, I found a new, different formula, with the correct limit
- both are wrong. We are lost.
FAQ: A problem with limits ( i think)
What is a problem with limits?
A problem with limits refers to a mathematical concept in calculus where a function approaches a certain value or gets infinitely close to it, but never reaches it.
Why is understanding limits important?
Understanding limits is crucial in calculus because it helps us determine the behavior of a function and its values at certain points. It also allows us to solve more complex problems involving derivatives and integrals.
What are the different types of limit problems?
There are three main types of limit problems: finite limits, infinite limits, and limits at infinity. Finite limits involve finding the value of a function at a specific point, infinite limits involve determining the behavior of a function as it approaches infinity or negative infinity, and limits at infinity involve finding the behavior of a function as x approaches infinity or negative infinity.
How do you solve a limit problem?
To solve a limit problem, you can use algebraic manipulation, graphing, or other techniques such as L'Hopital's rule or the squeeze theorem. You can also use a calculator or online limit calculator to get an approximate answer.
What are some real-life applications of limits?
Limits have various applications in fields such as physics, engineering, and economics. They are used to calculate instantaneous rates of change, determine maximum and minimum values, and model real-world phenomena such as population growth and particle motion.
