A Unit Question: Flicking a Switch
  • Thread starter thepopasmurf
  • Tags
    Switch Unit
In summary, when determining how hard it is to flick a light switch, you are dealing with units of impulse and work. The peak force needed to overcome the switch mechanism must be applied for a certain amount of time, resulting in an impulse. Additionally, work must be done on the spring holding the switch. When the switch moves into the new position, it also gains a certain amount of momentum. If using a projectile to flick the switch, the velocity needed would depend on the mass of the object and the impulse required.
thepopasmurf
76
If I wanted to work out the calculations for flicking a lightswitch, what units am I dealing with when I am determining how hard it is to flick the switch?
For example, I am sure that I wouldn't say it takes a certain amount of force because a large force over a short amount of time wouldn't do much. Is it impulse, or work?
It depends what you want to measure.
There is a peak force needed to overcome the switch mechanism
You apply this force for a certain time so their is an impulse, you also have to do a certain amount of work on the spring holding the switch. Finally when the switch moves over into the new position it has a certain momentum.
Well, the problem I have in mind is flicking a light switch with a projectile. I want to know what velocity I have to give an object of mass M in order to flick a light switch. Of course different switches vary and I'm not sure what I should call this varying quantity and what unit it is
You could measure the lightest object needed to push down the light switch, using only gravity. F= MA and you know the force. As far as velocity, you would need to know the impulse.
FAQ: A Unit Question: Flicking a Switch
What is the purpose of flicking a switch?
The purpose of flicking a switch is to complete an electrical circuit and allow the flow of electricity to a specific device or area.
What is the difference between flicking a switch on and off?
The difference between flicking a switch on and off is the direction of the flow of electricity. When a switch is turned on, it allows the flow of electricity, and when it is turned off, it stops the flow of electricity.
Why do we use switches in electrical circuits?
We use switches in electrical circuits to control the flow of electricity. By turning a switch on or off, we can control whether electricity flows to a specific device or not.
What happens when a switch is flicked?
When a switch is flicked, it either completes or breaks an electrical circuit, allowing or stopping the flow of electricity to a specific device or area.
Are there different types of switches?
Yes, there are different types of switches, including toggle switches, push-button switches, and rotary switches. Each type of switch has its own unique method of operation and is used for different purposes.
