A vessel filled with two liquid how to determine boant force?
In summary: Take a block instead of the sphere. The area of the top and bottom sides is A. The pressure at depth d in the oil is Pt=ρoilgd +P0, so the downward force on the top surface of the block is Ft= A(gρoilgd +P0).At the bottom of the block, the pressure is that of a column of oil of height d+h/2 and a column of mercury of height h/2. Pb=ρoilg(d+h/2)+ ρHgg(h/2)+P0, so the force Fb =A(ρoilg(d+h/2)+ ρHgg(h/2
vkash
318
A vessel filled with two liquid how to determine boyant force?
A vessel contains oil of density(800kgm-3) over mercury (density 13600kgm-3) A homogeneous Sphere is floats with half of its volume immersed in mercury and other half in oil. What is density of the material of the sphere?
How to apply Archimedes principle of floating? can you please help.
What does Archimedes' Principle say? ehild
ehild
It says that buoyant force is equal to weight of liquid displaced.
There are two kinds of liquid displaced. What is the volume and the weight of each when the volume of the sphere is V?
ehild
ehild
But lighter liquid seems to push the sphere downward rather than pushing it upward. and lower liquid seems to push with greater power.
even after this. can i apply that principle?
You get upward force at the bottom of the immersed volume, and an upward force at the top.
Pascal's law states that the force a liquid exerts on a surface is normal to the surface and F=PA.
As the pressure is greater at the bottom of the immersed object then at the top, the liquid pushes the bottom surface upward by a greater force than it pushes the top surface downward. The resultant force is always upward. ehild
ehild
thnank's sir(are u male) for helping me,
Can you proceed from here?
ehild
ehild
Actually i have already(before posting) done this question by this method. But I did not understand that is it correct or not. that's why i post it here.
Do you understand it now?
Ptoilgd +P0, so the downward force on the top surface of the block is Ft= A(gρoilgd +P0).
At the bottom of the block, the pressure is that of a column of oil of height d+h/2 and a column of mercury of height h/2. Pboilg(d+h/2)+ ρHgg(h/2)+P0, so the force Fb =A(ρoilg(d+h/2)+ ρHgg(h/2)+P0)
The resultant is the buoyant force: BF=Ag( ρoil(d+h/2)+ ρHg(h/2)-ρoild)=Ag(ρoil(h/2)+ ρHg(h/2))=g(V/2)(ρoil+ ρHg).
ehild
FAQ: A vessel filled with two liquid how to determine boant force?
What is a vessel filled with two liquid?
A vessel filled with two liquid refers to a container or object that contains two different types of liquids in it. This can include liquids of different densities or compositions.
How can we determine the buoyant force in a vessel filled with two liquid?
To determine the buoyant force, we need to first calculate the weight of the liquid displaced by the object. This can be done by multiplying the density of the liquid by the volume of the object. Then, we can use Archimedes' principle to calculate the buoyant force, which states that the buoyant force is equal to the weight of the liquid displaced by the object.
What factors affect the buoyant force in a vessel filled with two liquid?
The buoyant force in a vessel filled with two liquid is affected by the density and volume of the liquid, as well as the density and volume of the object. The depth of the liquid and the acceleration due to gravity can also affect the buoyant force.
How do the densities of the two liquids affect the buoyant force?
The densities of the two liquids play a crucial role in determining the buoyant force. If one liquid has a higher density than the other, it will exert a greater buoyant force on the object. This is because the denser liquid will displace more weight of the object, resulting in a greater buoyant force.
Can the buoyant force in a vessel filled with two liquid be greater than the weight of the object?
Yes, the buoyant force can be greater than the weight of the object in a vessel filled with two liquid. This happens when the density of the object is less than the average density of the two liquids. In this case, the object will float on the surface of the liquid with a portion of it submerged, and the buoyant force will be greater than its weight.
