AAS of mercury in prescence of cobalt
  • Thread starter Taryn
  • Tags
    Mercury
In summary, the conversation discusses the challenge of analyzing mercury in the presence of cobalt using atomic absorption analysis. The use of cold vapour atomic absorption analysis for mercury is mentioned, but it is unclear how to take into account the presence of cobalt which also emits and absorbs radiation at the same wavelength. The conversation ends with a question about the vapor pressure of zero valent cobalt.
Taryn
63
Just wondering how to analyse mercury in the presence of cobalt by atomic absorption analysis given that both elements emit and absorb radiation at 235.65nm.
I know that mercury isj examined using cold vapour atomic absorbtion analysis... but knowing this still doesn't help?
Any hints would be appreciated
cheers!
Cold vapour AAS is a method in which mercury is reduced in the sample to elemental mercury which has a fairly high vapor pressure. What do you suppose the vapor pressure of zero valent cobalt might be?
To analyze mercury in the presence of cobalt using atomic absorption analysis, you will need to use a technique called "sequential determination." This involves analyzing the sample first for cobalt, and then analyzing the remaining sample for mercury.
First, you will need to adjust the instrument's settings to detect cobalt at 235.65nm. This will allow you to quantify the amount of cobalt present in the sample.
Next, you will need to add a reducing agent, such as stannous chloride, to the sample. This will convert any mercury present into elemental mercury, which can then be detected using cold vapor atomic absorption analysis.
Once the cobalt analysis is complete, you can then adjust the instrument's settings to detect mercury at 235.65nm and analyze the remaining sample for mercury.
It is important to note that the presence of cobalt may interfere with the analysis of mercury, so it is important to properly calibrate the instrument and perform any necessary blank corrections.
I hope this helps guide you in your analysis. If you need further assistance, I recommend consulting a laboratory manual or reaching out to a colleague with experience in atomic absorption analysis. Best of luck with your research!
FAQ: AAS of mercury in prescence of cobalt
What is atomic absorption spectroscopy (AAS)?
Atomic absorption spectroscopy (AAS) is an analytical technique used to determine the concentration of elements in a sample. It measures the amount of light absorbed by atoms of a specific element, which can then be used to calculate the concentration of that element in the sample.
How does AAS work?
AAS works by passing a beam of light through a sample containing the element of interest. The light is absorbed by the atoms of that element, and the amount of absorption is measured by a detector. The more concentrated the element is in the sample, the more light will be absorbed, allowing for the calculation of the element's concentration.
What is the role of mercury in AAS in the presence of cobalt?
Mercury is used as a "carrier" in AAS when analyzing samples containing cobalt. This means that a small amount of mercury is added to the sample to help break down the sample matrix and improve the accuracy of the analysis.
Why is cobalt often analyzed by AAS?
Cobalt is a commonly analyzed element in AAS due to its unique properties and wide range of applications. It is used in many industrial processes, as well as in the production of batteries, magnets, and alloys. AAS allows for the precise and sensitive measurement of cobalt in various samples.
Are there any limitations to using AAS for analysis of mercury and cobalt?
While AAS is a highly accurate and reliable analytical technique, there are some limitations to consider when analyzing mercury and cobalt. These may include interference from other elements in the sample, the need for careful sample preparation, and the potential for contamination. It is important for scientists to carefully plan and execute their AAS experiments to minimize these limitations and ensure accurate results.
17K
10K
