About the Like dissolves like principle
  • Thread starter cantgetaname
  • Tags
    Principle
In summary, the 'Like dissolves like' concept refers to the principle that polar solutes are better soluble in polar solvents due to the strong interactions between them, while non-polar solutes are only soluble in non-polar solvents due to their weak interactions with water molecules. When both solute and solvent are non-polar, the interactions may be even weaker, but the hydrophobic effect plays a role in minimizing entropic penalty and results in the separation of non-polar molecules from aqueous solution.
cantgetaname
41
About the 'Like dissolves like' concept...
I can understand why polar solutes would be better soluble in polar solvents.
But why are they not soluble in non-polar solvents?
Moreover, why are non-polar solutes only soluble in non-polar solvents? What stops them from being soluble in non-polar solvents?
I would expect the following order solubility...
Polar-polar> Nonpolar-polar (or vice versa) > Nonpolar-Nonpolar
(solute and solvent respectively)
Chemistry news on Phys.org
Think about that it means for something to be in solution and for something to be dissolved. Polar solutes have relatively strong interactions with the water molecules, so they are able to separate the water molecules and be dissolved in them. In other words, the interaction between a polar solute and water is so stong that it is more energetically favorable for them to be close to the water molecules and the water molecules being close together.
Nonpolar solutes simply don't have a strong enough interaction with water to separate the molecules, and so we see layers forming when we try to dissolve for example hexane in water.
The same is true in the opposite case. Polar solutes are so strongly bonded to each other and don't really interact with nonpolar solvents, and the solvent can't separate the polar molecules from one another or break apart ionic salts.
Thanks
However, the main confusion here was that in case where both solute and solvent are non-polar, then the interactions should be even less.
How do non-polar solute and solvent dissolve into each other then?
In the case of a non-polar solute and non-polar solvent, it is true that the interactions between solute and solvent will be relatively weak. However, the interactions between solute molecules will also be relatively weak and easier to break up than interactions between polar solute molecules.
It is also worth noting that entropy plays a role here. When non-polar solutes are dissolved in a highly polar solvent with lots of hydrogen bonds (such as water), the solute molecules cannot participate in the hydrogen bonding. Therefore, the water molecules must arrange themselves in a ordered solvent shell around the solute particles in order to interact with the solute while still maintaining their hydrogen bonds to the other water molecules. This ordering of water comes with an entropic penalty.
In order to minimize the entropic penalty, the surface area of the solute molecules must be minimized and this is achieved by aggregating smaller groups of solute molecules into larger groups. This results in the separation of the non-polar molecules from the aqueous phase. Such an exclusion of non-polar molecules from aqueous solution is known as the hydrophobic effect.
Thanks for that explanation!
FAQ: About the Like dissolves like principle
What is the "like dissolves like" principle?
The "like dissolves like" principle is a concept in chemistry that states that substances with similar chemical properties are more likely to dissolve in each other. This means that polar substances are more likely to dissolve in other polar substances, and nonpolar substances are more likely to dissolve in other nonpolar substances.
Why is the "like dissolves like" principle important?
The "like dissolves like" principle is important because it helps us predict whether a substance will dissolve in a particular solvent. This is useful in many scientific fields, such as pharmaceuticals, where knowing how a drug will dissolve in the body is crucial for its effectiveness.
What are some examples of the "like dissolves like" principle in action?
Some examples of the "like dissolves like" principle include water (a polar substance) dissolving salt (also polar), and oil (a nonpolar substance) dissolving in other oils (also nonpolar). Another example is rubbing alcohol (polar) dissolving in water (also polar).
Are there any exceptions to the "like dissolves like" principle?
While the "like dissolves like" principle generally holds true, there are some exceptions. For example, water (a polar substance) can dissolve some nonpolar substances, such as oil, due to the formation of micelles. Additionally, some substances may partially dissolve in a solvent that they are not considered "like" with, but this is not a true dissolution.
How does the "like dissolves like" principle relate to intermolecular forces?
The "like dissolves like" principle is closely related to intermolecular forces. Substances with similar intermolecular forces are more likely to dissolve in each other, as these forces play a key role in the dissolution process. For example, polar molecules have dipole-dipole interactions, which allow them to dissolve in other polar substances with similar interactions.
