Acceleration vs De-acceleration
In summary: Assuming that you meant that you were not moving at a constant V wrt the observer, or that you were initially moving at a constant V wrt the observer and then at some time t0 you decelerated to a stop relative to the observer, then the above responses are correct.
multiix
If you were to be moving in space at a constant V observed by a "stationary source". Say you had no frame of reference yourself, so you felt you were stationary, (but per observer you are moving at V)
If the observer sees you slow down to a stop. At that point can you tell whether you accelerated or de-accelerated.
Thank You
I am not really sure what your asking here? are you asking if acceleration and deceleration are different? Or if you can tell if you change velocity if you are slowing down compared to a none accelerating (inertial)frame of reference?
Im asking whether you can tell the difference between the two if you have no frame of reference.
No, they are the same, it just depends on how you look at it. To someone you might be accelerating at the same time you will be decelerating to someone else. Really it's all just acceleration.
Thank You! I've been arguing this with a classmate. I got another supporter smile:
I would have to agree with darkhorror, the is only a difference between the two if there is a reference point. It really goes back to the bare basic physics principles. :)
Your question is self contradictory. If you are moving at constant V then there is no acceleration.
FAQ: Acceleration vs De-acceleration
What is acceleration and de-acceleration?
Acceleration is the rate at which an object's velocity changes over time. It can be positive (speeding up) or negative (slowing down). De-acceleration, also known as deceleration or negative acceleration, is when an object's velocity decreases over time.
How are acceleration and de-acceleration measured?
Acceleration is typically measured in meters per second squared (m/s²), while de-acceleration can also be measured in the same unit. However, de-acceleration can also be measured in units such as miles per hour per second (mph/s) or kilometers per hour per second (km/h/s).
What causes acceleration and de-acceleration?
Acceleration is caused by a force acting on an object, such as gravity or a push or pull. De-acceleration, on the other hand, can be caused by a force acting in the opposite direction of an object's motion, such as friction or air resistance.
What is the difference between acceleration and de-acceleration?
The main difference between acceleration and de-acceleration is the direction of the change in velocity. Acceleration causes an increase in velocity, while de-acceleration causes a decrease in velocity. Additionally, acceleration is usually associated with speeding up, while de-acceleration is associated with slowing down.
How do acceleration and de-acceleration affect an object's motion?
Acceleration and de-acceleration can both affect an object's motion by changing its velocity. Acceleration can cause an object to speed up or slow down, while de-acceleration can only cause an object to slow down. These changes in velocity can also affect an object's position and overall movement.
