Acceleration vs Time Graph in Simple Pendulum
In summary, the conversation discusses the concept of acceleration vs time graph in a simple pendulum. The group discusses the misconceptions around the graph being a straight line instead of a sinusoidal curve. They also mention the relationship between displacement, velocity, and acceleration in a simple pendulum and how it relates to the graphs shown. The group concludes by asking for clarification on the correct graph and the points where velocity and acceleration are zero and maximum in a simple pendulum.
XuFyaN
50
can anyone please explain
Acceleration vs Time Graph in Simple Pendulum ?
these would be straight lines but i don't know why
The Acceleration vs Time graph would actually be a sinusoidal curve, not a straight line. Perhaps you were thinking of acceleration vs displacement. If so; start with the general displacement-time equation for a simple pendulum, use it to find an acceleration-time equation, and compare the two.
No its not sinusoidal , see the attached image , the third graph is Acceleration vs Time of Simple Pendulum ...why these are straight lines ?
and also see the second graph , why Velocity vs time is not sinusoidal but in Mass attached to spring it is Sinusoidal
A simple pendulum approximately exhibits simple harmonic motion. My guess is that your graphs were just very crude approximations for the time derivative of the first graph.
what do you mean ??
please just explain the 3rd graph
What is there I am meant to explain. I'm telling you it's not correct. How much thought have you even put into this? Do you understand that velocity and acceleration are the first and second time derivatives of displacement respectively. Do the graphs you drew reflect that?
So can you show the correct Graph please ??
and in this image can you tell me where the velocity,acceleration is zero and where it is maximum
http://www.educationalelectronicsusa.com/p/images/wep-4.gif
Related to Acceleration vs Time Graph in Simple Pendulum
1. What is an acceleration vs time graph in a simple pendulum?
An acceleration vs time graph in a simple pendulum is a graphical representation of the acceleration of a pendulum over a period of time. This graph shows how the acceleration of the pendulum changes as it swings back and forth.
2. How is the acceleration of a simple pendulum related to its position?
The acceleration of a simple pendulum is directly proportional to its displacement from the equilibrium position. This means that as the pendulum swings further from the equilibrium position, its acceleration will increase, and as it reaches the equilibrium position, its acceleration will decrease.
3. How does the length of a simple pendulum affect its acceleration vs time graph?
The length of a simple pendulum does not affect its acceleration vs time graph. The only factor that affects the acceleration of a simple pendulum is its displacement from the equilibrium position.
4. What does the slope of an acceleration vs time graph represent?
The slope of an acceleration vs time graph represents the rate of change of acceleration over time. A steeper slope indicates a higher rate of change, while a flatter slope indicates a slower rate of change.
5. How can an acceleration vs time graph be used to determine the period of a simple pendulum?
The period of a simple pendulum can be determined by finding the time it takes for the acceleration to change from maximum (at the equilibrium position) to minimum (at the furthest point from the equilibrium position) and back to maximum. This time interval is equal to one full oscillation or period of the pendulum.
