jegues said:Homework Statement
See figure.Homework Equations
I tried KVL (see figure), but still got stuck with only 1 equation and two unknowns. Any ideas/tips on what I should try next?
I get dv_q/dv_s=3v_S-3=12 when V_S=5
jegues said:How did you get this?
[tex]\frac{3}{2}(v_{S} - 1)^{2}
\Rightarrow 3v_{S} - 3
\Rightarrow 3(5 + v_{s}) -3
[/tex]
What is this equal to anyways, we don't know what vQ is?
evaluated at the DC operating point of V_S=5 V and V_Q=24 V.
jegues said:How did you know that V_Q = 24 V?
[tex] {{v_q}\over{v_s}}={{\Delta v_Q}\over{\Delta v_S}}\approx{{d v_Q}\over{dv_S}}\bigg|_{v_S=5V}=12 [/tex]
When you evaluate this you find that [tex]v_{S} = 5\cdots v_{s} = 0 [/tex]
And if [tex] v_{s} = 0 \cdots \frac{v_{q}}{v_{s}} = undefined [/tex]
A non-linear device is an electronic component or circuit that does not have a linear relationship between its input and output. This means that the output signal does not change proportionally to the input signal, making it useful for signal processing and amplification.
A non-linear device works by using non-linear elements, such as diodes or transistors, to manipulate the input signal and produce an output signal that is different from the input. This can be achieved through a variety of techniques, such as changing the frequency, amplitude, or phase of the signal.
Some examples of non-linear devices include diodes, transistors, operational amplifiers, and digital logic gates. Non-linear devices are commonly used in audio and video equipment, communication systems, and electronic sensors.
One of the main advantages of using non-linear devices is their ability to manipulate signals in ways that linear devices cannot. This makes them useful for applications such as amplification, signal processing, and frequency conversion. Non-linear devices also tend to have smaller size and lower power consumption compared to linear devices.
One potential disadvantage of non-linear devices is their tendency to introduce distortion or noise into the signal. This can be mitigated through careful design and use of feedback circuits. Non-linear devices also require more complex circuitry and may be more sensitive to changes in operating conditions compared to linear devices.
