Rishav sapahi
- 19
Like if number is too big then normal division is very much tedious task to do
Rishav sapahi said:Like if number is too big then normal division is very much tedious task to do
I am asking about the algorithm on which they works as I have come across an algorithm on fundamental theorem of arithmetic but it was not so much clear.SteamKing said:Which is why calculators and computers were invented.
To find the divisors of a number, you can use a simple method of starting from 1 and checking if it divides the given number without a remainder. If it does, then it is a divisor. Continue this process until you reach the given number. Another method is to factorize the number and use the prime factorization to find all possible combinations of divisors.
Yes, there are more efficient methods to find divisors. One example is using the square root method, where you only need to check for divisors up to the square root of the given number. This reduces the number of iterations needed and makes the process faster.
Yes, you can find all the divisors of a large number using the methods mentioned above. However, for extremely large numbers, it may not be feasible to list all the divisors as it would require a significant amount of time and resources.
A number is a divisor of another number if it divides the given number without a remainder. In other words, if you divide the given number by the potential divisor and the remainder is 0, then the number is a divisor.
Technically, any number can have divisors, including decimals and negative numbers. However, the process of finding divisors for these types of numbers may be more complex and may require different methods. It is best to specify the type of number when searching for divisors to ensure an accurate and efficient process.
