rovelli
- 3
mfb said:Mismatching brackets in the last sum. And I doubt the overall expression is well-defined.
Simply open the door and work from there without entering the room? ;)
What the h**l is this and where's the equality sign?rovelli said:
What you have in the image is NOT an equation. An equation has this symbol in it somewhere: =.rovelli said:yes, one bracket is missing. I found out where the equation is from
That would be the value of the expression (I didn't confirm this for myself, though).rovelli said:, it is from a book by an author named Lauren Child, and using that information, I found out that the solution to the equation is 42. LOL! She cooperates with maths prof Marcus de Sautoy...
mfb said:Where is the equality sign in 3+5 (a "slightly" easier problem of the same type)?
The purpose of this formula is to solve a specific problem or equation. It can be used to find a solution or to better understand a concept.
The formula was likely created by a mathematician or scientist, and the specific person and date of creation may vary depending on the formula in question.
To understand and use a formula, it is important to have a basic understanding of the mathematical or scientific concepts involved. It may also be helpful to consult with a teacher or expert in the field.
In many cases, there may be multiple formulas or solutions to a problem. It is important to consider all options and choose the most appropriate one for the specific situation.
Some formulas may have a wide range of applications, while others may be more specific. It is important to carefully consider the context and limitations of a formula before applying it to different scenarios.
