Are Ionospheric Scramjets possible?
  • Thread starter Apollo19
In summary, a scramjet is a type of engine used in spaceplanes, with a maximum estimated speed of Mach 25. The ionosphere, which contains low levels of oxygen, may not provide enough lift for a scramjet aircraft to fly at 100km. At this altitude, the required flight speed would reach orbital velocity, making the aircraft act as a satellite. It is possible to burn something at this speed, but drag would still be a factor to consider.
Apollo19
I was doing some Wikipedia browsing, and I came across the concept of Scramjets for spaceplanes. The highest estimate for a top speed of a scramjet in atmosphere is Mach 25, which is approximately orbital velocity. The ionosphere contains high levels of O, so would it be possible to fly a scramjet aircraft in it (at approx. 100km)?
Astronomy news on Phys.org
High fraction does not mean high amount - the ionosphere is extremely thin. You don't get much oxygen there, and not much lift. You need a very high speed to counter this. 100km is at the Kármán line, where the required flight speed reaches the orbital speed - your "plane" becomes a satellite.
Thanks. Thing is that at Mach 25, surely even though it is very thin, you are taking in some? Do you know if such a scramjet would work, even if it had very low thrust? And for the sake of the theory, assume that there is no drag.
I'm sure you can burn something, but airplanes are always a quantitative problem.
The air is thin, but at that speed drag is relevant.
I can say that the concept of Ionospheric Scramjets is certainly possible, but it would require significant technological advancements and challenges to overcome. Scramjets are a type of air-breathing engine that relies on high-speed airflow to ignite and sustain combustion. These engines are typically designed for high-altitude, high-speed flight in the Earth's atmosphere.
At 100km altitude, the ionosphere is indeed rich in atomic oxygen (O) atoms, which can be used as a source of oxidizer for the scramjet's combustion. However, there are several key factors that would need to be addressed for Ionospheric Scramjets to become a reality.
Firstly, the ionosphere is a highly variable and dynamic region of the Earth's atmosphere, with constantly changing levels of O atoms and other gases. This would make it challenging to maintain a consistent and reliable source of oxidizer for the scramjet's combustion.
Secondly, the extremely high speeds and temperatures involved in scramjet flight would require advanced materials and cooling systems to prevent overheating and structural damage. This would be particularly difficult to achieve in the harsh environment of the upper atmosphere.
Lastly, the design and operation of a scramjet in the ionosphere would need to be carefully considered to avoid any potential negative impacts on the Earth's atmosphere and the delicate balance of gases within it.
In summary, while the concept of Ionospheric Scramjets is scientifically possible, it would require significant advancements in technology and careful consideration of various challenges before it can become a practical and feasible option for high-speed flight in the ionosphere.
FAQ: Are Ionospheric Scramjets possible?
What are ionospheric scramjets?
Ionospheric scramjets are a type of propulsion system that uses the ionosphere, a layer of the Earth's atmosphere, to generate thrust. This is achieved by using the charged particles in the ionosphere to ionize and heat incoming air, creating a plasma that can be expelled at high speeds to produce thrust.
How do ionospheric scramjets work?
Ionospheric scramjets use the principles of ionization and plasma propulsion to generate thrust. As the vehicle travels through the ionosphere, it collects incoming air and uses its electrical charge to ionize and heat it. The resulting plasma is then expelled at high speeds, creating thrust that propels the vehicle forward.
Are ionospheric scramjets feasible for space travel?
While ionospheric scramjets have been successfully tested in laboratory settings, they have not yet been proven to be feasible for space travel. The technology is still in its early stages of development and more research and testing is needed to determine its potential for practical applications in space travel.
What are the advantages of ionospheric scramjets?
One of the main advantages of ionospheric scramjets is that they can potentially reach extremely high speeds, making them ideal for space travel. They also use the atmosphere as a source of fuel, reducing the need for heavy onboard fuel storage. Additionally, they have the potential to be more efficient and environmentally friendly than traditional rocket engines.
What are the challenges of developing ionospheric scramjets?
One of the main challenges of developing ionospheric scramjets is the complexity of the technology. It requires precise control and coordination of multiple systems, including ionization, plasma generation, and thrust generation. Other challenges include the need for advanced materials that can withstand high temperatures and the need for further research and testing to fully understand the potential of this technology.
10K
