Are these good analogues for entanglement
  • B
  • Thread starter sciencejournalist00
  • Tags
    Entanglement
In summary: The very previous post, you were told that you can't just pick and choose elements. Not sure what your point is here.Again, I will re-recommend that you stop and take time to read the references you have been previously supplied (by myself and others as well as yourself) rather than starting new threads with similar themes. There are many ways to create entanglement, but they are difficult to execute and attention to detail (and theory) are absolutely required.In summary, the conversation discusses the concept of nonclassical light and how it is necessary for entanglement and coincidence counting in quantum physics experiments. The discussion also mentions the use of polarizing beam splitters (PBSs) and half-silvered mirrors
sciencejournalist00
94
In his book on quantum physics, "The theoretical minimum" Leonard Susskind says that if Alice and Bob get their different coins from the same Charlie who mixes them up behind his back so he won't know which coin ends up in whose hands, the coins become entangled.
If Alice gets her coin from Charlie-A who mixes two different coins and then discards one and Bob gets his coin from Charlie-B in the same way, the coins will not get entangled because they are mixed up by different sources.
So if I send two photons on the same beam splitter which mixes up the photon identity and then get them absorbed by two resonant crystals, the crystals get entangled, but if I use two beam splitters, the crystals will not get entangled.
Did I understand correctly?
Wait,
http://pages.uoregon.edu/svanenk/solutions/NotesBS.pdf
If we detect light with two photodetectors, then we’ll either get one click on detector 3, or one click in detector 4. Classically, in contrast, we would get half the intensity in each. An experiment with an appropriate nonclassical light source (not a laser!) and a 50/50 beamsplitter can thus “prove” the existence of photons: no two clicks are simultaneously observed (see Kimble, Dagenais, and Mandel, Phys Rev Lett 39, 691 (1977).)
https://www.rp-photonics.com/nonclassical_light.html
Nonclassical light is light with nonclassical quantum noise properties, which can be understood only on the basis of quantum optics.
squeezed light, fock states
Do they require nonclassical light for entanglement and coincidence counting?
No. You have been told repeatedly that you must consider the entire context of an experimental setup. You cannot pick and choose elements and expect to get the desired result.
First: Polarizing Beam Splitters (PBSs) do not mix up anything. If anything, they usually do the opposite: sorting a mixed beam into components.
Second: To get entanglement, you need a few things. One of the requirements is fixed photon number. You cannot shine a beam of light (which lacks a fixed photon number) into a PBS and expect to see pairs of entangled photons coming out. And just saying you have 2 photons is meaningless, you may as well say you are starting with 2 unicorns. Getting 2 suitable photons together requires its own additional mechanism.
Third: even when you have 2 photons going into a PBS, the PBS outputs do NOT magically entangle those photons. There are other factors that are important too, and those critically determine what happens. The PBS is just one component.
Fourth: If you think that your example above is viable, perhaps you can give a reference. I think you will see that actual experiments creating entangled crystals do not look anything like what you describe.
First, PBS and BS are not the same thing. PBS are polarizers and BS are half-silvered mirrors.Half- silvered mirrors do not distinguish between color,polarization and they reflect and transmit any photon with 50% probability. And you said just yesterday BS create path entanglement. I did read all about the role each element plays on Wikipedia. Only 50-50 beam splitters entangle, filters and polarizers do not.
I have referenced Leonard Susskind's book which talks about a thought experiment of mixing up coins of different type and gives a random one to each of the two people so they won't know which coin they posess. He says the correlation obtained between the coins is not factorizable.
Is there a point here? I repeat every one of my comments with half silvered mirrors. You don't just send a couple of photons to a half silvered mirror and get entanglement out. Not sure where you get this from.
So: Got references?
So: Got references?
http://www.livescience.com/19975-spooky-quantum-entanglement.html
https://physics.aps.org/articles/v7/25
Both speak of the half-silvered mirror or the symmetric beam splitter as an alternative to SPDC.
Beam splitters erase path information, the indistinguishability of paths between two particles is the source of entanglement from the beam splitter, rather than the energy and momentum conservation which create entanglement in particle decay.
https://www.quora.com/What-is-delayed-choice-quantum-eraser[/URL]
[URL]http://www.nature.com/nphoton/journal/v6/n4/fig_tab/nphoton.2012.68_F2.html[/URL]
[URL]http://www.nature.com/nphoton/journal/v6/n4/fig_tab/nphoton.2012.68_F2.html[/URL][/QUOTE]
None of these have anything to do with what you propose. The last does at least discuss entanglement of crystals. Can you please explain [B]what [/B]of those crystals is entangled? I think you will see that the entanglement is nothing like what is usually given that label.
Again, you are extracting words from articles without any concern for the science involved. For example, in the one article where "half-slivered" appears - the reference is to a completely different experiment that is not described.
DrChinese said:
None of these have anything to do with what you propose. The last does at least discuss entanglement of crystals. Can you please explain what of those crystals is entangled? I think you will see that the entanglement is nothing like what is usually given that label.
Might I say the experiment is being described? Zeilinger says two pairs of entangled photons from nonlinear crystals are being entangled with each other with the use of beam splitter and detectors.
As of entangling crystals,
http://arxiv.org/pdf/1109.0440v1.pdf
The signal photon now traverses the switch, a polarizing beam splitter (PBS) and a Faraday rotator (FR), before a 50/50 beamsplitter (BS) creates single-photon entanglement between spatial modes A and B. This entanglement is, upon absorption, mapped onto the crystals MA and MB.
By means of absorbtion of entangled photons, I see from above setup matter particles become entangled
Your logic should connect what Zeilinger said about photons forgetting where they came from when they meet a half-silvered mirror with that Nature figure, where it says lack of information about the path of photons after they meet on a beam splitter creates an entangled state.
As you see, erasing path information creates the entanglement. And this erasing is done by beam splitter.
Also, it says on Wikipedia that fiber optic couplers entangle photons by confining and mixing them
https://en.wikipedia.org/wiki/Quantum_entanglement#Methods_of_creating_entanglement
"Entanglement is usually created by direct interactions between subatomic particles. These interactions can take numerous forms. One of the most commonly used methods isspontaneous parametric down-conversion to generate a pair of photons entangled in polarisation.[68] Other methods include the use of a fiber coupler to confine and mix photons, the use of quantum dots to trap electrons until decay occurs, the use of the Hong-Ou-Mandel effect, etc., In the earliest tests of Bell's theorem, the entangled particles were generated using atomic cascades."
Your logic should connect what Zeilinger said ...
No, you are mixing and matching snippets of text to support a position that is incorrect. You said "So if I send two photons on the same beam splitter which mixes up the photon identity and then get them absorbed by two resonant crystals, the crystals get entangled, but if I use two beam splitters, the crystals will not get entangled."
Sending 2 photons to a single beam splitter do not, on their own, result in 2 crystals being entangled in any meaningful basis. If you have some reference for this, please provide it.
And despite what you think is a reference to something similar (a single photon entangling 2 crystals), you will quickly see that there is no experimental realization of that as you envision it. It is something else entirely, you can get an idea from this work:
https://www.google.com/url?sa=t&rct...IKneUay_A&sig2=eaMGliMwSemClN7uFRIWxg&cad=rja
Again, I caution you from using terminology out of context.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&ved=0ahUKEwjQhuqG-O3KAhVIFh4KHZkOAo8QFggyMAQ&url=https://archive-ouverte.unige.ch/unige:27602/ATTACHMENT01&usg=AFQjCNEgTT_NCdsL4PzH5gsB7IKneUay_A&sig2=eaMGliMwSemClN7uFRIWxg&cad=rja
http://www.nature.com/news/diamond-shows-promise-for-a-quantum-internet-1.12870
"To entangle qubits in separate pieces of diamond, the team uses lasers to entangle each qubit with a photon at temperatures of 10 kelvin. The photons meet midway through a fibre-optic cable, where they are themselves entangled."
What about an entire computer made of ions, beam splitters and detectors?
"The individual particles of light (photons) emitted by each atom are entangled with the quantum state of the atom. Light is collected with large microscope lenses and focused into fiber optic cables. The other end of the fiber optic cables are pointed at a thin piece of glass- a beam-splitter. When the photons hit the beam splitter, the wave-like part of the two photons interfere. After passing through or bouncing off of the beam splitter, the photons pass through thin film polarizers. These polarizers reflect or transmit the photons depending on the direction the photons' electric fields and strike single photon counters. Simultaneous detection of single photons on certain detector pairs heralds entanglement between the remotely trapped atoms."
The original question has been answered, so this thread is closed.
FAQ: Are these good analogues for entanglement
What is entanglement?
Entanglement is a quantum phenomenon where two or more particles become connected in such a way that the state of one particle is dependent on the state of the other, regardless of the distance between them.
How are analogues for entanglement used in scientific research?
Analogues for entanglement are used in scientific research to better understand the principles of entanglement and how it can be applied in various fields, such as quantum computing, cryptography, and communication.
What are some examples of analogues for entanglement?
Some examples of analogues for entanglement include classical systems like synchronized pendulums or coupled oscillators, as well as physical systems such as photons, atoms, and superconducting circuits.
Can analogues for entanglement exhibit the same properties as entangled particles?
Although analogues for entanglement can exhibit similar behavior as entangled particles, they do not possess all of the properties of true entangled particles. This is because entanglement is a unique quantum phenomenon that cannot be fully replicated in classical systems.
How can analogues for entanglement help advance our understanding of quantum mechanics?
Analogues for entanglement can help us gain a better understanding of quantum mechanics by allowing us to study entanglement in a more controlled and observable manner. This can provide insights into the behavior of entangled particles and how they can be manipulated for practical applications.
