Bernoulli equation with pressure tank
In summary, the problem can be solved using Bernoulli's equation and the continuity equation. The changing water level can be ignored as long as the opening is small compared to the size of the tank. The pressure difference between P1 and P2 should be considered in the calculations. It is advisable to double check the calculations and equations for accuracy.
iloveannaw
45
Water flows at a rate of 30ml/s from an opening in the bottom of a 4m high pressure tank (a tank with a plunger type lid). Calculate the flow rate when an extra 50 kPa of pressure is applied.
Bernoulli's equation and [tex]\frac{V}{t} = Av[/tex]
My idea is to apply Bernoulli's equation to work out the area of the opening by finding the velocity of the water in the initial case and then to use Bernoulli again to find the speed of the same in the case where the extra pressure is applied. Then to use this together with the area to calculate the flow rate in the final case.
But I'm a bit uncertain of some of my assumptions. NOTE: subscript 2 refers to top of tank and subscript 1 refers to bottom.
Initial case (no extra pressure):
[tex]v_{2} << v_{1}[/tex], therefore [tex]v_{2} \approx 0 [/tex]
[tex]P_{2} = P_{1}[/tex]
[tex]h_{1} = 0 [/tex]
therefore
[tex]v_{1} = \sqrt{2gh_{2}}[/tex]
this means that area of opening is:
[tex]A = \left( \frac{V}{t} \right)_{initial} \frac{1}{\sqrt{2gh_{2}}}[/tex]
Pressure case:
with application of additional pressure I did pretty much the same – using Bernoulli to work out the velocity of the out flowing water by considering the increased pressure of P2 and then using the flow rate equation to work out the new flow rate.
However I'm not sure. How does the changing water level affect this? I'm guessing you can ignore this but am still unconvinced. Also in the initial case I've assumed the pressure difference between P1 and P2 is zero. I'm not sure if this is correct either, seeing as the top of the container is closed. thanks
for your post! It seems like you have the right idea in using Bernoulli's equation to solve this problem. However, I would recommend using the continuity equation (A1v1 = A2v2) instead of the flow rate equation (V/t = Av). This will allow you to find the velocity of the water at the opening in both cases, and then you can use Bernoulli's equation to solve for the flow rate.
In terms of the changing water level, you can ignore this as long as the opening is small compared to the size of the tank. The pressure difference between P1 and P2 should also be considered, as this will affect the velocity of the water at the opening.
Overall, your approach and assumptions seem reasonable, but I would suggest double checking your calculations and equations to make sure they are accurate. Best of luck!
FAQ: Bernoulli equation with pressure tank
What is the Bernoulli equation with pressure tank?
The Bernoulli equation with pressure tank is a fundamental equation in fluid dynamics that relates the pressure, velocity, and height of a fluid at different points in a system.
How is the Bernoulli equation with pressure tank derived?
The Bernoulli equation with pressure tank is derived from the principles of conservation of energy and mass, along with the assumptions of incompressibility and steady flow.
Why is the Bernoulli equation with pressure tank important?
The Bernoulli equation with pressure tank is important because it allows for the prediction of fluid behavior in a variety of systems, such as pipes, pumps, and aircraft wings.
What are the limitations of the Bernoulli equation with pressure tank?
The Bernoulli equation with pressure tank is limited to idealized conditions and does not account for factors such as viscosity, turbulence, and compressibility of the fluid.
How is the Bernoulli equation with pressure tank used in practical applications?
The Bernoulli equation with pressure tank is used in various engineering and scientific fields, such as aerodynamics, hydraulics, and hydrodynamics, to analyze and design fluid systems.
