Calculate the first four Picard Iterates of the equation y' - y = x^2
  • Thread starter brit123
In summary, the conversation discusses the calculation of the first four Picard Iterates of the equation y' - y = x^2 with the condition y(0) = -1. It is mentioned that the definition of Picard iterates involves the function y'(x) and its relation to f(x,y(x)). The first two Picard iterates, \phi_0 and \phi_1, are calculated using the given information. The question is then raised about the values of \phi_2 and \phi_n.
brit123
Help Please!
Calculate the first four Picard Iterates of the equation y' - y = x^2 with the condition y(0) = -1
and it was given that y'(x) = x^2 +y and y(0)= -1
Need a little help with this question... Not sure what to do.
The definition of Picard iterates is
[tex]\phi_0=y(x_0),[/tex]
[tex]\phi_{n+1}(x)=\phi_0+\int_{x_0}^x f(s,\phi_n(s))ds,[/tex]
where [itex]f[/itex] is given by
[tex]y'(x)=f(x,y(x)).[/itex]
In your case, [itex]f(x,y(x))=x^2+y[/itex], [itex]\phi_0=y(0)=-1[/itex], and
[tex]\phi_1=-1+\int_0^x (s^2+\phi_0)ds=-1+\int_0^x (s^2-1)ds.[/tex]
What is [itex]\phi_2[/itex]? and [itex]\phi_n[/itex]?
To solve this problem, we can use the Picard Iteration method, which is an iterative technique used to approximate a solution to a first-order differential equation. The first four Picard Iterates are given by the following formulas:
y_0(x) = y(0) = -1
y_1(x) = y(0) + ∫x^2 dx = -1 + (x^3)/3
y_2(x) = y(0) + ∫(x^2 + y_1(x)) dx = -1 + (x^3)/3 + (x^5)/5 + (y_1(x))^2/2
y_3(x) = y(0) + ∫(x^2 + y_2(x)) dx = -1 + (x^3)/3 + (x^5)/5 + (x^7)/7 + (y_2(x))^2/2
To find the first four Picard Iterates, we need to substitute the given condition y(0) = -1 into each formula. This gives us:
y_0(x) = -1
y_1(x) = -1 + (x^3)/3
y_2(x) = -1 + (x^3)/3 + (x^5)/5 + (-1 + (x^3)/3)^2/2
y_3(x) = -1 + (x^3)/3 + (x^5)/5 + (x^7)/7 + (-1 + (x^3)/3 + (x^5)/5 + (-1 + (x^3)/3)^2/2)^2/2
Simplifying each of these expressions, we get:
y_0(x) = -1
y_2(x) = -1 + (x^3)/3 + (x^5)/5 + (x^6)/6
y_3(x) = -1 + (x^3)/3 + (x^5)/5 + (x^7)/7 + (x^9)/9 + (x^10)/10 + (x^11)/66
Therefore, the first four Picard Iterates of the equation y' - y = x^2 are:
y_
FAQ: Calculate the first four Picard Iterates of the equation y' - y = x^2
What is the equation y' - y = x^2?
The equation y' - y = x^2 is a first-order linear differential equation, where y' represents the derivative of y with respect to x. It is also known as a homogeneous equation since the term y does not depend on x.
What are Picard Iterates?
Picard Iterates are an iterative method used to approximate the solution of a first-order differential equation. In this method, the initial value problem is solved using a series of successive approximations until the desired level of accuracy is achieved.
How many Picard Iterates should be calculated?
The number of Picard Iterates needed to approximate the solution of a differential equation depends on the desired level of accuracy. Generally, it is recommended to calculate at least four Picard Iterates to obtain a reasonable approximation of the solution.
How do you calculate the first four Picard Iterates of y' - y = x^2?
To calculate the first four Picard Iterates of y' - y = x^2, we can use the following formula: y_n(x) = y_0(x) + ∫(x^2 - y_(n-1)(x))dx, where y_0(x) is the initial guess and y_n(x) is the nth Picard Iterate. This formula is applied successively for n = 1, 2, 3, 4 to calculate the first four Picard Iterates.
What is the significance of calculating Picard Iterates?
Calculating Picard Iterates allows us to approximate the solution of a first-order differential equation without having to solve it analytically. This method is particularly useful for differential equations that cannot be solved using traditional methods or for which the exact solution is difficult to obtain.
