Calculate the velocity of the eight ball after collision
In summary, the eight ball is initially moving with a velocity of 2.25 m/s, and then it continues moving at that same velocity after it has collided with the cue ball.
aarietta
Hello, I was just wondering if I am doing this question correctly, if not, any suggestions please and thank you
A person takes aim at the eight bal in a game of billiards. Her shot gives the cue ball a velocity of 2.5m/s [forward]. The cue ball strikes the eight ball and continues with a velocity of 2.5 x 10^-1 m/s [forward]. If the mass of the cue ball equals the mass of the eight ball equals 400g, calculate the velocity of the eight ball after collision.
v1 of cueball = 2.5m/s [forward]
v2 of cueball = 2.5 x 10^1 m/s [forward]
m = 400g = .4kg
P1 = m1v1
P1 = 0.4(2.5)
P1 = 1 m/s
P2 = m2v2
P2 = 0.4(2.5 x 10^1)
P2 = 0.1 m/s
Ptotal = [(0.1)^2 + (1)^2]sqaure root
Ptotal = 1.0 m/s
Pafter = m1v1 + m2v2
1 = (0.4kg + 0.4kg)v
v = 1/0.8
v = 1.25 m/s
Thanks!
Ptotal = 1.0 m/s
I don't get this. The total initial momentum of the system is just that of the cue ball before collision.
v = 1/0.8
v = 1.25 m/s
The problem does not state the balls move together after the collision.
Hello,
I think you've made one small error on this question, in your equations it appears that you're looking for 1 velocity, when you're really looking for two. Your equation should look like this:
(0.4)(2.5) = (0.4)(0.25) + (0.4)V2prime
You already know one velocity, and you're searching for another (V2 prime) so you can't combine the two sections together (0.4+0.4)V2,
they must be seperate.
I hope this was helpful.
By conservation of total momentum,
Initial momentum = Final momentum (for any forms of collisions)
Initial P of cueball + Initial P of 8-ball = Final P of cueball + Final P of 8-ball
0.4(2.5) + 0 = 0.4(0.25) + 0.4v
v = 2.25ms
Please don't post full solutions .
You may suggest hints or point out where the OP is going wrong, but let him do it on his own .
"A person takes aim at the eight bal in a game of billiards. Her shot gives the cue ball a velocity of 2.5m/s [forward]. The cue ball strikes the eight ball and continues with a velocity of 2.5 x 10^-1 m/s [forward]. If the mass of the cue ball equals the mass of the eight ball equals 400g, calculate the velocity of the eight ball after collision"
the eight ball is supposed to move forward.
let "m" be the mass of each ball(the value is crap), which is given to be equal for both.
conserving momentum in the forward direction,
m*2.5 + m*0 = m*0.25 + m* v
* denotes multiplication and v to be found.
cancelling "m" on both sides,
v+0.25=2.5
therefore v=2.25 m/s... ANSWER.
FAQ: Calculate the velocity of the eight ball after collision
1. How is velocity calculated after a collision?
Velocity after collision can be calculated using the formula: Vf = (m1 * v1 + m2 * v2) / (m1 + m2), where Vf is the final velocity, m1 and m2 are the masses of the objects involved in the collision, and v1 and v2 are the initial velocities of those objects.
2. Can the velocity of the eight ball after collision be negative?
Yes, the velocity of the eight ball after collision can be negative if it is moving in the opposite direction of its initial velocity.
3. Is the velocity of the eight ball after collision dependent on the material of the pool table?
The velocity of the eight ball after collision is not significantly affected by the material of the pool table. It is primarily determined by the mass and initial velocity of the ball and the object it collides with.
4. How does the velocity of the eight ball after collision affect its trajectory?
The velocity of the eight ball after collision affects its trajectory by influencing the direction and speed at which it travels. A higher velocity will result in a longer and faster trajectory, while a lower velocity will result in a shorter and slower trajectory.
5. Can the velocity of the eight ball after collision be calculated without knowing the masses of the objects?
No, the velocity of the eight ball after collision cannot be accurately calculated without knowing the masses of the objects involved. The mass of the objects is a crucial factor in determining the final velocity.
