mopar969 said:My question is what is the voltage for loops 2 and three since they do not go through the power supply?
mopar969 said:I thought that the current changes at each junction that is why I have up to I6. Why doesn't this occur?
mopar969 said:I understand what you mean but in your equation for loop two how did you determine that 4I2 was negative and that 20I2 was negative?
An electric circuit is a path or network through which electric current flows. It typically consists of a power source, conductors, and loads.
Electric circuits work by allowing electricity to flow from the power source, through the conductors, and to the loads. The power source provides the energy to move electrons through the circuit, while the conductors act as pathways for the electrons. The loads, such as light bulbs or motors, use the energy from the electrons to perform their function.
In a series circuit, the components are connected in a single loop, with the same amount of current flowing through each one. In a parallel circuit, the components are connected in branches, with the current dividing between them. This means that in a series circuit, if one component fails, the entire circuit will stop working, while in a parallel circuit, the other components will still function.
Voltage (V) is calculated using Ohm's law: V = I x R, where I is current in amperes (A) and R is resistance in ohms (Ω). Current is measured using an ammeter, while resistance can be found using a multimeter or calculated using Ohm's law. Resistance is also dependent on the material and dimensions of the conductor.
Some common problems with electric circuits include short circuits, where a low resistance connection is created between two points in the circuit, and open circuits, where the circuit is broken and no current can flow. These issues can be caused by faulty wiring, damaged components, or incorrect connections.
