Calculating Potential Difference on A Capacitor, RC Circuits
In summary, the circuit of Figure P.72 has been turned on for a long time, allowing us to ignore the transient behavior of the capacitor. The voltage of the battery is 31V. Using Kirchoff's Voltage Law, the potential difference across the capacitor C (C = 9 µF) should be equal to the voltage of the battery. However, this was found to be incorrect. This could be due to the fact that when a capacitor is fully charged, the potential difference is equal to that of the battery. The circuit is then simplified to the battery driving current into the 2 and 3 ohm resistors in series, with the voltage across the 3 ohm resistor being calculated. As there is no
cwatki14
57
The circuit of Figure P.72 has been turned on for a long time, so that you can ignore the transient behavior of the capacitor. Voltage of Battery V = 31 V
(e) What is the potential difference across the capacitor C (C = 9 µF)?
I thought about using Kirchoff Voltage Law, but I also though that when a capacitor is fully charged the potential difference should be equal to that on the battery, but the computer said that was wrong. It also is not zero. Any ideas?
Initially the uncharged capacitor will have very voltage, so a lot of current will flow that way. But as it becomes charged its voltage rises until no current at all flows into it. The resistance of that part of the circuit is effectively infinite, so you just ignore it. The circuit you have left is the battery driving current into the 2 and 3 ohm resistors in series. Calculate that current and the voltage across the 3 ohm resistor. Since there is no current through the 1 ohm resistor, it will have no voltage drop V=IR across it and so you know the voltage on the capacitor.
The potential difference across a capacitor in a circuit can be calculated using the formula V = Q/C, where V is the potential difference, Q is the charge on the capacitor, and C is the capacitance. In this case, the capacitor has a capacitance of 9 µF and the battery has a voltage of 31 V.
Since the circuit has been turned on for a long time, the capacitor is fully charged and the charge on it is equal to the charge on the battery. Therefore, we can calculate the charge on the capacitor using the formula Q = CV, where Q is the charge, C is the capacitance, and V is the voltage.
Plugging in the values, we get Q = (9 µF)(31 V) = 279 µC.
Now, we can use this value to calculate the potential difference across the capacitor using V = Q/C.
V = (279 µC)/(9 µF) = 31 V
As you can see, the potential difference across the capacitor is indeed equal to the voltage of the battery. It is not zero because even though the capacitor is fully charged, it still has a potential difference across its plates.
In summary, to calculate the potential difference across a capacitor in a circuit, you can use the formula V = Q/C, where Q is the charge on the capacitor and C is the capacitance. In this case, the potential difference across the capacitor is equal to the voltage of the battery.
FAQ: Calculating Potential Difference on A Capacitor, RC Circuits
How do I calculate the potential difference on a capacitor in an RC circuit?
In order to calculate the potential difference on a capacitor in an RC circuit, you will need to know the capacitance (C) of the capacitor, the resistance (R) of the circuit, and the time (t) that has passed since the capacitor was fully charged. The formula for potential difference in an RC circuit is V = Q/C, where Q is the charge on the capacitor. To find Q, you can use the formula Q = Q0(1-e-t/RC), where Q0 is the initial charge on the capacitor. Plug in the values for C, R, t, and Q0 to find the potential difference (V).
How does the resistance affect the potential difference on a capacitor in an RC circuit?
The resistance (R) in an RC circuit affects the potential difference (V) by controlling the rate at which the capacitor charges. A higher resistance will result in a slower charging time, thus leading to a lower potential difference. Conversely, a lower resistance will result in a faster charging time and a higher potential difference.
What is the time constant in an RC circuit?
The time constant (RC) in an RC circuit is a measure of the time it takes for the capacitor to charge to 63.2% of its maximum potential difference. It is calculated by multiplying the resistance (R) by the capacitance (C), and has units of seconds (s).
Can I use the same formula to calculate potential difference for any type of capacitor?
Yes, the formula V = Q/C can be used to calculate potential difference for any type of capacitor. However, the values for capacitance and resistance may vary depending on the type of capacitor being used.
How can I use the potential difference on a capacitor to determine the charge stored on it?
To determine the charge (Q) stored on a capacitor, you can rearrange the formula V = Q/C to Q = VC. Simply plug in the values for potential difference (V) and capacitance (C) to find the charge (Q).
