Calculating SCIENTIFIC NOTATION by hand help .
In summary, to convert a number into scientific notation by hand, you need to move the decimal point until you have a number between 1 and 10, and the number of times you move the decimal point will be the exponent. Standard notation is the typical way we write numbers, while scientific notation is a more compact form used for very large or small numbers. To multiply or divide numbers in scientific notation, you can simply add or subtract the exponents respectively. In science, scientific notation is used to represent numbers in a more manageable form and express precise measurements. To convert a number from scientific notation back to standard notation, you need to move the decimal point based on the exponent.
camboguy
36
calculating SCIENTIFIC NOTATION by hand help please.
((4*10^5)(5*10^-7)) / (2*10^-3)
im getting 10 and the answer but its should be 100 can you please tell me what i am so posted to do step by step please.
4*5/2=10. Doing the exponents 5+(-7)-(-3)=1. So 10*10^1=10*10=100.
If that is indeed the problem as stated, then
Mantissa:
(4 * 5) / 2 = 20 / 2 = 10
Exponents:
5 - 7 -(-3) = 8 - 7 = 1
Answer = 10 * 10^1 = 10 * 10 = 100 = 1 * 10^2
Do you see?
thanks you very much
FAQ: Calculating SCIENTIFIC NOTATION by hand help .
How do I convert a number into scientific notation by hand?
To convert a number into scientific notation by hand, you need to move the decimal point to the right or left until you have a number between 1 and 10. The number of times you move the decimal point will be the exponent in your scientific notation. For example, to convert 250,000 into scientific notation, you would move the decimal point 5 places to the left, making the number 2.5. The exponent would then be 5, since you moved the decimal point 5 places.
Can you explain the difference between standard notation and scientific notation?
Standard notation is the typical way we write numbers, with the decimal point in a fixed position and no exponents. Scientific notation, on the other hand, is a way to express very large or very small numbers in a more compact form. It consists of a number between 1 and 10, multiplied by a power of 10 (represented by an exponent). This allows us to easily compare and perform calculations with numbers that have a lot of zeros.
How do I multiply or divide numbers in scientific notation by hand?
To multiply numbers in scientific notation, you can simply multiply the numbers in front of the decimal point and add the exponents. For example, (4.5 x 10^3) x (6.2 x 10^2) = (4.5 x 6.2) x (10^3 x 10^2) = 27.9 x 10^5. To divide numbers in scientific notation, you can divide the numbers in front of the decimal point and subtract the exponents. For example, (4.5 x 10^3) ÷ (6.2 x 10^2) = (4.5 ÷ 6.2) x (10^3 ÷ 10^2) = 0.72 x 10^1 = 7.2
What is the purpose of using scientific notation in science?
The purpose of using scientific notation in science is to represent very large or very small numbers in a more concise and manageable form. This allows scientists to perform calculations and make comparisons more easily. It is also used to express measurements with a high level of precision, as the exponent can represent the number of significant figures in the measurement.
How do I convert a number from scientific notation back to standard notation?
To convert a number from scientific notation back to standard notation, you need to move the decimal point to the right or left based on the exponent. If the exponent is positive, you move the decimal point to the right the same number of places as the exponent. If the exponent is negative, you move the decimal point to the left the same number of places as the exponent. For example, 2.5 x 10^5 would become 250,000 in standard notation, and 3.2 x 10^-2 would become 0.032 in standard notation.
