Calculating total circuit resistance
In summary, -There is just one voltage source, which is in series with one resistor.-Current passing through R1 then splits and goes through either R2 or through a combination of the rest of the resistors R3 through R7 .-Current which passes through R1 but not through R2 must pass through some combination of R4 thru R7 before it all comes back together and passes through R3 -- after which it joins up with the current from R2 and returns to the voltage source.-R3 is in parallel with the combination of the resistors, R4 thru R7 .
Jalisi
Calculate the total resistance of the circuit.
Calculate the potential difference across each of the resistors.
http://img849.imageshack.us/img849/2190/hw1v.jpg
Series resistors= RT=R1+R2+R3
Parallel resistors = 1/RT=1/R1+1/R2+1/R3
V=iR or i=V/R
V=voltage i=current R=Resistance
I'm trying to find the "groups" in the circuit so I can calculate the smaller parts them combine into a whole.
I started by calculating R5 and R6, which are parallel. 1/600+1/200=4/600=600/4=150Ω
My problem starts here. I'm not quite sure which resistors are in parallel and which are in series. I calculated R2, R4, and R7 as being parallel. Thus 1/500+1/1000+1/2000=7/2000=2000/7= 285.7Ω
Now that I have the parallel groups solved, I can look at the resistors in series so: 200Ω+ 150Ω +285.7Ω + 100Ω = 735Ω
Would that be correct for the total resistance?
If so, then to find the total current, use i=V/R so i=25v/735Ω = 0.034A
And from there I have total voltage, current, and resistance so it should be fairly easy to calculate each potential difference.
Thanks so much for any help provided.
V=iR or i=V/R
Hello Jalisi . Welcome to PF !
Your analysis of the circuit has several errors.
Lets look at the circuit starting with the "big picture", and progressing down to the small details.
First of all, there's just one voltage source. Let's start there.
Any current passing through the battery must also pass through R1. From there the current branches off in some complicated way through the rest of the resistors. It then returns to the battery, where the process starts all over again.
So, the voltage source is in series with R1 and in series with some resistance that's equivalent to the combination of all the other resistors.​
Now for a little more detail:
So we have R2 in parallel combination of rR3 though R7 .​
So R3 is in parallel with the combination of the resistors, R4 thru R7
...See if you can take it from there.
You are on the right lines upto this point. The trick is to redraw the circuit at each step until you get used to doing it so..
Redraw the circuit with R5 and R6 replaced by a single resistor marked "R5//R6".
Then it should be obvious that R7 is in series with R5//R6. So redraw the circuit with one resistor replcaing R5//R6 and R7 and marked "(R5//R6) + R7".
Then you will see that the resistor "(R5//R6) + R7" is in parallel with another resistor. I'll let you work out which one and continue from there.
Mistake.
A Tip: Two Resistors are in parallel only if you can connect both their ends to each other without any intervening resistors.
SammyS and CWatters -
Thanks for helping me figure out exactly where I was messing up and how. It took a few more attempts to really apply what you were two were talking about, then a couple more to get the match correct, but in the end I got the circuit solved. Thanks for putting me back on the correct path!
rollinstein- Thanks for the tip. That will come in handy over the next few chapters.
Thanks again all!
FAQ: Calculating total circuit resistance
What is total circuit resistance?
Total circuit resistance is the combined measure of all the resistances in a circuit. It determines how much of an impediment the circuit has to the flow of electric current.
How do I calculate total circuit resistance?
To calculate total circuit resistance, you need to add up all the individual resistances in a series circuit, or use Ohm's law (R = V/I) for parallel circuits.
What is the unit of measurement for total circuit resistance?
Total circuit resistance is measured in Ohms (Ω).
Why is calculating total circuit resistance important?
Calculating total circuit resistance is important because it helps determine the overall performance of a circuit. It also allows for proper sizing of components and helps prevent overheating and other electrical hazards.
Can total circuit resistance ever be zero?
In theory, total circuit resistance can be zero if there is no resistance in the circuit or if all the individual resistances cancel each other out. However, in practice, this is highly unlikely and usually indicates a malfunction in the circuit.
