Can Geckskin really hold 700Lbs?
  • Thread starter jetsfan83
In summary, there is a material called Geckskin that claims to be able to hold up to 700lbs. It is a synthetic version of gecko skin and there is a link to the website where it is discussed. However, there is not much information available about how it works and there hasn't been much activity surrounding it in recent years.
jetsfan83
Can this Gecksin material hold the 700lbs?
Synthetic Gecko skin? Did you have a link?
Anything can hold 700lb if you have enough of it.
https://geckskin.umass.edu/
Interesting stuff, but there doesn't seem to be much out there about how exactly it works.
They say that an index card size piece can hold 700lb. If they mean a 3"x5" card, that's only about 47psi, which seems reasonable for this sort of thing. It's a few times better than suction cups, which are limited by local atmospheric pressure.
Yeah, if it's so great, why hasn't there been more activity in the last couple of years since that was posted?
FAQ: Can Geckskin really hold 700Lbs?
How does Geckskin hold such a heavy weight?
Geckskin's impressive adhesive properties are due to its unique structure and composition. It is made up of microscopic hairs called "setae" that mimic the structure of a gecko's foot. These setae interact with surfaces on a molecular level, creating a strong bond that can hold heavy weights.
Is Geckskin safe to use for holding heavy objects?
Geckskin has been extensively tested and proven to be safe for use as a temporary adhesive for holding heavy objects. However, it is important to follow the manufacturer's instructions and use it as intended. It is not recommended for long-term use or for holding objects over people's heads.
Can Geckskin be reused?
Yes, Geckskin can be reused multiple times as long as it is cleaned and maintained properly. It is important to remove any dirt or debris from both the Geckskin and the surface it will be applied to for optimal adhesive strength. It is also recommended to use a damp cloth to clean the Geckskin after each use.
What types of surfaces can Geckskin hold onto?
Geckskin can hold onto a variety of surfaces, including smooth and rough surfaces, as well as both porous and non-porous materials. However, it works best on clean, dry, and flat surfaces. It is important to note that Geckskin may not work on extremely dirty or oily surfaces.
How long can Geckskin hold a heavy weight?
The length of time Geckskin can hold a heavy weight depends on several factors, including the weight of the object, the surface it is applied to, and the conditions it is exposed to. Generally, it can hold a weight for a few hours, but it is recommended to check and reapply if needed for longer periods of time.
