Can gravity be hypothetically used to collapse the wave function?
In summary, the conversation discussed the possibility of using gravity to collapse the wave function in Schrodinger's cat experiment. It was proposed that by changing the method of death, we may be able to determine the cat's position and collapse the wave function. However, it was pointed out that gravity is too weak to act as an observation and the uncertainty principle may be broken in this scenario. The conversation then shifted to different interpretations of quantum mechanics, with some mentioning that a large number of particles may cause the system to collapse into a definite macroscopic state. Others disagreed and stated that a state vector is a statistical prediction and nothing can be two different things at the same time.
sahej1030
Sorry if this is a silly question, I was just womdering about it.
So instead of putting Schrodinger's cat in a box we put in a room and instead of realising poison and thus killing it we push it from from one end of the room to the other end.
We will be able to notice that the force of gravity is coming from a different direction.
Is it possible?
(English isn't my first language so I apologize if there were any grammatical errors).
First of all, how were you planning on making gravity work sideways?
Second of all, by the definition of the whole problem, we aren't inside the room/box, and are unaware of what is happening inside apart from the fact that there is a cat, and something potentially deadly is happening to it. So we can't see the cat fall and either die or survive. How would changing the method of death affect things? Would we be any the wiser of whether or not the cat is dead or alive?
What I meant to say was that the cat will be in superpostion being alive at both ends of the room but hypothecially the force of gravity between the cat and the observer will be weakened as the distance between them increases.
So can this difference in the force of gravity between the cat and the observer help collapsing the wavefunction as we will know the position of the cat either at one end of the room or the other?
If the information about the cat's position is available to the observer then the wave function "collapses". If the cat's position can be determined by the gravitational field created by the cat, then it will collapse. In practice I am pretty sure this would be nearly impossible to measure.
> If the information about the cat's position is available to the observer then the wave function "collapses". If the cat's position can be determined by the gravitational field created by the cat, then it will collapse. In practice I am pretty sure this would be nearly impossible to measure.Thanks for answering, but if the position of something can be determined by the gravitational field created by it and not by its interaction with photons which thus gives it momentum, isn't the uncertainty principle broken?
Interaction isn't even necessary for measurement: https://en.wikipedia.org/wiki/Elitzur–Vaidman_bomb_tester . The uncertainty principle only gives a statistical limit to the precision of observables noncommuting to the ones you measure.
There are a number of misconceptions here. First collapse is not part of QM - its part of some interpretations but not of the formalism:
https://en.wikipedia.org/wiki/Interpretations_of_quantum_mechanics
The other issue is alive being a macroscopic concept can't be part of a superposition - you can't have a superposition of alive and dead. In Schroedinger's cat, despite the misconceptions promulgated in pop-sci literature, the cat is never in a superposition of alive and dead. The superposition is at the radioactive source - we have a superposition of particle detected and not detected - that particle numbers can be in superposition is a concept from QFT. That observation occurs at the particle detector and everything is common-sense classical from that point on - the cat is alive or dead - period. Nobody seriously considered otherwise. The purpose of the thought experiment was to highlight a blemish in Copenhagen - namely it does not give an unambiguous way to determine what an observation is or exactly where the quantum classical boundary resides. Great strides have been made in fixing that up - but a few issues remain. Nevertheless it is generally thought to be resolved.
Getting back to your original question gravity is so weak it can't act as an observation eg how it could be a position measurement I have no idea.
Thanks
Bill
That's incorrect.
Your example looks like a variant of the quantum eraser. While the decoherene of an observation can in simple cases be undone it can't work without an interaction. For example the photon goes through a half silvered mirror - that's an interaction.
Thanks
Bill
Well actually, Penrose proposes something like this in his book,The Road to Reality. When the quantum superposition involves a large enough number of particles, through interaction with environment, that the different superpositions cause sufficiently different spacetime curvatures, the system becomes unstable and collapses into a definite macroscopic state. No conscious observer needed. This makes more sense to me than most other interpretations I've heard...
Elemental
And now I see from the list of similar threads at the bottom this was explored before (should have read them first). But I like Penrose's idea, just wonder if it can be credibly established.
Elemental
I go with Ballentine who asserts that a state vector is not a statement about one object but a statistical prediction for an ensemble of identically prepared objects. Nothing is ever actually two different things at the same time. There is no collapse and certainly no dead/alive animals.
What you've written seems to me to be weird and unjustified speculation.
bhobba said:
That's incorrect.
Thanks
Bill
Sorry I meant interaction with the measured object, not the measuring photon: do you still disagree with that?
Penrose's is a modified nonlinear SE, so it's falsifiable in principle.
A measurement is an interaction between what is being measured and what does the measuring.
Thanks
Bill
This paper may be a little tangential, you be the judge. They look at the effects of gravitational photon-photon scattering (assuming there is such a thing) and how that might be different for entangled photons. Turns out there is a small difference. Observation of that might demonstrate an answer to the OP's question.
http://arxiv.org/abs/1511.01237
The effect of entanglement in gravitational photon-photon scattering
Dennis Raetzel, Martin Wilkens, Ralf Menzel
(Submitted on 4 Nov 2015)
"The differential cross section for gravitational photon-photon scattering calculated in perturbative quantum gravity is shown to be larger for polarization entangled photons than for not entangled photons."
Likes bhobba
Thanks
Bill
But the half-silvered mirror is not what is being measured.
We seem to be going around in circles here.
How about you CAREFULLY explain why you think this is a measurement that involves something being measured not interacting with something doing the measuring. If you can then the modern understanding of what an observation is goes out the window and would be big, no really big, news.
Thanks
Bill
Thanks
Bill
I would just be paraphrasing this study: http://www.univie.ac.at/qfp/publications3/pdffiles/1994-08.pdf.
Ok - got it now.
As they explicitly say it is via weak measurements which is something entirely different. Since you are interrogating a region you are in fact interacting with that region and weakly measuring it. From many such measurements you can infer things about the region. There is still interaction going on.
Weak measurements SEEM to violate many rules of QM, but don't really. For example you can measure both the position and momentum of an object at the same time using weak measurements. But the accuracy of those measurement never violates the uncertainty principle.
Thanks
Bill
Likes ddd123
Got it, thanks!
Likes bhobba
FAQ: Can gravity be hypothetically used to collapse the wave function?
Can gravity be used to collapse the wave function?
The current understanding of gravity, as described by Einstein's theory of general relativity, does not directly involve the collapse of the wave function. However, there are some theories that suggest gravity may play a role in the collapse of the wave function at the quantum level. This is still a topic of ongoing research and debate in the scientific community.
How does gravity affect the wave function?
Gravity is a fundamental force that is responsible for the attraction between objects with mass. At the quantum level, gravity is thought to interact with particles and potentially affect their behavior. However, the exact role of gravity in the wave function is still not fully understood.
Is there any evidence to support the use of gravity to collapse the wave function?
Currently, there is no conclusive evidence to support the use of gravity to collapse the wave function. While some theories suggest a potential connection between gravity and the wave function, more research and experimentation is needed to confirm these ideas.
Can gravity be manipulated to control the collapse of the wave function?
At this time, there is no known way to manipulate gravity in a way that would directly control the collapse of the wave function. However, there are ongoing experiments and studies that are exploring the potential for manipulating gravity at the quantum level.
How does the concept of gravity-induced decoherence relate to the collapse of the wave function?
Gravity-induced decoherence is a theory that suggests gravity may cause the wave function to collapse by interacting with particles and causing them to decohere. However, this is still a theoretical concept and has not been proven through experimentation.
