Can Hölder's Inequality also be applied to other optimization problems?
  • MHB
  • Thread starter anemone
In summary, the problem is to prove that if $a, b, c, d >0$ and $c^2+d^2=(a^2+b^2)^3$, then $\frac{a^3}{c}+\frac{b^3}{d} \ge 1$. The solution involves using Hölder's Inequality to show that $x^{\frac{3}{2}}+y^{\frac{3}{2}} \ge 1$, where $x=\left(\frac{a^3}{c} \right)^{\frac{2}{3}}$ and $y=\left(\frac{b^3}{d} \right)^{\frac{2}{3}}
anemone
MHB
POTW Director
3,883
115
If $a, b, c, d >0$ and $c^2+d^2=(a^2+b^2)^3$, then show that \(\displaystyle \frac{a^3}{c}+\frac{b^3}{d} \ge 1\).
Mathematics news on Phys.org
Re: Prove (a³/c)+(b³/d) ≥1
My solution
This probably can be done with some clever manipulation of inequalities but the problem does suggest that the method of Lagrange multiplier would be effective.
If we define
$F = \dfrac{a^3}{c} + \dfrac{b^3}{d} + \lambda\left(c^2+d^2-(a^2+b^2)^3 \right)$,
so
\begin{eqnarray}
F_a &=& 3\,\frac {a^2}{c}-6a\,\lambda \left( a^2+b^{2} \right) ^{2}\\
F_b &=&3\,\frac {b^2}{d}-6b\,\lambda \left( a^2+b^{2} \right) ^{2}\\
F_c &=&-\,\frac {a^3}{c^2}+2\,\lambda c\;\;\;\;\;(*)\\
F_d &=&-\,\frac {b^3}{d^2}+2\,\lambda d\\
F_{\lambda} &=&c^2+d^2-(a^2+b^2)^3
\end{eqnarray}
Setting $F_c=0$ and solving for $\lambda$ gives $\lambda= \dfrac {a^3}{2c^3}$. From the $F_a=0$ equation we have
$-3\,{\dfrac {{a}^{2} \left( -c+{a}^{3}+a{b}^{2} \right) \left( c+{a}^{
3}+a{b}^{2} \right) }{{c}^{3}}}
=0$
from which we obtain $c = a^3+ab^2$. Factoring the $F_b=0$ equation gives
$3\,{\dfrac { \left( {a}^{2}b+{b}^{3}-d \right) b}{ \left( {a}^{2}+{b}^{
2} \right) d}}=0$
leading to $d = a^2b+b^3$ noting that the remaining equation in (*) are satisfied. Thus, we have
$\dfrac{a^3}{c} + \dfrac{b^3}{d} = \dfrac{a^3}{a^3+ab^2} + \dfrac{b^3}{a^2b+b^3} = 1$
the minimum as required.
Thanks for participating, Jester and well done! And now it seems to me Lagrange Multiplier is a magic tool and can be applied to all kind of optimization problems to find the desired extrema points.
I want to share with you and others the solution proposed by other as well. It suggests the use of Hölder's Inequality to solve this problem.
If we let \(\displaystyle x=\left(\frac{a^3}{c} \right)^{\frac{2}{3}}\) and \(\displaystyle y=\left(\frac{b^3}{d} \right)^{\frac{2}{3}}\), we see that
\(\displaystyle a^2+b^2=c^{\frac{2}{3}}\left(\frac{a^3}{c} \right)^{\frac{2}{3}}+d^{\frac{2}{3}}\left(\frac{b^3}{d} \right)^{\frac{2}{3}}\)
\(\displaystyle \;\;\;\;\;\;\;\;\;\;\;\;=c^{\frac{2}{3}}(x)+d^{ \frac{2}{3}}(y)\)
\(\displaystyle \;\;\;\;\;\;\;\;\;\;\;\;\le (c^2+d^2)^{\frac{1}{3}}(x^{\frac{3}{2}}+y^{\frac{3}{2}})^{\frac{2}{3}}\)
\(\displaystyle \;\;\;\;\;\;\;\;\;\;\;\;\le (a^2+b^2)(x^{\frac{3}{2}}+y^{\frac{3}{2}})^{\frac{2}{3}}\)
Hence
\(\displaystyle a^2+b^2\le (a^2+b^2)(x^{\frac{3}{2}}+y^{\frac{3}{2}})^{\frac{2}{3}}\)
\(\displaystyle x^{\frac{3}{2}}+y^{\frac{3}{2}} \ge 1\)
\(\displaystyle \therefore \frac{a^3}{c}+\frac{b^3}{d} \ge 1\) (Q.E.D.)
FAQ: Can Hölder's Inequality also be applied to other optimization problems?
What does the inequality (a³/c) + (b³/d) ≥ 1 mean?
The inequality (a³/c) + (b³/d) ≥ 1 means that the sum of the cubes of two numbers (a and b) divided by two other numbers (c and d) is greater than or equal to 1.
How can this inequality be proven?
This inequality can be proven using mathematical methods such as algebraic manipulation and the properties of inequalities.
What are the possible values for a, b, c, and d in this inequality?
The values of a, b, c, and d can be any real numbers, as long as they satisfy the given inequality.
Can this inequality be simplified?
Yes, this inequality can be simplified by finding a common denominator and combining like terms in the numerator. This will result in a simpler form of the inequality.
In what situations would this inequality be useful?
This inequality could be useful in many situations, such as when solving problems involving geometric figures, optimization, or determining the range of possible values for a variable. It could also be used in mathematical proofs or in real-life applications such as physics, economics, or engineering.
