Can't get the concept [of energy]
In summary, work is energy, potential energy is the potential to do work, heat is the capacity to do work with thermal contact, and kinetic energy is the energy of motion.
johncena
131
Can't get the concept ! [of energy]
I can't get the actual concept or meaning of various forms of energies . Actually what is energy ? Can anyone provide a brief definition of kinetic energy and potential energy based on work ? I can't get the relation between work and energy...
Thanks in advance.
Work is energy, or rather energy is the capacity to do work - which is one of the most useless definitions in science.
Perhaps it's easier to picture energy mechanically as force * distance.
You put energy into something by supplying a force * distance - eg. by lifting a weight.
And you get it back in kinetic energy when it falls
ok.. Then what is heat energy,nuclear energy, light energy ....?
Heat energy is the capacity to do work through thermal contact. Nuclear energy is the capacity to do work via a nuclear reaction. Light energy is the capacity to do work with light.
I disagree with mgb_phys, the definition is excellent. But if you prefer a more "insightful" definition you may say that energy is the conserved quantity due to time translation invariance of a system's Lagrangian. However, that is only good if you don't define the Lagrangian in terms of energy.
how i understand work, kinetic energy, potential energy:
while lifting any object to a desired height (h) i spent some energy to overcome the gravitational pull, and when i am successful in displacing the body to a new position; means i have done some work,
potential energy: now the object is at some new location, and it has some potent energy which can be converted into other forms , that is potential energy, the potential energy of a body at height mgh.
Another way of looking at it, is that there is a conserved quantity, and we call it energy. A conserved quantity is a number you can calculate for a given system, "let it do stuff", and then calculate again the number and find out that it is the same.
It turns out that that conserved quantity is a sum of terms. And it happens to be so that "kinetic energy" is one of those terms. We can also chunk up "closed systems" in subsystems which interact with each other, and even then, we can assign terms of "energy" to the different subsystems. Some terms are "bookkeeping" terms, which add to one subsystem what they take away from others. Using this trick, you can then even say that the energy is conserved for the subsystems (but it is a trick: you used "bookkeeping").
So for the simplest of systems, the sum is just this single term. Energy = kinetic energy. As energy is conserved, this means that kinetic energy is constant.
For more complicated systems, say, a ball on earth, clearly, kinetic energy is NOT conserved. But "energy" is. We do that by introducing a "bookkeeping" trick, the "potential energy". It turns out that you can introduce a term in the energy sum of the ball, which takes into account the interaction between the Earth and the ball. The Earth itself has a similar term. The total energy of "earth + ball" is still not ok, you have to consider "earth + ball + gravity". And then the total energy is again conserved. But we don't want to work with "earth + ball + gravity". We only want to work with "ball". And there, the energy is "conserved" if we use "kinetic energy + potential energy(of gravity force)".
Now, as the ball falls through the air, we see that our sum is again "wrong". KE + PE is not conserved we find out. It turns out that that's because of the interaction with the air. There's friction. We can again get the balance right by adding yet another term: "heat".
And so on. Each time when we studied new systems, what we thought of being the "energy" seemed not to be conserved after all. But we could always manage by adding a new term that got the balance right. All these terms are "energies".
It looks like a stupid trick. Of course, if you add a cheat term each time your bookkeeping turns out wrong, you will get it right ! In a way, yes. But nevertheless, there are much less "cheat terms" than there are systems, so it is still a useful quantity. If we have a dozen or so "energy terms", that will be it, and we can describe gazillions of systems with it and it is "conserved".
But then there are more profound reasons to "know" that there is really a conserved quantity called energy, and that this is not some silly bookkeeping game. For one, energy is indeed related to the time translation symmetry of the laws of nature (that the laws are the same "today" than that they are "tomorrow").
edit: in fact, if you think about it (unless I'm making a silly mistake here), energy is the only strictly conserved continuous scalar quantity.
There are other conservation laws of course, but they are or approximative, or discrete, or not scalar (unless I'm overlooking something).
There's conservation of "mass". But it turns out that it is approximate, in relativity.
There's conservation of "atoms" in chemistry, but it turns out that nuclear reactions violate it.
There's conservation of baryon number. It seems to be exact for the moment, but it is a discrete number (an integer).
There's conservation of lepton number - again it is discrete.
There's conservation of angular and linear momentum: these are not scalar quantities but vectors/tensors.
There's conservation of charge (but that's again discrete, in 1/3 of electron units).
So energy is THE conserved continuous scalar quantity.
Well, given a conserved vector, any scalar-valued function of that vector (e.g. the norm) is also conserved.
You're right.
I like the way Feynman explains energy:
It is important to realize that in physics today, we have no knowledge of what energy is. We do not have a picture that energy comes in little blobs of a definite amount. It is not that way. However, there are formulas for calculating some numerical quantity, and when we add it all together it gives "28" - always the same number. It is an abstract thing in that it does not tell us the mechanism or the reasons for the various formulas.
More here:
http://leifi.physik.uni-muenchen.de/web_ph09/lesestoff/06_energie-feynman/what_is_energy.htm
FAQ: Can't get the concept [of energy]
What is energy?
Energy is the ability to do work or cause change. It exists in various forms such as kinetic, potential, thermal, chemical, and electromagnetic energy.
How is energy measured?
Energy is typically measured in joules (J) or calories (cal). Other units, such as kilowatt-hours (kWh) and British thermal units (BTU), are also commonly used to measure energy.
What is the law of conservation of energy?
The law of conservation of energy states that energy cannot be created or destroyed, only transferred from one form to another. This means that the total amount of energy in a closed system remains constant.
Why is energy important?
Energy is essential for all forms of life and is crucial for various processes and activities, such as growth, movement, and maintaining body temperature. It also powers our modern world and enables the production of goods and services.
How can energy be converted from one form to another?
Energy can be converted from one form to another through various processes, such as mechanical work, chemical reactions, and electromagnetic radiation. This conversion can be done naturally, as in photosynthesis, or artificially, as in power plants.
